Introduction: A.D.U Bazooka 1040 (Armor Demolition Unit)
Picture of A.D.U Bazooka 1040 (Armor Demolition Unit)
Check my El Diablo Assualt Pistol R-45
This is my Heavy Assault Weapon!
It has a staggering power that will knock you out of your boots!
The range is about 100 ft with the normal bullet.
It has a shoulder support and the very reliable ratchet system.
Don't have any words left so i'll just tell some pros and cons.
Pros:
-Insane power!
-Looks awesome.
-Scares anyone instantly (especially your mom).
-Strong body
-Good range
-Ratchet system
Cons:
-Takes long to build
-Learning to reload is hard
You likey?
Let's get to building then, shall we?
WARNING:
THIS GUN IS LETHAL!!!
NEVER FIRE THIS AT ANYONE!!!
THE BOX PICTURE SHOWS HOW POWERFUL IT IS!!!
ONCE AGAIN, NEVER FIRE THIS AT ANY LIVING THING (Exluding Justin Bieber as he is the son of Satan.)!!!
Titles:
-It passed the 4 star barrier (once).
Step 1: The Slingshot
Picture of The Slingshot
This part is just for some extra fun
a little slingshot with reasonable power
The trigger is located on the back of the frame.
Step 2: Sides for Wheels
Picture of Sides for Wheels
These parts come in handy, since they make the frame sturdier.
Build this part 2 times
Step 3: Barrel
Picture of Barrel
This part is too let the bullet come out straight of the barrel.
Step 4: Top
Picture of Top
This part is for a more sturdy barrel.
If this is not built and not attached to the gun when you try firing, boy are you in serious trouble then
Step 5: Wheels
Picture of Wheels
These are for an easier pullback of the bands and a stronger barrel.
Step 6: Front Barrel
Picture of Front Barrel
This part is for a more steady shot that goes out straight.
Step 7: Sides
Picture of Sides
The sides for the barrel.
Step 8: The Rear
Picture of The Rear
This part is for a more sturdy frame.
Step 9: Bars (1)
Picture of Bars (1)
Strength bars
Step 10: Bars (2)
Picture of Bars (2)
Strength Bars.
Build this two times.
Step 11: Bars (3)
Picture of Bars (3)
Strength Bars.
Build this 2 times.
Step 12: Bars (4)
Picture of Bars (4)
Strength Bars.
Step 13: Scope Thingy
Picture of Scope Thingy
I don't know why i put this on the top, but it just looked cool.
It is not required.
Step 14: The Rubberbands
Picture of The Rubberbands
These are 5 royal postal rubberbands tied together.
Make 2 of them.
Step 15: The Top of the Rear
Picture of The Top of the Rear
This part is for more strength.
Step 16: Bullet
Picture of Bullet
This is the original bullet designed purely for destruction.
Step 17: Strength Bars
Picture of Strength Bars
This one is for a sturdy frame.
Step 18: Shoulder Rest
Picture of Shoulder Rest
This part is too have a steady base when you are carrying it around.
Step 19: Trigger and Handle
Picture of Trigger and Handle
This part is too hold back the rubberbands, and too have a firm grip onto the gun.
Step 20: Bi-Pod
Picture of Bi-Pod
This is not an actual bi-pod, but it gives some support when you put it down.
Step 21: Assembly (1)
Picture of Assembly (1)
The pictures speak for themselves.
If you have a question, post you're problem on my orangeboard.
(I made the assembly in several steps because, the computer would stop when i wanted to upload all at once)
Barrel
Step 22: Assembly (2)
Picture of Assembly (2)
Rear + Barrel
Step 23: Assembly (accesories)
Picture of Assembly (accesories)
An accesorie for a steady shot (bi-pod), or when you put it down it has a steady base.
Cannon Completed:
Vie step 24 for loading.
Step 24: (Re)loading
Picture of (Re)loading
This is pretty hard and will require some skills
and a bit of training won't harm you either
Cannon:
-Pull back the rubberbands (you can get a grip at the blue rod squares)
-Get the bullet
-Slide it down the barrel
-FIRE!!!
Small Slingshot:
-Get the bullet
-Slide in the yellow rod
-FIRE!!!
Step 25: You're Done!!!
Picture of You're Done!!!
Well you've built yourself one of the biggest guns on Instructables:
The A.D.U Bazooka 1040
Have freaking much fun!!!
Kona-chan (author)2013-08-29
if we make a hell of a lot of these, WE CAN DESTROY ALL THE JB LOVES MAHAHAHAHA
knexboy586 (author)2013-08-23
BEST.GUN.EVER!
Evergladess (author)2012-04-06
a birds eye view picture would be great thanks
shieldsam (author)2011-12-23
Is this optional? :D
Skreetsha (author)shieldsam2011-12-24
Lol, never
shieldsam (author)2011-12-19
can i use the barrel of this in my cannon?
Skreetsha (author)shieldsam2011-12-19
If you do that, you must realize. You're basically using a key part from another creator, that way it's more like a huge mod then anything else.
