AA Battery Powered "Tesla Coil"
 by JoeBeau
Featured
First things first:
DISCLAIMER: I am not responsible for any injuries or property damage that may befall you from following this instructable. High voltage electricity can be DANGEROUS and should only be worked with at your own risk. Proper safety precautions should always be followed.
That out of the way, welcome to my first instructable. Seeing as this is my first, any suggestions for improvements are greatly appreciated. Just go easy on me.
This is intended to be a how-to guide for a newbie to high voltage (like myself) looking for a quick, cheap, and relatively safe project. Although this is not a true tesla coil, as it does not utilize a resonant air-core transformer or operate at high frequencies, in effect it is similar. It still throws out plasma discharges from the top load and about 3.5 centimeter arcs to ground. Estimated output is about 100kv.
Step 1: Parts and Pieces
There aren't many parts to this build, and most can easily by scrounged from old TVs and other electronics or be bought for cheap. The following is needed:
Bug zapper racquet: This can be purchased from Ocean State Job Lot for about 5 bucks, and is nifty for fending of mosquitos or high voltage experiments. There are probably other types of devices very similar, but I would recommend finding the racquet pictured to insure the internal circuitry is the same.
Flyback transformer: Any flyback transformer will do, though the bigger the better. Don't kill yourself looking for an old non-rectified design, since there are no benefits of it for this circuit.
Random assorted hardware: This circuit requires a spark gap to be constructed. The design of the spark gap can vary, as long as the two ends where the arc jumps is rounded, and the gap adjustable. For mine, two Erector set brackets were used. One had a ball bearing soldered to it, the other a nut over top the hole, so a bolt with an acorn nut on the end can be threaded through. See the attached picture for the details.
2xAA battery holder: Can be purchased from Radioshack or the bug zapper handle can be used to hold the batteries.
Optional:
Additional Capacitors: Should be rated for at least 1.6 KV. The Bug zapper already contains one, but for bigger sparks more can be used.
Toggle Switch: The switch on the board of the bug zapper can be difficult to use, and because of the design of the bug zapper circuit, floats at high voltage, leading to a shock hazard when it is exposed. Because of this, a new switch is recommended.
Pen body or other plastic tube: To elevate the top load
Top load: I used a ball bearing, but anything smooth and without sharp edges or points can be substituted.
Of course, solder and a soldering iron as well as other general tools are needed, and wire for connecting everything together
Step 2: Dismantle the Zapper
The bug zapper is easy enough to open. First, pry off the battery cover, and then remove the screws. There are two up near the head of the racquet, two near the bottom of the battery compartment, and another at the top of the battery compartment. Once removed, the back half of the handle can be lifted off, exposing the back of the circuit board. Remove the screw in the middle of the circuit board, and snip the wires running to the head of the racquet as close to the head of the racquet as possible, and snip the wires where they attach to the battery contacts. Now that the board is removed, the rest of the racquet is not needed.
Step 3: Prepare the Zapper Circuit
Now that the circuit is removed, it has to be slightly modified for our needs. First, remove the original momentary push switch, and in its place solder a jumper. Next, remove the negative battery wire from the board, and solder in its place the lead from the AA battery holder. Solder the positive battery wire on the board to the normally open lead on the toggle switch, and the positive lead from the battery holder to the common lead on the toggle switch. If you have extra capacitors, these can be used to make a capacitor bank. if you go this route, desolder the capacitor from the board, and set aside with the other capacitors. If you choose to not do this, leave the capacitor in its place. One of the black wires from the board's output can also be removed, since it is not needed. If you choose to make a capacitor bank, see below. Otherwise, the board is all set. The final product with capacitor bank is showed below, mounted on a piece of painted mdf.
Capacitor Bank:
This is relatively simple to make. Find as many high voltage capacitors as you want to use and wire them in parallel. In my case, I chose to use six, for no apparent reason. They can be mounted on a perf board as shown for a neater appearance.
