In this instructable, i will be showing you how to convert an AC power transformer into a shoking device.
Remove these ads by
Signing UpStep 1Needed Materials:
An AC power adapter that you are willing to take apart (i think any of them should work)
A button/ switch
A square 9v battery (with good charge left)
Another square 9v battery (dead or one that you want to destroy)
Soldering Iron
Solder
Dremel
Electrical tape
Hot glue
A vice
Minimal electronics and soldering knowledge and skills.
I'm very happy, that I spotted this instructable, because I need a device @ school to prank others.... will make it with 2 leads, countdown timer (with Atmega), and fake voltmeter!! :)
But, I personally do it all of the time, now that I know what I'm doing. The trick is in soldering the leads onto the terminals without actually touching the battery with the soldering iron. It requires good timing and copious amounts of flux.
"Taser International also says that while its device can deliver up to 50k volts, it does not deliver that much voltage to a person's body. The company says it's Advanced Taser M26 delivers an average of 1.5k volts.
As well, the high-voltage pulse of a Taser is said to carry only a small amount of current, typically 0.002 to 0.03 amps."
If a circuit was included that pulsed the DC before going into the transformer, one could achieve 110 vDC out (with a standard wall wart), but not much more. But it would be continuous AC current nonetheless. As this stands, it will pulse one swift bzzt, per button push.
