3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
AFFORDABLE LASER LIGHT SHOW
Lasers are fun, but what else can they be used for? Laser light shows are one option. I've been to many concerts where laser shows are used. I've always wanted to have one of my own, but the good, pre-made setups commonly used in concerts are very expensive, usually in the hundreds or thousands of dollars. I decided that I'd try to build my own show as I'm not willing to shell out a huge amount of money for something that I may be able to make on my own.
So, I'll show you how I made my very own laser light show that will project either a really cool spider-webby hexagon effect or a crisp triangle effect using a few very common and cheap materials.
Here's a video of what the final results will look like:
Step 1Gather Parts
Gather Parts
You'll need the following
- about six feet of half-inch PVC pipe
- two dowel rods under a half-inch in diameter and about a foot and a half long
- a hack saw
- a ruler or yard-stick
- a sharpie marker
- duct tape
- hot glue gun
- six half-inch PVC T-joints
- one half-inch PVC 90 degree elbow
- one half-inch PVC end-cap
  and
- triangular flood lamp bulb (mine is a Philips Halogen Flood light 75 W 120 V)
- a reflective lens - I got mine from a light-up key chain
- a laser pointer that is around a half inch in diameter, any color will work (The laser I used has a button which is pushed in when the   laser is put in the pipe, conveniently turning on the laser)
13 comments
Sep 26, 2011. 6:28 AMdlemke says:
Out of all the components I have scavenged from old electronic junk I have, like old printers, there is always small DC motors left that should do the trick with battery power or simply use an old power supply. That should do it to turn the disk, but I wonder, if you could use a bigger laser? I know safety would be an issue here, but it could make for a cool basement project.
Dan
Jun 1, 2011. 9:22 AMtinker234 says:
wow this is cool
Apr 12, 2011. 11:59 PMsabladask says:
cool!
you should add a motot insted of the drill :)
Apr 15, 2011. 7:08 AMcfirestone says:
I would suggest using a small motor from something like, the plant turner device you see online? it is a small 6 volt motor that turns slowly. the drill you'd have to sit and hold the trigger, right?
Apr 14, 2011. 7:02 PMdacker says:
A college roommate in the late 70s had a simpler method which automatically synched with music.
He glued a small mirror onto a speaker which in turn was attached to a music source. Aim a stationary laser at the mirror and crank-up the tunes. He used a salvaged 8" or 10" woofer and may have left the crossover in the circuit so only the bass notes went to the speaker, generating a lissajous pattern or something similar on the wall or ceiling. I honestly don't really remember how well it worked.
Lasers were not something individuals owned back then as they were big (perhaps 10"x10"x20") and expensive so all he could do was set it up in a physics lab one time. Now you can have the same thing on a keychain for $5 and it's a toy for a cat.
Apr 15, 2011. 7:09 AMcfirestone says:
LOVE the speaker jiggles the laser idea....
Apr 15, 2011. 2:43 PMrcisneros says:
You might consider a cordless screw driver. A little more portable and easier to power.
Apr 14, 2011. 12:37 PMAdamVanMeter says:
Awesome! I'm going to put something like this together for light effects come halloween. Excellent instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:The Porsche Fan