Step 4: Spark Gap
One of the wires from the zapper capcitor/capacitor bank feeds directly to the flyback transformer, which will be addressed in the next step, the other through the spark gap. The spark gap works to allow the capacitors to charge to the point when the electricity jumps the gap, and continues into the flyback. This creates short, powerful pulses to feed the flyback. The design of the spark gap can vary, but there are some general requirements:
It has to be adjustable for the width of the gap.
The ends of each electrode should be rounded.
The rounded shape is to prevent corona leakage between the electrodes. For my spark gap, one electrode is a ball bearing, the other a bolt with an acorn nut on the end. The electrodes are then mounted on Erector set pieces, and each nailed to the mdf that my whole setup is mounted on. the bolt can be screwed in or out to adjust the width of the gap. The wider the gap, the slower but more powerful the pulses, the narrower the gap, the faster but weaker the pulses. The gap then feeds into the flyback transformer.
Step 5: Flyback Transformer
This is easily the most time consuming and tedious part of the build. While many other people might rewind their own primary coils on the flyback, I prefer to use the ones already available, since they are already nicely potted in the flyback. Unlike most flyback driver circuits, which use a primary and feedback coil, this just uses one primary coil. To find the primary coil, its down to trial and error. Using a multimeter, measure the resistance across each pair of pins. I find that in a majority of flybacks, the primary coils (as there are usually more than one) are situated so that their inputs are next to each other. That being said, this is not always the case. As you measure across each set of pins, take note of their resistances, as the one with the lowest resistance has the fewer number of coils. This is the one we are after. However, make sure that this is an independent coil, and that there isn't a third pin connected to it. Once this coil is located, the secondary coil needs to be located. Part of this is already done, since one "pin" is the fat (usually red) wire that comes out of the top of the transformer and has a suction cup on the end. The method for locating the second pin is relatively crude. Connect a 9 volt battery to one of the primary coil pins with an alligator clip, and to the other primary coil pin, connect an alligator clip. Don't connect this alligator clip to the battery yet. Take fat the red wire, and with the suction cup removed and the end stripped, place it close to one of the unused pins. Tap the disconnected terminal of the battery with the loose alligator clip, and look for a spark between the wire and pin. If there is none, move it closer and try again. If there is still no spark, move onto the next pin. If the wire doesn't spark to any of the pins, reverse the polarity of the battery and try the whole process again. Eventually, you will come across the pin you are looking for. Before disconnecting the battery from the flyback, take note of the polarity of the primary coil pins. If you are using one of the new flybacks, the polarity is important, since they contain a rectifier and voltage multiplier circuit. Once the primary coil is located, solder two long wires to it, and to the pin that the fat red wire sparks to, solder another wire. Then, just to be safe, pot the pins in hot glue. Make sure to use plenty of glue, and fill all gaps and spaces. This prevents unwanted arcing. Once this is done, the coil is all set.
Step 6: Putting it All Together
The flyback is now ready to be wired into the rest of the circuit that we prepared. In my circuit, the positive output from the capacitor bank goes thought the spark gap, then to the flyback. The negative output from the capacitor bank goes directly to the flyback. In this way, the spark gap is wired in series with the flyback. Once this is all set, the circuit is ready to be tested. flip the circuit on, and the red LED that was already on the zapper board should light up. This means the circuit is running and the capacitors are being charged. If you don't get a spark across the spark gap, check the width of the gap. If the electrodes are touching, back the bolt out (or however your spark gap is set up) until a spark is achieved, or if they are too far apart, make the gap smaller. DON'T MAKE ADJUSTMENTS TO THE SPARK GAP WHILE THE CIRCUIT IS ON!!!!! If you do so, you will be shocked. Once you have a spark, put the fat red wire close to the wire soldered to the other pin of the secondary. You should have an arc jump the gap. If not move the wires closer. If you get an arc from the secondary coil of the flyback, give yourself a pat on the back, your circuit is done! if not, time for troubleshooting. Check all connections, make sure the capacitor bank is charging by using a high voltage multimeter to check the voltage across the capacitors, check the spark gap width, check the polarity of the primary coil connections to the flyback, and check to make sure you are using the proper pins. Once the circuit is working, it's time to package it all up. Below, the picture is after its been mounted to a piece of mdf and a top load added, which is addressed in the next step.
