3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
AA Battery Powered "Tesla Coil"
AA Battery Powered \"Tesla Coil\"
First things first:
DISCLAIMER: I am not responsible for any injuries or property damage that may befall you from following this instructable. High voltage electricity can be DANGEROUS and should only be worked with at your own risk. Proper safety precautions should always be followed.
That out of the way, welcome to my first instructable. Seeing as this is my first, any suggestions for improvements are greatly appreciated. Just go easy on me.
This is intended to be a how-to guide for a newbie to high voltage (like myself) looking for a quick, cheap, and relatively safe project. Although this is not a true tesla coil, as it does not utilize a resonant air-core transformer or operate at high frequencies, in effect it is similar. It still throws out plasma discharges from the top load and about 3.5 centimeter arcs to ground. Estimated output is about 100kv.
Step 1Parts and Pieces
Parts and Pieces
There aren't many parts to this build, and most can easily by scrounged from old TVs and other electronics or be bought for cheap. The following is needed:
Bug zapper racquet: This can be purchased from Ocean State Job Lot for about 5 bucks, and is nifty for fending of mosquitos or high voltage experiments. There are probably other types of devices very similar, but I would recommend finding the racquet pictured to insure the internal circuitry is the same.
Flyback transformer: Any flyback transformer will do, though the bigger the better. Don't kill yourself looking for an old non-rectified design, since there are no benefits of it for this circuit.
Random assorted hardware: This circuit requires a spark gap to be constructed. The design of the spark gap can vary, as long as the two ends where the arc jumps is rounded, and the gap adjustable. For mine, two Erector set brackets were used. One had a ball bearing soldered to it, the other a nut over top the hole, so a bolt with an acorn nut on the end can be threaded through. See the attached picture for the details.
2xAA battery holder: Can be purchased from Radioshack or the bug zapper handle can be used to hold the batteries.
Optional:
Additional Capacitors: Should be rated for at least 1.6 KV. The Bug zapper already contains one, but for bigger sparks more can be used.
Toggle Switch: The switch on the board of the bug zapper can be difficult to use, and because of the design of the bug zapper circuit, floats at high voltage, leading to a shock hazard when it is exposed. Because of this, a new switch is recommended.
Pen body or other plastic tube: To elevate the top load
Top load: I used a ball bearing, but anything smooth and without sharp edges or points can be substituted.
Of course, solder and a soldering iron as well as other general tools are needed, and wire for connecting everything together
108 comments
1-40 of 108next »
Apr 14, 2012. 10:34 PMBrunoG says:
Good project but what is the range of the value of the capacitor bank is it in the range of 10 to 500pF or 20 to 600nF or 1 to 20uF?
Please respond.
Apr 15, 2012. 6:35 PMBrunoG says:
If it helps
Mar 25, 2012. 10:46 PMf22archrer says:
a little help here please... i want to make this for my phy project..and have successfuly done..till what you have done!! thanks alot for that..
now i was just wondering if I could show the teacher...a small LED bulb glowing with this tesla coil... is that possible with 1k voltage???
please answer
Jan 10, 2012. 2:08 PMtesla man says:
One more question. When you said the racket had capacitors, what did you mean?
Feb 11, 2012. 3:03 PMtesla man says:
Would You leave the capacitor in the racket circut board thingy, or take it out?
Mar 26, 2012. 11:36 AMExtreme Intellect says:
You would leave it in.
Mar 25, 2012. 10:48 PMf22archrer says:
can i get a led glowing out of it??..
Jul 22, 2011. 6:58 PM-max- says:
its better if all your capacitors are identical, and wired for more voltage (series) and have at least a 1M resistor across all of them. you might consider making your own out of aluminium foil, and plastic sheets
Jul 22, 2011. 7:02 PMNicola Tesla says:
what does the resistor do?
Jul 22, 2011. 7:12 PM-max- says:
it evens the voltage across all the capacitors. you learn in science class "a series circuit divides voltage across all the loads" (capacitors, in our case) well, caps are tricky, if they are not EXACTLY the same, some will charge with more voltage than others, and that can cause the overloaded capacitor to fail, and conduct, then its a chain reaction, the voltage is now divided among fewer capacitors, and are charged to higher voltage, causing them to fail.
Jul 22, 2011. 8:07 PMNicola Tesla says:
oh thanks for telling me! =)
Jul 30, 2011. 10:15 AM-max- says:
for every millimeter of spark in the air, is 1000V (this means a inch long spark is 20,000 volts! )
Jan 10, 2012. 2:15 PMtesla man says:
thats not potentially true... a taser is 10,000v but across the leads,an at least 2 inch spark can be formed.(depending on the taser.)
Jan 11, 2012. 5:39 AM-max- says:
i always see them rated at 500,000V to a few million volts. and they have pointed electrodes, i forgot to mention that, the 1000V per mm. is for smooth polished electrodes in the ideal atmosphere.
Jul 30, 2011. 8:14 AMNicola Tesla says:
ok thanks i'll try it out when my better caps arrive
Jul 31, 2011. 6:46 AM-max- says:
do you know about basic electronics, you shouldn't build this if you don't. also, for a more true Tesla coil, you need a really old huge flyback transformer. every now and then, a good one comes along eBay, and you can get one out of a really old TV. for a even more realistic coil, make your own primary and secondary coil. only then will you have a true "Tesla coil"
Jul 31, 2011. 7:25 AMNicola Tesla says:
yes i now "Basic Electronics" and i don't plan on making a bigger one
Jul 31, 2011. 8:34 AM-max- says:
good, you should also know high voltage safety precautions. a real tesla coil doesn't need to be large.
Jan 10, 2011. 11:27 AM-max- says:
i dont have too many high voltage capacitors, all of them have different values, i make my own with wax paper and foil.
Jul 29, 2011. 4:49 PM-max- says:
OK. but still, be on the safe side
Jan 10, 2012. 2:06 PMtesla man says:
So, what is the voltage output of the spark?
Jan 7, 2012. 10:21 AMtesla man says:
So, from my understanding, It starts out at the racket circut board, goes to the flyback transformer, which goes to the switch. Then the spark gap and cappacitor, and finally the primary, seconday, and topload. Is this correct????
Jan 8, 2012. 1:14 PMtesla man says:
Thank you!
Dec 19, 2011. 8:00 PMtechno guy says:
Can you make a schematic of that driver circuit thing?
Nov 7, 2011. 9:58 PMmmaaz says:
can you show me back of capaciter's bank
Nov 8, 2011. 7:10 PMEEduino says:
Would it be possible to make a singing tesla coil with this? I think all I would have to do is change the circuit a bit and use fiber optics to send the signal from my computer. I'm just trying to find a low cost way to do this, and I love how simple this is setup!
Oct 21, 2011. 1:01 AMD.L.Downs says:
Enjoying the info, I was wondering instead of the spark gap could I use a 555 or a simply relay with a cap to buzz off and on? Also could I use 9v in place of the AA? to get a small bit more on the out put? Thank you
Oct 7, 2011. 2:27 AMisaksena says:
Joe, in the first photo what is the rod-like thing near the ball bearing with which you're getting such long bolts ?
1-40 of 108next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:JoeBeau
Why fix it if it ain't broken? Cause it's fun!
