3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
AC Arc Welder FAIL
AC Arc Welder FAIL
I had the idea to make an arc welder from Tim Anderson's instructable "Build a Microwave Transformer Homemade Stick/Arc Welder". On his instructable he shows how to make a welder out of two microwave transformers.
I began working on it. After many hour of work and $80 spent it was finally finished. However, when I tried welding with it, it would not even arc. After half an hour of failed attempts I accidentally got my welding rod stuck to the metal I was welding. Before I even had a chance to remove it, one of the transformers began melting down.
What did I do wrong? Should I have used larger than 10 gauge wire for the new secondary coil? Should I have wound it more times? Fewer times? Do I have my transformers wired wrong?
If you can answer any of my questions please comment below. It would be greatly appreciated.
29 comments
Sep 8, 2011. 7:10 PMrjnerd says:
Are you sure you have the transformers connected with the correct phasing? If you got the phase wrong, they will fight each other. What is the open circuit voltage for each transformer, and for the combined?
Second, do you have any experience with a stick welder? Difficulty getting a rod started, and rods sticking are the norm when first starting out. Look around for a class or another weldor, to get some time on known working welders. New welder and weldor (welder is the machine, weldor the person) together mean you can't tell where the problem is.
What kind of rod are you using? How has it been stored? Did you try cleaning off the end of the rod, to make sure it would make contact? (you might try a "bounce" start" to see if you can get an arc that way. hold the stinger a little loosely, and tap straight up and down, the idea is to get it to "recoil" so it won't stick - its one way to deal with crud on the tip of the rod, or when a rod burns "into" the flux coating - look at the end, and you will see what amounts to a tube of flux, that will need to get broken off before the rod can make contact. You need to learn regular "match" starting, as its hard to control the bounce start, it often bounces out of arcing distance, but it is a good way to "warm up" a stubborn starting rod)
Mar 3, 2012. 6:31 PMjakdedert says:
"Are you sure you have the transformers connected with the correct phasing? If you got the phase wrong, they will fight each other. What is the open circuit voltage for each transformer, and for the combined?"
BINGO!!!! Give the man a prize!
This was my first thought on reading the OP. Not nearly enough space has been devoted to this aspect. It's a shame, because the topic is dear to my heart. I'd build the welder in a heartbeat. I learned how to weld when I was ten years old; but my neighbors would absolutely freak out if I started arc welding on my back porch (the only suitable spot for doing it).
That said, if one isn't sufficiently knowledgeable to understand the basic electricity involved, one shouldn't be fooling with high-current AC. Sorry, kids. DO NOT try this at home without reading a book--even an article--on AC fundamentals. It looks like fun, but you can kill yourself, or burn your house down.
Dec 11, 2011. 12:22 PMsnotty says:
Hmm. My first try melted down too.
I used stranded wire that was too thin and got overloaded.
My second failure involved wrapping too tightly and cutting the insulation on a sharp corner of the transformer. This caused a short circuit. I fixed it by filing down the sharp edges around the transformer's hole and re-winding it.
I've made two of these welders. They both work but can only use thin rods (around 1/16") and they still trip the circuit breaker after a few seconds. Also they get pretty warm.
I used three smaller transformers in my first welder and two larger ones in my second welder.
The primaries (connected to the wall plug) are in parallel and the secondaries (the ones we rewind with thick wire) are in series. You should have 30 volts minimum.
Dec 15, 2011. 4:02 PMsnotty says:
For my working welders I used the wire recommended in the original instructable. I think it was 10ga solid wire.
Sep 22, 2011. 8:30 AMEternal_Tristan says:
I'm a little alarmed to hear that there are people out there building these things who don't have a multimeter. You MUST have a multimeter to successfully complete this project. You need to be able to check the voltage of your transformers. Make sure the meter is set to AC Volts (NOT AMPS) and check the voltage. If it is too low you need to wind more transformers and stack them up. I have found that microwave transformers come in many different sizes. Some of them are a lot smaller than the ones used in the instructable. On second thought, if you don't have a multimeter this might not be a safe project for you. You should have a good idea of how electricity work before playing with this kind of fire power.
Practice the one hand always in a pocket rule. This is probably the most dangerous configuration of scrap electrical components possible. Play it safe and get some help like T Bomber.
Dec 14, 2011. 9:54 PMdph84 says:
I know, I started reading this out of passing interest and I've just become more and more alarmed by the different ways people are misinterpreting what's going on.
