A wearable sound-to-light display, without a microprocessor - the Musicator Junior.
Smaller than the 9-volt battery that powers it, the Musicator Jr. displays the sound it 'hears' (through the Electret Microphone) as fluctuating light bars.
Small enough to fit in your shirt pocket, it can also be placed on a flat surface to monitor the sound levels around it.
An alkaline battery will easily power it 20 or more hours.
Step 1The parts needed
The parts needed
The 'brains' of this project is a LM358 general-purpose op-amp which costs under 30-cents. The first half of the circuit is an amplifier which boosts the 500-micro-volts from an electret mic to about 1-volt. This level is generally called 'Line-level' and can be used to drive our LEDs, an audio amp, or even the input pins of an Arduino processor.
The second half of the op-amp is used as a voltage-to-current converter, which limits the brightness of the LEDs to 10mA or less.
The complete list of parts is below:
LEDs. Any combination can be used, as long as their total forward voltages is less then 8. For example, you can have up to 4 amber LEDs with 1.8v Vf.
Electret microphone - I got mine on eBay for under 25-cent
LM358 - Op-amp (8-pin DIP). Also available on eBay.
2N4401 - NPN general transistor (other audio NPN-types will probably work as well)
10k resistor x 5
2.2k resistor x 1
470k resistor x 1 (Can also be 330k as labeled in the circuit)
100-ohm resistor x 1
1uF capacitor
0.1uF capacitor
9-volt battery and connector
Perf-board and mounting parts.
Total cost: $3 or less.
239 comments
1-40 of 239next »
Jul 20, 2011. 11:47 PMAronC0816 says:
I have to agree with the two people above me. I can somewhat read schematics but this one confuses me. It would have made more sense if the rectangular shape of the op-amp was included and the interior circuits were shown inside that box. Then you could show each of the eight pins and what they should connect to. I tried to wire this up but it took me over an hour and it doesn't work. So apparently i did something wrong.
Jun 30, 2011. 11:17 PMthealeks says:
would it be hard to use 6 mics that individually trigger 6 LED's?
thanks
Jul 1, 2011. 1:31 PMthealeks says:
i want to set up a small light show for my guitar, and i want each mic to be activated by a single string, so when i play, a light will light up for each string thats played
Jul 2, 2011. 12:14 PMthealeks says:
i was hopin i could lower the sensitivity, maybe by giving the mics less power, and putting the mics right up to the strings, so they only pic up their designated string. im still learning so i dont know much about this stuff, so i dont know if that will work or not
Jul 3, 2011. 11:20 AMthealeks says:
i thought about that, but then the lights wont sync up with the strings, but the ideas not out.
last question, how would i change the sensitivity of the mic?
thanks for all your help, by the way, i appreciate it
Jul 9, 2011. 7:39 PMthealeks says:
ok awesome. thanks for your help. ill let you know how it turns out!
Jun 18, 2011. 6:00 AMphevtron says:
how sensitive is it to sounds?
Jun 19, 2011. 8:19 AMphevtron says:
thank you for replying :D you just offered a teen an amusing yet attractive decorative idea :P
May 10, 2011. 3:36 PMmusick_08 says:
instead of a microphone, could you put on a 3.5mm jack so the lights flash to a music source?
May 16, 2011. 2:13 PMmusick_08 says:
I think this would work. i wanted a small circuit that could be used with a small battery source if needed. thanks
May 16, 2011. 1:16 PMThe Insignificant User says:
Try checking out this one: http://www.instructables.com/id/Music-LED-Light-Box/
I honestly think the circuitry on this one looks a bit simpler, but it should work for what you are thinking of.
May 16, 2011. 2:08 PMmusick_08 says:
i've used the circuit for that on other projects, but i want one that can use a battery source for portability
Oct 10, 2011. 3:39 PMelijah_rippington says:
i have built that circuit to run off a 9 volt battery by placing the LEDs in parallel, so its entirely portable.
May 17, 2011. 9:24 AMThe Insignificant User says:
Oh, I see. Well, I can't say that it would work for certain, but I've run several LED's off of 2 AA batteries with the proper resistor. I haven't used the transistor that was featured in that project before, but it shouldn't cause too much impedence, I think.
Feb 9, 2011. 8:35 PMsayray says:
HI!! I am looking to create some inner light effects for a runway/hair show avant garde style... as in light would be glowing/flashing from inside the hair sculptures. Do you think something like this would work for it? Would it be bright enough for a dimly lit/ or dark stage? Could it be adjusted for more lights or brighter lights? Possibly flashing lights but w/out the music respose?? I am looking for a definate flashing/ good deal of light streaming out, not tiny rice lighting. What do you think?? Any help would me so so appreciated!!
Jan 6, 2011. 3:31 PManarky2k says:
ive made it....but my leds flash very dimmly and they have to be very close to the music source....ive gone over it and the only thing i have different is the transistor, i used a 2n2222a cause i couldnt find the other one.....could anytbody help me xS
Jan 6, 2011. 8:26 PManarky2k says:
jajaja thanks, ur right, the microphon didnt work, as soon as i put another one in it worked......noow i have a different issue....the leds dont turn off completly, they flicker alittle when theres no sound...any advice?
Dec 15, 2010. 5:18 AMmayur.phadte says:
Thank You for dat humble help
I checked the wire at R3 as well as the wire no. 19(I didnt quite get you when u said R3 + wire 19) the leds go off when I remove it
I checked the wire no. 24 as well
Dec 16, 2010. 3:34 AMmayur.phadte says:
I removed the cap all together (100 nf)
removed one pin
removed the other
interchanged postion
LEDs are still on
Dec 13, 2010. 10:48 PMmayur.phadte says:
I have dat cap
is it ok?
I think that's a polarized one
do I need to get a non polarized cap?
Dec 13, 2010. 11:00 PMmayur.phadte says:
Oh I hav a cap rated for exactly 50 volts..
so what is the recommended rating for this cap then?
even If I remove the cap the LEDs dont show any changes.they are still on no matter what i do.
Nov 28, 2010. 7:39 AMthebanano says:
hello qs, nice work...
i building this musicator for over three times...
all the problem was the same....it doesn't seem sensitive to the sound
i'll have to stay closely the mic to the sound source, then the led response with a weak light...
i do changing the 10K Resistor with 10 to 47K as you said, but the result was still the same...i'm little bit confused, because i have no electronic bacground...perhaps you can help me...
ps :
1. i'm using 2uF replacing the 1uF, coz it's hard to find a non polarised cap with that value
2. i'm using 1/4 watt resistor
3. sorry for my english
4. thank you very much
5. :-)
Nov 24, 2010. 2:01 AMmayur.phadte says:
This is what I got upto,but then when it is switched on it just lights up the 2 Red LEDs and isnt sensitive to Sound,Reverse Bias Doesn;t Work...!
Uploaded the Microphones too,I think there's a problem with my Mic..
Is Electret Mic something different?
Even tried connecting my mic reversed,,,still doesn't work/.!
Nov 25, 2010. 1:03 AMmayur.phadte says:
noticed one more thing..!
1)When I dont connect my mic(yeah! circuit minus mic)
2)When I short the two mic wires
The bulbs are still ON !
No flicker no change at all!
Nov 25, 2010. 12:49 AMmayur.phadte says:
so u mean I need to connect LEDs in parallel???
so u mean 2N4401 is also available in a PNP variant?
so u mean...that's it.
Nov 25, 2010. 12:51 AMmayur.phadte says:
dont worry about that the leftmost wire(two wires going in) rising up is negative and next to it is positive(one wire going in)
1-40 of 239next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
169
Author:qs