Step 7: Top Load and Mounting the Circuit
To make the circuit function more like a classic Tesla Coil, one end of the secondary coil needs to be grounded. This is done by simply attaching it to a grounding post or cold water pipe. The pin of the secondary that should be grounded is the one on the bottom of the flyback. The fat red wire is connected to the top load. The top load is simply something metal and smooth, without any edges or points. A large ball bearing works well for this. I then glued the top load to a plastic pen body, with the wire running up the inside. to make the whole set up neater, it was mounted on painted mdf (medium density fiberboard). The wire running to the top load enter the side of the board, then takes a right turn up inside the pen body. The other wire from the secondary coil enters the board from the side, but then connects to a binding post, so that a grounded wire can be attached to it. You can choose to do it as I have done, or mounted everything in a box, or however.
Using the "Tesla Coil": Turn the switch on, and with a grounded wire attached, plasma discharges will leave the top load. Because the discharges are low amperage, they are difficult to see in the light. In a dark room, once your eyes adjust, they are visible as white, mini lightning bolts. A wire can be attached to the grounding post, and placed near the top load, so it arcs to it. The longest arc I have recorded was about 3.6 cm long. The spark gap can be adjusted to achieve different results as well. Making the gap bigger leads to fewer pulses, as low as 1 a second, but leads to the most powerful discharges out of the top load. This is best when trying to achieve the largest arc to ground. Making the gap smaller leads to faster, but less powerful pulses. This is best for making plasma discharges into the air. Making the gap too small, however, will severely weaken the discharges. Finally, don't run the circuit for too long, no more than about 30 to 35 seconds at a time, as this can lead to the zapper circuit overheating and failing.
Congratulations on your new AA battery powered "Tesla Coil"!. Have fun with it, show it off to family members and friends, and experiment with high voltage! Remember, just remember to use common sense and be safe.
1-40 of 138Next »
my wookie says: Mar 5, 2013. 12:58 PM
could you upload a schematic of your racket's board? i have all those parts already if i could see how they went together.
JoeBeau (author) in reply to my wookieMar 10, 2013. 2:53 PM
Here are some pics. Unfortunately I wont be able to upload an actual schematic for a while so this is in case you want to get a head start on it.
JoeBeau (author) says: Mar 8, 2013. 1:52 PM
I'll post some better pictures of the board shortly. I am really busy as of late and will put up a schematic eventually, but in the mean time it might be quicker if you were to do it yourself. I can't trust myself to do it in a timely manner...
MadGuitarist says: Jan 19, 2013. 8:04 AM
thanks joe for solving my problem and concerns , but ive got anothe prob here ive bought a bigger flyback from my local electronic repair shop the guy tlod me that it was removed from old TV but it is giving smaller sparks can you tell me why is it so?
JoeBeau (author) in reply to MadGuitaristJan 30, 2013. 3:49 AM
Is it a rectified type or unrectified? The old flybacks have just a pancake coil on them, with no rectifier circuit. The rectifier circuit of modern flybacks also have a voltage multiplier in them, which can give you longer sparks. That being said, if you build a ZVS type flyback driver you want the unrectified type because then you can run it at higher power without destroying the rectifier circuit.
I would check to make sure you are running it at the proper polarity, if it is rectified, as well as making sure you are using one of the lowest resistance coils.
MadGuitarist in reply to JoeBeauFeb 1, 2013. 8:34 AM
i dont know but looks like the same one as the one you shown in the picture
jabelone says: Nov 20, 2012. 1:22 PM
Sorry, double comment \/. Any way, one other thing. My dad is a diesel fitter and works with electricians all the time. He also has a lot of "Sources." If I could choose a voltage of the transformer what should I ask him to get? Thanks heaps, and awesome Instructable!
