loading
loading
Picture of AIR POWERED BB GUN
THIS IS ALL ABOUT A AIR GUN FROM A POP BOTTLE
I TAKE NO RESPONSIBILITY WITH WHAT YOU DO WITH THIS
Step 1: THINGS YOU NEED
Picture of THINGS YOU NEED
YOU NEED:
*PVC PIPE
*ARALDITE RESIN
*CORNER PIECE OF PVC
*DUCT TAPE
*SHUT OFF VALVE
*THIN PIPE
*BOTTLE WITH TOP
*VALVE FROM A BIKE TIRE
*SLECTION OF DRILL BITS
*BIKE PUMP
Step 2: MAKING IT
Picture of MAKING IT
FIRST WRAP THE HOLE BOTTLE WITH DUCT TAPE TO REINFORCE IT
THEN DRILL A HOLE IN THE SIDE OF THE BOTTLE SO YOU CAN FIT A TIRE VALVE IN IT
PUT THE TIRE VALVE INTO THE HOLE WITH THE THREAD FACING OUTWARDS
SEAL THE HOLE WITH A LOT OF RESIN
THAT IS THE BOTTLE DONE
Step 3: THE PIPE
Picture of THE PIPE
GET A CORNER PIECE OF PVC AND ATTACH A PIEC OF PVC ABOUT HALF A FOOT LONG AND GLUE IT TOGETHER WITH RESIN
AT THE END OF THE PVC PIPE ATTACH A SHUT OFF VALVE TO THE PVC AND SEAL IT WITH RESIN
AT THE OTHER SIDE OF THE SHUT OFF VALVE ATTACH ANOTHER PIECE OF PVC TIT AND GLUE
THEN PUT THE THIN TUBE TO THE END OF THE PVC AND GLUE
GLUE THE CORNER PIECE TO THE END OF THE BOOTLE TOP BY DRILLING A HOLE IN THE TOP OF THE BOTTLE AND GLUE THE TOP TO THE BOTTLE
Step 4: HOW TO FIRE
TO FIRE YOU HAVE TO CHECK THE SHUT OFF VALVE IS CLOSED AND PUT A BIKE PUMP TO THE BIKE VALVE AND INFLATE TO 50 PSI BUT NOT MUCH MORE SINCE THE PRESSURE COULD BUILD UP TOO MUCH AND EXPLODE
WHEN YOU HAVE PUMPED IT UP TO THE CORRECT PRESSURE PUT WHATEVER AMMO WILL FIT IN THE THIN TUBE SUCH AS:
*BB'S
*WET TISSUE
*PELLETS
AND ANYTHING ELSE YOU CAN THINK OF
THEN LOAD IN YOUR AMMO AND OPEN THE VALVE FULLY AND IT WILL FIRE
THIS IS A HORRIBLE INSTRUCTABLE TURN CAPS LOCK OFF NOW!!! Ahhh, That's better. it's a horrible 'ible. Goodbye!
use a 2ltr Coke bottle and strenthen it (ible coming soon) And pump it up to 100 - 125 psi !
sharlston (author)  stephenniall5 years ago
i use a small butane gas thing for my stove now
Oh cool . I modified a airgun with 3 2ltr cola bottles holding about 125 psi each with a compressor in a backpack to hold bb bullets its not exactly safe holding 375 psi on your back But its alot more powerful than a normal bb gun
wrap duct tape round it so if it explodes it wont be as bad
Ive strengthened it using my methods i was Saying earlier (ible coming lol) and then wrapped Duct tape around then its got a load of memory foam i had left over it stops the bottles Jinglinh and isnt as much stress on my back So it should be ok !
I would not use capitals the whole instructable.
sharlston (author)  imthatguy11255 years ago
i cant be bothered to edit it now
Very Cool.
sharlston (author) 6 years ago
i made this and it shot 100 foot witha metal bb and 74 foot with a plastic bb
