Introduction: AC Booster Fan
Picture of AC Booster Fan
Booster fan to increase air flow to rear seats.
Step 1: Parts Needed
Picture of Parts Needed
80mm PC fan, I used a spare one I had but the higher CFM the better.
12 Volt cell phone car charger.
A few pigtails for connecting charger to fan.
One plastic cable strap.
Solder and Soldering Iron.
Electrical tape or heat shrink tubing.
Wire strippers.
Step 2: Cut Wires and Solder Pigtails
Picture of Cut Wires and Solder Pigtails
Cut wires to length and solder pigtail connectors
Step 3: Install Holding Strap
Picture of Install Holding Strap
Install plastic cable strap and secure with electrical tape.
Step 4: Installation on Front Vents
Picture of Installation on Front Vents
Slide plastic strap into vent opening and push fan up against vent. Adjust to direct air flow to right areas.
Step 5: Installation on Rear Seat Vents
Picture of Installation on Rear Seat Vents
Same as step above, depending on size of vent you might need to rotate by 90deg to fit into fin openings. Plug into 12volt lighter socket and enjoy!
seamster (author)2014-10-22
Great idea! Thanks for sharing this.
About This Instructable
1,247views
12favorites
License:
More by ArnaldoA:AC Booster Fan
Add instructable to:
