3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A wearable sound-to-light display, without a microprocessor - the Musicator Junior.
Smaller than the 9-volt battery that powers it, the Musicator Jr. displays the sound it 'hears' (through the Electret Microphone) as fluctuating light bars.
Small enough to fit in your shirt pocket, it can also be placed on a flat surface to monitor the sound levels around it.
An alkaline battery will easily power it 20 or more hours.
Step 1The parts needed
The parts needed
The 'brains' of this project is a LM358 general-purpose op-amp which costs under 30-cents. The first half of the circuit is an amplifier which boosts the 500-micro-volts from an electret mic to about 1-volt. This level is generally called 'Line-level' and can be used to drive our LEDs, an audio amp, or even the input pins of an Arduino processor.
The second half of the op-amp is used as a voltage-to-current converter, which limits the brightness of the LEDs to 10mA or less.
The complete list of parts is below:
LEDs. Any combination can be used, as long as their total forward voltages is less then 8. For example, you can have up to 4 amber LEDs with 1.8v Vf.
Electret microphone - I got mine on eBay for under 25-cent
LM358 - Op-amp (8-pin DIP). Also available on eBay.
2N4401 - NPN general transistor (other audio NPN-types will probably work as well)
10k resistor x 5
2.2k resistor x 1
470k resistor x 1 (Can also be 330k as labeled in the circuit)
100-ohm resistor x 1
1uF capacitor
0.1uF capacitor
9-volt battery and connector
Perf-board and mounting parts.
Total cost: $3 or less.
246 comments
1-40 of 246next »
Aug 23, 2009. 5:12 PMJ-Five says:
Here's one that I drew.
Sep 29, 2009. 8:15 AMJim5975 says:
can you label r1, r2, c1 etc......
Nov 13, 2009. 1:44 PMJ-Five says:
what do you mean?
Nov 14, 2009. 6:17 PMJim5975 says:
r1= ???ohms etc
Nov 15, 2009. 9:29 AMJ-Five says:
Sorry about that I misunderstood what you meant. Here it is
IC1 = LM358 - Op amp (8-pin DIP)
Q1 = 2N4401 - NPN general transistor
R1 to R5 = 10K
R6 = 2.2K
R7 = 470K
R8 = 100 Ohms
C1 = 1 μF ceramic disc capacitor
C2 = 0.1 μF ceramic disc capacitor
Nov 16, 2009. 1:58 AMJim5975 says:
ok thanks
May 20, 2012. 11:42 AMJ-Five says:
No problem.
May 18, 2012. 5:41 AMindiantinker says:
Awesome Instructable..i have done something like this using Arduino and Processing!
But this one is real portable!
Im making this one...
Cheers!
Mar 24, 2012. 4:43 PMumfan110 says:
is there any way that you can split it into high, mid, and lows
Mar 26, 2012. 4:12 PMumfan110 says:
This was exactly what i was looking for did you hook this up to a mic or to a 1/8 audio jack. Mine my iggnorance but what dose COM mean i never understood that i know there is left and right but com?
Jul 20, 2011. 11:47 PMAronC0816 says:
I have to agree with the two people above me. I can somewhat read schematics but this one confuses me. It would have made more sense if the rectangular shape of the op-amp was included and the interior circuits were shown inside that box. Then you could show each of the eight pins and what they should connect to. I tried to wire this up but it took me over an hour and it doesn't work. So apparently i did something wrong.
Jun 30, 2011. 11:17 PMthealeks says:
would it be hard to use 6 mics that individually trigger 6 LED's?
thanks
Jul 1, 2011. 1:31 PMthealeks says:
i want to set up a small light show for my guitar, and i want each mic to be activated by a single string, so when i play, a light will light up for each string thats played
Jul 2, 2011. 12:14 PMthealeks says:
i was hopin i could lower the sensitivity, maybe by giving the mics less power, and putting the mics right up to the strings, so they only pic up their designated string. im still learning so i dont know much about this stuff, so i dont know if that will work or not
Jul 3, 2011. 11:20 AMthealeks says:
i thought about that, but then the lights wont sync up with the strings, but the ideas not out.
last question, how would i change the sensitivity of the mic?
thanks for all your help, by the way, i appreciate it
Jul 9, 2011. 7:39 PMthealeks says:
ok awesome. thanks for your help. ill let you know how it turns out!
Jun 18, 2011. 6:00 AMphevtron says:
how sensitive is it to sounds?
Jun 19, 2011. 8:19 AMphevtron says:
thank you for replying :D you just offered a teen an amusing yet attractive decorative idea :P
May 10, 2011. 3:36 PMmusick_08 says:
instead of a microphone, could you put on a 3.5mm jack so the lights flash to a music source?
May 16, 2011. 2:13 PMmusick_08 says:
I think this would work. i wanted a small circuit that could be used with a small battery source if needed. thanks
May 16, 2011. 1:16 PMThe Insignificant User says:
Try checking out this one: http://www.instructables.com/id/Music-LED-Light-Box/
I honestly think the circuitry on this one looks a bit simpler, but it should work for what you are thinking of.
May 16, 2011. 2:08 PMmusick_08 says:
i've used the circuit for that on other projects, but i want one that can use a battery source for portability
Jun 13, 2010. 1:35 PMelijah_rippington says:
i have built that circuit to run off a 9 volt battery by placing the LEDs in parallel, so its entirely portable.
Oct 1, 2011. 4:59 PMThe Insignificant User says:
Oh, I see. Well, I can't say that it would work for certain, but I've run several LED's off of 2 AA batteries with the proper resistor. I haven't used the transistor that was featured in that project before, but it shouldn't cause too much impedence, I think.
Feb 9, 2011. 8:35 PMsayray says:
HI!! I am looking to create some inner light effects for a runway/hair show avant garde style... as in light would be glowing/flashing from inside the hair sculptures. Do you think something like this would work for it? Would it be bright enough for a dimly lit/ or dark stage? Could it be adjusted for more lights or brighter lights? Possibly flashing lights but w/out the music respose?? I am looking for a definate flashing/ good deal of light streaming out, not tiny rice lighting. What do you think?? Any help would me so so appreciated!!
Jan 6, 2011. 3:31 PManarky2k says:
ive made it....but my leds flash very dimmly and they have to be very close to the music source....ive gone over it and the only thing i have different is the transistor, i used a 2n2222a cause i couldnt find the other one.....could anytbody help me xS
Jan 6, 2011. 8:26 PManarky2k says:
jajaja thanks, ur right, the microphon didnt work, as soon as i put another one in it worked......noow i have a different issue....the leds dont turn off completly, they flicker alittle when theres no sound...any advice?
Dec 15, 2010. 5:18 AMmayur.phadte says:
Thank You for dat humble help
I checked the wire at R3 as well as the wire no. 19(I didnt quite get you when u said R3 + wire 19) the leds go off when I remove it
I checked the wire no. 24 as well
1-40 of 246next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:qs
