A sweet jig was used to quickly assemble the trestles, standardizing the tables and ensuring ADA compliance. The detailed saw setups make cutting parts short work. FKLP's thoughtful assembly steps simplify accurate construction. Lastly, I have included some build suggestions and a survey of failure mechanisms.
A single person should be able to finish a table in a weekend. Approximately 25 volunteers, working two half-days, can assemble 10+ tables. These tables are strong, heavy and durable, excellent for years of use.
Remove these ads by
Signing UpStep 1: Tools, Materials and Plans
- 3D full scale model of the picnic table, both in shareable open format "ADA Compliant Picnic Table.dae" and in SketchUp format "ADA Compliant Picnic Table.skp". The file can also be downloaded from the Google 3D Warehouse listing.
- The table plans and basic materials list "Picnic Bench Plans.pdf" with a QR-code that links back to this Instructable.
- Assembly instructions "Table Assembly Steps.pdf" with relevant measurements labeled.
Budget $400 per table. Actual cost was ~$350 per table for the builds in 2011 and 2012. If you are using these plans to make a single table for your home, keep in mind the table's sheer weight of ~300 lbs. The weight can be reduced by using shorter 2x12's (also shorten the 2x4's and recalculate their angles). Alternately, try different lumber, perhaps non-treated. At your store, collect lumber and lift for weight estimate.
The materials for a single table are:
- 5pieces [ 2" x 12" ] by 10' treated wood
- 2pcs [ 2" x 6" ] by 12' treated wood
- 1pcs [ 2" x 6" ] by 10' treated wood
- 1pcs [ 2" x 4" ] by 8' treated wood
- 16pcs 1/2" x 31/2" stainless steel carriage bolt, with nuts and washers
- 1 lb. 16 penny galvanized nails (~50pcs)*
- 1/3lb. 9 penny galvanized nails (~35pcs)*
- 1/2 gal floor enamel paint**
**FKLP used different paint and quantities from listed in the schematic-materials (primer and top coat instead of 1/2gal floor enamel paint).
Prep-day tools for a large-volunteer program (3 saw-stations, 2 sanding-stations and 1 paint-station):
- 4 20' x 20' shade / rain tents
- Tarps for ground cover at paint spray area
- Extra tarps for wind block, if necessary
- Lots of extension cords
- 3+ power bars with internal breaker switches
- 15+ Saw Horses
- Three 24" x 16' work platforms to set up saw stations
- Sliding Miter Saw
- 3 Miter Saws
- Scrap 2 x _X_ boards for rests and board stops
- Many 3" deck screws to secure saws and stops
- 3 pliers for pulling staples from lumber
- 2 wheel barrows
- 2 belt sanders
- ~10 sander belts, ~80-grit
- Paint sprayer**
- Air compressor**
- Paint-operator safety equipment (goggles**, respirator**, disposable clothes)
- Paint sprayer cleanup equipment**
- Four sturdy poles, ~10' long to carry wet parts
- Stacking spacers for wet parts, ~20pcs per table
- Work gloves
- Safety Glasses
- Cold water
- 3+ 20' x 20' shade / rain tents
- lots of extension cords
- Custom trestle assembly jig***
- 6 Drills
- 10+ 1/8" drill bits
- 2 1/2" spade-drill bits
- 2+ Socket wrenches for 3/4" nut and bolt
- 20+ Saw horses
- 8+ 20oz hammers
- 4+ Nail punches for 16d nails
- 4+ Tape measures
- 4+ Carpenter squares
- 4+ Pencils
- Paint sprayer**
- Air compressor**
- Four sturdy poles, ~10' long to carry wet tables
- Scrap 2x6 boards to place under wet table feet
- Work gloves
- Safety glasses
- Cold water
***The custom assembly jig is explained in the following step.
Not Nice
Visit Our Store »
Go Pro Today »