To everyone--> because I'm forcing myself to stop reading more comments on this intructable, out of the need for less worry in my life-- PLEASE understand that this instructable is intrinsically very SIMPLE, and yet there are a few key aspects of it that are dangerous to anyone who would be working on the circuit, be they professional or amateur. Get someone's help who at least kinda sorta knows what they are doing. Discharge that large capacitor in the microwave and test it with a multimeter to ensure that you got rid of all the voltage. Sometimes there is quite a bit remaining after the first "pop!" Be CAREFUL and fully understand the phase (think of it kinda like polarity) of the transformers, and if you don't have a clue what that means then just skip this build. You might spend a lot less time finding someone who will gladly show you how to weld, than you would on this project BTW.
Apr 17, 2012. 12:51 PMsnotty says:
The voltage is fine for pretty much any mulitimeter. The amperage is a different story though. I only ever tested the voltage of the two transformers separately and together. The amperage would have been too high and blown my meter, actually an AA battery would also blow my meter's fuse. So you don't need a fancy meter to test voltage.
Sep 22, 2011. 12:18 PMEternal_Tristan says:
Basically almost any multimeter can handle standard wall voltage (120VAC), and you should be expecting less than 120VAC because you are wiring the transformer as a step down transformer. You should be expecting no more than 20v to 50v out of one of your transformers. My guess is that your voltage is even lower since you can't get an arc. Any time you have more windings on the input and fewer windings on the output of a transformer you have a "step down transformer." A step down transformer basically takes the electricity from the input and steps the voltage down while proportionately increasing the available current. An arc welder is essential a high current, low voltage power supply.
Nov 22, 2011. 11:52 PMtansit234 says:
One tip, have the transformer cores 90 degrees to each other so the mag field doesn't bleed over between the two.
I waited and watched craigslist (for a long time) until a Miller Dialarc 250 AC/DC came up for $300.....plus the $350 co-pay when my Dad threw his back out helping me. Don't lean over when you're man handling 180 pounds (1/2).
Sep 11, 2011. 2:08 PMlenny25 says:
I've been working on the same project and off for a long time. I also tried with two transformers and melted my primary coils together. No 1. You need the heaviest gauge wire you can get your paws on. No 2. Get an ameter that can measure amperage up to 200amps, that way you can fiddle with different configurations and see what's happing to the volts and amps in the secondary circuit. You need a minimum about 30volts if you want a arc, and a fair amount of amps if you want to melt anything. No. 3 Look at other DIY welders on the web, there are stax of them. Most of them use between 4 to 12 transformers. I actually don't know how Tim Anderson's welder works without overheating. My welder has six transformers which means the load is much more distributed, and therefore it does not heat up/melt down. The problem I have is that my welder, welds at like 150amps. Which is great for heavy duty welding but it just burns holes in anything thinner than 3mm. I have tried all sorts of different configurations of the transformers' primary and secondary circuits, parallel and series and vs versa. And have not really managed to be able to bring the current down and still maintain a reasonable amount of volts for it to arc properly.
Our electricity in South Africa is 220v, and we also have a different frequency as well, which throws a big spanner in the works for me trying to follow the american guys' calculations. At the current moment I have lost interest in the project, when i am more motivated again I will try to "cool it down". For now I have made quite a few useful things with it, like a motorbike stand, and various tools.
Try thicker gauge wire, and then try another MOT or two and see what happens. Don't spend money on stuff!...That defeats the whole point of DIY... I put adverts up on gumtree asking people for their broken microwaves, and in a week, I had six microwaves! The copper i chopped out of the secondary windings, earned me enough money at the scrap yard, that I could buy all the wire I needed for my new secondaries, plus stuff like rod holders and clamps etc. I also bought my wire from a scrapyard, which meant I paid 1/10 of what it would cost me new.
Oct 3, 2011. 9:17 AMswitch62 says:
How have you got your 6 transformers wired?  Multiple MOT designs are usually a combination of series and parallel connections of secondaries.
Also did you leave the shunts in the MOTs.  The shunts are to limit the power through the MOT, without them the MOT can draw too much power and overheat.
To reduce the welding current you actually may need to have more turns on your secondary, that means slightly thinner wire.  This will give you higher voltage with less amps.  You probably won't need as many transformers.
Tim had 20 windings to get 20V from each transformer.  With two 1000W MOTs he got 40V at 50A for welding.  That's a fairly low powered welder.
Your voltage and frequency should not cause any trouble with calculations.
Basically with a transformer Power in = Power out  and Power = V x A
So if your secondary winding gives you 20V and you have a 1000W MOT then you get P / V = 1000 / 20 = 50 Amps.