JoeBeau (author) in reply to jabeloneDec 5, 2012. 10:06 AM
The transformer should be as high of a voltage as possible. Here, the voltage being put into the transformer is a lot more than its rated for. Generally, The voltage in to a regular step up tranformer should be 120 volts. Here, its about 2kv, so the output will be about 15 or 16 times higher than the rated output.
jabelone in reply to JoeBeauDec 6, 2012. 12:49 AM
Thanks, he ended up getting me a 25kv one off ebay for about $7. :)
MadGuitarist says: Nov 23, 2012. 8:31 PM
hey joe ur project is awesome i have also made it i had removed the core of the flyback and the discharges were more longer than then ones when the core is attached & do u have any suggestions that how can i get more larger sparks when one end of secondary coil is grounded
JoeBeau (author) in reply to MadGuitaristDec 5, 2012. 10:09 AM
Winding your own turns on the transformer could increase the output spark lengths, potentially. Coupling will be a problem, however, unless you continue to use the core. With the core removed, there is a potential to be able to tune the circuit to operate at a resonant frequency, similar to a true tesla coil. This is why you are probably getting longer sparks. Playing around with the capacitance value could be used to tune the circuit, and this would then allow the circuit to behave more like a traditional tesla coil.
jabelone says: Nov 20, 2012. 1:16 PM
What is the voltage of your transformer?
What is the voltage of you Transformer?
resistanceisfutileiflessthan1ohm says: Oct 22, 2012. 11:05 AM
brilliant instructable, very clear and seems quite easy to do. i guess the circuit could be powered by the charging circuit of a disposable camera rather than a bug zapper?
sooraj619 says: Jul 7, 2011. 8:14 AM
since the flyback transformer pins are glued, the pins cant be seen so please add pictures to show which are the pins nice job
JoeBeau (author) in reply to sooraj619Jul 7, 2011. 4:48 PM
The flyback pictured is a different one, and the pinout is different. The pin marked by the line is the other high voltage pin, and the ones marked by the single and double dots are the pins to the primary. But by comparing this flyback to the one in the instructable you can guess which pins are the ones being used in the instructable. Sorry, but i couldn't get a picture of the pins in the hot glue.
crazy-blender in reply to JoeBeauAug 3, 2012. 10:53 AM
what model of flyback did you use
sooraj619 in reply to JoeBeauJul 17, 2011. 7:41 AM
thanks
PyroTrician95 says: May 26, 2012. 8:52 PM
i was wondering, does the zappers circuit allow the capacitors to overchard and just dump their load with out a "complete" circuit?and if so thwn does the spark gap just allow the capacitor to fully charge before it over loads and dumps its chrage through the primary coil?
JoeBeau (author) in reply to PyroTrician95Jun 28, 2012. 6:12 AM
The capacitors dump their load into the primary coil of the flyback, which is in effect an open circuit due to the airgap of the spark gap in series with the coil. As a charge builds up in the capacitors, a charge builds up across the spark gap due to it being wired in parallel to the capacitors if one were to ignore the resistance offered by the primary coil. But due to that resistance, the charge builds up slower across the spark gap, allowing the capacitors to build a stronger effective charge than would just be present across the spark gap. Once the charge across the gap has reached a point where it can arc, it does, completing the circuit and allowing the capacitors to then discharge into the series circuit of the acring spark gap and primary coil.
Essentially, during charging, the spark gap sereves to be a second capacitor wired in parallel to the actual capacitors, until it discharges, at which point it is now wired in series with the primary coil
PyroTrician95 in reply to JoeBeauJul 31, 2012. 6:32 PM
thanks that helps :)
crazy-blender says: Jul 17, 2012. 6:40 AM
also what is voltage of the flyback's HV output
JoeBeau (author) in reply to crazy-blenderJul 21, 2012. 3:33 PM
Depends on the voltage going into it and the number of windings. Typically, it would be a max of 20kv. Here, it is possibly closer to 200kv
crazy-blender says: Jul 17, 2012. 6:00 AM
what type of flyback do you need rectified or non rectified ?
