3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
ADJUSTABLE PCB VICE
ADJUSTABLE PCB VICE
This adjustable vice for holding printed circuit boards while soldering is built around a discarded car rear view mirror and other readily available material.
Step 1BASIC PARTS
BASIC PARTS
A  discarded  Maruthi Suzuki Van rear view mirror provides a ready made ball and socket joint and an additional semi-circular degree of freedom for the PCB vice. The old mirror is removed by placing the whole assembly in boiling water, the plastic expands and the old mirror comes out smoothly. The flat surface originally seating the mirror forms a perfect base for the PCB vice. An Aluminum  tower bolt used for fastening doors forms the second major component.
10 comments
Jan 15, 2012. 12:55 PMProBodger says:
This is a great invention, who would have thought using a bolt for a vice. I am definatly going to attempt this, or something similar, don't think I will track down a mirror. I will wait till the better weather though, so that I can again get access to my workshop (garden shed), without freezing to death.
Nov 20, 2011. 3:46 PMpfred2 says:
I wish I could find a picture of the PCB holders we used at one job I worked at. They were nice. They had a square back beam that two arms slid on with locking screws so you could lock the arms in place and just leave them there. Then the arms had V grooves up and down them that you slid the boards into. Also when you pushed the stand in, you could flip it around, so you could work the board top or bottom.
We were a volume production assembly shop so we needed holder stands that were really quick and easy to do repetitious work in quickly. They were very simple, and once setup for a particular board it was slide it in, then slide it out.
Boss man liked that.
Jan 3, 2012. 12:56 PMbricabracwizard says:
I think I may have used the same device many, many moons ago so I have tried to recreate one for myself here:
http://www.instructables.com/id/PCB-Holder-prototype/
Jan 3, 2012. 6:40 PMpfred2 says:
Ours was more like a two pronged fork you just slipped the board into. The fork tines held the board, and slid on the square back support to adjust for different sized boards. The back support was attached to an upright, then to a base. It was all a rather simple affair. I'll make a really bad sketch of it. Try to add the pivot points, locking screws it has etc. with your imagination.
I think I forgot the collar that would have slid up and down on the upright and attached to the back support. You should get the idea though.
Jan 3, 2012. 8:07 PMbricabracwizard says:
I gather from your sketch you still need to bend the component wires to hold the components in place when you flipped the board to solder?
Jan 3, 2012. 11:00 PMpfred2 says:
I suppose that would depend on your skill level. But nothing about the board holder would limit one in any way. It can hold a board in any angle, I neglected to draw in the pivot point, it also locks in the horizontal and vertical, but nothing stops you from having the board at any angle.
Nov 18, 2011. 1:57 PMmdog93 says:
can you take a few more shots to show how the movable jaw attaches to the threaded rod?
Nov 17, 2011. 6:27 AMjavi_el_largo says:
Nice vice, I tell you once and I tell you twice!
Mine is a Panvavise JR., but yours is just as good as mine.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:ajoyraman(Ajoy Raman)
I am a retired Electronic Systems Engineer now pursuing my hobbies full time.