As you can see if your secondary voltage goes up you current goes down and vice versa because the maximum power stays constant.
To calculate the maximum current on the primary 1000 / 220 = 4.5 Amps
To work out your turns ratio on the MOT just put 10 turns on the secondary using any thin insulated wire, we aren't going to draw current from it.  Connect the mains to the primary and measure the voltage on the secondary, divide the voltage by 10 and you get your turns ratio.
EG secondary measures 12V that gives you 1.2V per turn.
Remove the wire afterwards.
Sep 14, 2011. 1:24 AMjking14 says:
When you took the wires out of the transformers, did you yank out the steel shunts also? You needed to keep those in (mostly to limit the current so you don't burn them up on a dead short).
Also you need to find the output voltage when tied together in series vs individually. They should add together (say 12V from one and 14V from the other gives 26V, which is low, but ok to weld with). If they seem to subtract (say you get 2V) you need to swap the wires on one of the MOT's. This is also very crucial to check if you plug in the two plugs into different circuits, as the may be on the same phase or opposite phase.
If you wired the output of the MOT's in Parallel, that requires a little more attention as to how you wire your MOT's
Sep 14, 2011. 11:35 PMjking14 says:
You could replace the shunts, but it would have to exactly the same size shape and structure as the original. Way too difficult in my opinion. If you cannot find the old shunts, it would be easier to wire up new MOT's, or build a saturable reactor.
As for measuring the voltages, by all means use a multimeter (just have it set for AC voltage..)
Sep 14, 2011. 4:04 PMT Bomber says:
I just started putting together another one of these,this time with solid strand wire.However,the two transformers I have are smaller than the ones I used before(physically smaller).The voltage is the same.After one set of windings it is already painfully obvious to me that I'll never get anywhere near 20 windings on either one.If I got another transformer,how many windings of what size wire would give me the same amperage?I realize that this question has probably already been answered somewhere amongst all the comments on these welders,indirectly if not directly.
Sep 13, 2011. 5:24 PMT Bomber says:
I just put one together,meaning I read the instructable,aquired the microwaves, prepped the transformers and got everything lined up for assembly and an electrician friend of mine wired it up according to what I told him the instructable called for.After one minor reconfiguration,much to his suprise-it worked!Neither one of us had any trouble striking an arc and it welded fairly well on a relatively thin piece of angle iron,with good penetration.I used 1/16" rod.However,it did pop a crcuit breaker after 2 minutes(20 amps).I know nothing about electricity,thats why I had someone help me.I don't know why yours didn't work,but it seems there are several variables even with something this simple.Maybe you damaged the primary coil when you removed the old secondary?I had to junk one of my transformers when I nicked the primary coil by accident.And like I said-my friends a professional electrician and his first attempt got no results.I used #10 multistrand wire and I actually got all 20 windings on each.My next one I'm going with #10 solid.I'm also going to wind the secondary in the same direction as the primary to see what difference it makes.Also try to get thin rod specific for ac welding.Good luck-keep trying.
Sep 8, 2011. 6:00 PMPhil B says:
I cannot speak to why your homebrew welder did not perform. But, at $80 laid out, you almost could have found a used welder for just a few dollars more. I have a Miller Thunderbolt 225 I bought a dozen years ago on eBay for $75 plus $50 shipping.
Sep 9, 2011. 12:15 AMPhil B says:
I am one who should have saved to buy one welder, but has bought a cheap welder, replaced it with a better welder, and then bought still another better welder. If I had saved and spent what I should have spent, I would have spent less in all. But, you may still be able to salvage your project. I have seen plans for homebrew welders that used parallel strands of smaller wires, like #10, to achieve the current carrying capacity of #6 cable. The advantage is that you are able to use more of the space in the metal core opening than you could with one heavier cable. If the primary windings on your microwave transformers are not burned up, you may be able to make your welder work. There is also another version of that welder which uses a rheostat on the primary to give some control of the output on the secondary windings. It is the one referenced by Tim Anderson as from Dan Hartman. You probably saw it.
Sep 8, 2011. 6:47 PMrimar2000 says:
Maybe you are using thick electrodes. Use the thinnest you can find.
Sep 8, 2011. 12:44 PMcrankyjew says:
i used 10 gauge wire in my microwave welder, and i just barely could get it to arc, even with 1/16" electrodes. even then it was only every 10 attempts or so. i would definitely recommend trying again with larger gauge wire. 6 or so i think.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:DIY Dave
"Can't" can't do anything until "try" comes along and does it