JoeBeau (author) in reply to crazy-blenderJul 21, 2012. 3:32 PM
Either. Non-rectified makes better sparks if you are using a flyback driver. Here, there is no difference.
The_Fire_Emu says: Jul 15, 2012. 12:23 PM
also, will adding capacitors make the amperage higher?
JoeBeau (author) in reply to The_Fire_EmuJul 21, 2012. 3:32 PM
As i said in the comment below; up to a certain point. The capacitors store a charge that is then released through the spark gap. Eventually, adding bigger and bigger capacitors wont show a benefit because you will reach the limit of the spark gap set by the voltage anyway.
The_Fire_Emu says: Jul 11, 2012. 6:28 AM
You said that you can add additional capacitors for lengthier sparks, so would that mean if I put a huge capacitor in the circuit it would generate giant sparks?
JoeBeau (author) in reply to The_Fire_EmuJul 21, 2012. 3:29 PM
Possibly... The capacitor and spark gap work in tandem to resonate at a specific frequency in a regular tesla coil. Here, thats not the case. Don't waste your time with a monster cap- eventually you wont see any benefits if the capacitance was raised any higher
crazy-blender says: Jul 10, 2012. 12:53 PM
will it kill you ?
JoeBeau (author) in reply to crazy-blenderJul 10, 2012. 2:38 PM
No. I have avoided it for safety's sake, but by the time the 1.5 volts is stepped up to 20 kv the amperage is very low
ROBOCOP603 says: Jun 9, 2012. 5:36 PM
Could I get the spark gap to be larger if I had both of the rounded sections be good sized neodymium magnets?
I'm trying to make a plasma staff that has three blades around a center area at the top. These blades will be at least two to three feet long. I was thinking that I could have the blades be plastic and have a series of neodymium magnets on all three of them with sparks jumping either from blade to blade at random points or along each blade from magnet to magnet, or having sparks fly from the blades and each point of the blades at the same time! I might need a strip of metal running along each blade connecting the three series of magnets as one, so I will need to split either the positive or negative spark gap wire into three one going to each blade.
What do you think?
JoeBeau (author) in reply to ROBOCOP603Jun 28, 2012. 6:04 AM
I am not familiar with magnets increasing arc length, but maybe it could work by some principal i am not aware of. I guess one could argue that the magnets could in effect increase the potential difference on either side of the spark gap by interacting with the magnetic fields produced by electron flow. But i feel that this would be a very minor difference.
I dont know if that would work. Give it a try. There's nothing to lose
crazy-blender says: Jun 27, 2012. 6:38 PM
if you touch the sparks will it kill you
BrunoG says: Apr 14, 2012. 10:34 PM
Good project but what is the range of the value of the capacitor bank is it in the range of 10 to 500pF or 20 to 600nF or 1 to 20uF?
Please respond.
JoeBeau (author) in reply to BrunoGApr 17, 2012. 4:49 AM
To say it simply- I dont know. Each of the large red capacitors are .1 uF, but the blue ones are unmarked except for "1.6 kv" Seeing as this project does not use resonance like a true tesla coil, the capacitor bank does not make a huge difference. I would guess that my cap bank is between .2 uF and .4 uF. But dont worry abou it too much.
BrunoG says: Apr 15, 2012. 6:35 PM
If it helps
f22archrer says: Mar 25, 2012. 10:46 PM
a little help here please... i want to make this for my phy project..and have successfuly done..till what you have done!! thanks alot for that..
now i was just wondering if I could show the teacher...a small LED bulb glowing with this tesla coil... is that possible with 1k voltage???
please answer
JoeBeau (author) in reply to f22archrerMar 27, 2012. 3:26 AM
1 kv is kinda high for an LED, bt they do gow, yes, at voltages like that. This circuit can be used for that. What would probably be a better idea is to use a flash bulb from a disposable camera. You can actually see the spark travel through it. Or, a small neon bulb
tesla man says: Jan 10, 2012. 2:08 PM
One more question. When you said the racket had capacitors, what did you mean?
1-40 of 138Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