But sure, if you want to
shieldsam (author)Skreetsha2011-12-23
no offence but what I'm building is just using the design from this barrel, because i couldn't build a barrel that wouldn't just explode when i fired
Re-read my reply, you didn't get my point.
i really can't tell what u have to do here
knexinventer (author)2011-11-28
i might make a gun with your trigger and Handel but ill give you credit
Skreetsha (author)knexinventer2011-12-10
Okay, fair enough
knexinventer (author)2011-09-26
just rebuilt it and now it is better
Skreetsha (author)knexinventer2011-10-06
Good :3
knexinventer (author)Skreetsha2011-11-28
it blew up yesterday
fire_1 (author)2011-10-22
I made this AWSOME!!! buzooka, but my only con is that Ihave not been able to find royal postal rubber bands!
bjarne96 (author)2011-07-30
hoe herlaad je de bazooka en kunner er ook tennisballen in voor mijn hond?
knexinventer (author)2011-07-05
when i made this gun i fired it and it blew up in my face
blackboard (author)2011-06-07
finly someone understands that justin bebier is satiatins son
arf200 (author)2011-05-27
i did not relize how big this was till i finnished making it. dannng!!!!!!!
Skreetsha (author)arf2002011-05-29
Lmao, yeah you can't really see the scale of it properly, that is true sadly. Anyways, enjoy your new asset!
danbaha (author)2011-05-23
Would #64 bands work? If not where do I get the royal mail postal bands?
Skreetsha (author)danbaha2011-05-25
I think you can't use 64#'s on this. They dont stretch enough, i think it might snap the barrel in half.
I got the mail bands from my mom, who (used to) deliver mail. Lol
danbaha (author)Skreetsha2011-05-25
I actually tried the number 64s and the first couple shots the wheels came off. After maybe 20 shots or so it started working great! I think the rubber bands got more steched out or something. Great gun! I like the little slingshot :)
Skreetsha (author)danbaha2011-05-26
Yeah that's probably it. Lol, you're the second to mention the miniture slingshot. Lmao
skyfaller (author)2011-03-31
Video plox?
Skreetsha (author)skyfaller2011-04-04
Read beyond the top ten comments ''plox''?
skyfaller (author)Skreetsha2011-04-07
Oh, sorry. I've actually seen that video before too. I guess i forgot :P
STUNTMANIC101 (author)2011-01-22
Can you give a piece count because I want to know if I have enough to build this beast
knexinventer (author)2010-11-22
what is the rachet system
Skreetsha (author)knexinventer2010-11-30
Retype this question in a different way because this is quite inaccurate. Cheers
james4 (author)2009-09-18
dam you make such good Instructables
Skreetsha (author)james42009-09-18
Was that sarcasm or real? If real, thanks :P
james4 (author)Skreetsha2010-11-08
real
smattman22 (author)Skreetsha2009-11-27
 dont put a target in front of a ps2!
Skreetsha (author)smattman222010-03-09
Lolz, it was just to show ;)
james4 (author)Skreetsha2009-11-15
it was real
knexinventer (author)2010-07-30
i made your gun and it blew up after i shot it for the first time i built it just like the pics
Im_the_knex_god_hail_me (author)2010-07-25
me and my friend built this it is amzing alot of parts tho but exact range was 127 feet with a strand of 6 #64 bands almost 200 with 8 # 84 bands so in other words its a beast and if you like i can post a vid on youtube of it and it fireing
KnexFreek (author)2009-12-12
 no offence, but this doesnt deserve #1 spot. im not a hater, so i didnt rate. i actually dont know what to rate so..... yea... i didnt rate at all
but iac's cannon is 100000000000000000000000000 times better
Hiyadudez (author)KnexFreek2010-04-07
It doesnt matter if IAC's cannon is 100000000000000000000000000 times better. This is SO much more piece efficient and even though the bullet is smaller, it still shoots as far as IAC's cannon. But the low piece count substitutes for the small bullet.
KnexFreek (author)Hiyadudez2010-04-07
 i was still a newb back then!!
Hiyadudez (author)KnexFreek2010-04-08
"i was still a newb back then!!"
That suggests that you were, and still are, a noob.
DJ Radio (author)Hiyadudez2010-04-10
0wn3d.
Hiyadudez (author)DJ Radio2010-04-10
*bows*
PieMaster777 (author)Hiyadudez2010-07-10
even though IAC's cannon is 1000000000000000000 times better, it isn't a fair comparison since there's 5 versions of that same cannon.
even though IAC's cannon is 100000000000000000000000000000 times better, it isn't really a fair comparison since there are 5 versions of that same cannon.
knexpeople (author)2010-06-28
Hiyadudez, knexfreek is no noob,you are no noob, i am a noob
FlutterTree (author)2010-03-06
T-t-t-that's a b-b-bullet???????
An Villain (author)FlutterTree2010-04-07
no it's toilet paper, actually it's a shell.
About This Instructable
8,883views
32favorites
Bio: Favourite games are LittleBigPlanet2 and Gran Turismo 5. Favourite music genre is drum and bass, but my current favourite song is Gorillaz - Clint Eastwood. I ... More »
More by Skreetsha:A-600 "Low Ridah" ChopperStuart W.R. V4.0The Sipriani Rifle V3.0 (FT210)
Add instructable to:
