3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
AC Powered Engine Timing Light
Back in the 1970s I wanted a xenon timing light to replace the nearly useless neon timing light I had. I borrowed a friend's AC powered timing light to use. While I had it, I opened it and made a diagram of the circuit. Then I went to an electronics supply store and got most of the parts. I got the lens and the xenon flash tube from Sears. To do that, I took the model number from a new unit on the shelf and went to their repair parts store. In a few minutes I had the part numbers I needed and ordered them. Today you can use an Internet search to find replacement parts for xenon timing lights. I decided on an AC circuit because the circuit is simpler and because I can use the light on machines with a magneto ignition where there is likely no battery.
Once we had a yard full of gopher mounds. The soil was clay. When I hit one of those with my mower, it often sheared the flywheel key. I eventually put timing marks on that mower so I could check it with this timing light before tearing the motor apart and learning it was not running for some other reason.
Be careful: this circuit makes use of high voltage. Before handling internal parts use a screwdriver with a plastic insulated handle to remove the charges from the capacitor by shorting out the case or ground terminal to the "+" terminals of the capacitor. Do this a couple of times to be certain all charges are removed.
The paint was from an aerosol can of touch up paint for a 1963 Chevrolet.
Step 1A wooden case
A wooden case
I made the case from plywood. I began by cutting a pistol grip base from two pieces of 3/4 inch plywood. I made recesses for the trigger switch, the AC power cord, and for the copper core spark plug wire. There is a hidden pivot pin in the 1/4 inch plywood trigger.
Next I cut and glued the right side panel to the side of the base. Then I framed the light with a back, top, and front. The front has a hole for the lens.
You can also see wedges to hold the wires in place in the pistol handle.
8 comments
Jan 20, 2011. 12:37 PMThe Lightning Stalker says:
Old TVs and monitors are a good source for the parts. You can get Xenon tubes on the Internet or a place where they sell strobe lights.
Jan 16, 2010. 9:29 PMstormende says:
Sweet, a blast from the past!
I do remember my father had one of this timing lamps but if I recall right, the light was redish meaning it was some kind of neon, isn't?
Anyway, congrats for such a nice instructable.
I gave it 5!
Jun 4, 2009. 3:46 PMmortaz says:
thanks for you and keep it on, do not let any thing to stop you becoase its been sold for more than 100$
Apr 18, 2009. 1:20 AMgrantaccess says:
Very cool. I love hearing about pre-google hacks.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
475
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
