3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
AKAI LCT2715 Power Supply Removal
How to disassemble your AKAI LCT2715 to access the Power Supply
Step 1
You are going to need a Phillips ( X ) Screwdriver for this proceedure.
The first thing you will want to do is find a suitable location to disassemble the TV. Try to find somewhere with plenty of space to work and preferably somewhere you will not have any hazards such as static (like carpet)
Lay the TV Flat on its face (picture side down) and remove the 4 screws from the back of the TV holding the base on.
Next you will want to process to remove the screws around the back cover. There are 12 screws you will need to remove (refer to picture for locations).
Carfully remove the back panel of the TV. It may snag on the coaxial connector so be careful.
28 comments
Dec 10, 2011. 9:16 AMJacksonville says:
Vernon, I have an AKAI PDP50006H that needs to have the power supply repaired. Are you able to repair this model as well? If so, can you email me with information on how I can mail the part to you and approximately what the cost will be? Thank you
Feb 14, 2010. 5:11 AMWest Guy says:
Vernon, I sent you my power supply for the AKAI months ago prior to your move. You promised to quickly let me know right after that...I am very concerned you have forgotten me.
Please let me know where we stand with this.
Thanks. Al
Feb 25, 2011. 12:52 PMjermaljermetrax says:
Hey, could i send in my power supply for you to repair it?
Mar 29, 2010. 5:05 AMWest Guy says:
Vernon, it's been a month since you said you were checking to see what you have done with my power supply. Overall it has been since Nov. with no return. This is not a resonable time frame in spite of your move. Please return my power supply so that I can send it elsewhere. You promised a turn around in a brief time initially. I need to know what the deal is here pronto.
Nov 15, 2010. 1:55 PMantonio08 says:
I have a Akai LCT2701TD with a bad PSU. Could you give me a cost on repairing this unit? My e-mail ; antontyberman@yahoo.com
Jul 22, 2010. 3:12 PMonemanarmy41 says:
hey your instructions are a1 and simple to follow , now if you could help me with my power supply that would be tops, thanks
Oct 26, 2009. 11:46 AMstaminaboy says:
Great instructions! I got my Akai LCD2715 as a hand me down with the condition of "fix it and it's yours."  Twisted's instructions had my set up and running in less than a day for less than $30 (most of which went toward a new soldering iron).  Thanks much!
Feb 10, 2009. 10:23 PMkrishnalc says:
I have an Akai LCD2717 that did not work for about a year. I tried to get estimates to fix it but was getting estimates of $400 to $500 dollars. When I found this site I thought I would give it a try to see if the power supply was in fact the problem with the TV. I followed these instructions which were very detailed (they did not miss a single screw), and was able to have the power supply out in about 15 minutes. The board looked like it was described with the power supply capacitor array on the power output side have become bulged and are starting to leak like described in the step 3. I contacted Twizted to get the details about having the power supply repaired. He got back to me very quickly. He repaired the power supply the same day he received it and shipped it back to me the next day. The TV has worked perfectly since I put it back in. The entire process was efficient, fast and professional. I would recommend Twizted services to anyone!
Thank you for everything!
Aug 3, 2009. 1:46 PMtraceta says:
how do you get in touch with twizted
Apr 14, 2009. 11:53 AMcliff.jacobs says:
Hi Twizted; Same problem with a LCT3201AD and need to rebuild the E7802-005008 supply. I can do it myself but thought you might want to sell a repair kit with the caps. Will that work?
May 31, 2009. 11:49 AMcliff.jacobs says:
The TV finally would not turn on so I popped out the power supply. Not the same one as in this post but had similar bulging caps. Replaced 3; 1000pf caps with a bit higher working voltage and the thing works like new. Thanks for the tip.
Jul 31, 2009. 11:58 AMaleisen says:
Hi I'am a TV repairman and I am working on a AKAI LCT301TD TV that has a defective MEGMEET MLT186 power supply. No 12v or 24v only 5v. I read on the internet on many such failures of this board . AKAI is of no help as well as their service manual. Does anyone know what goes bad in these power supplys, common troubles etc ? Thanks Al
Jul 12, 2009. 1:21 PMmarkg123 says:
i have a 32' Magnavox that i need to change the power supply on, can i just use a power supply from a 24" tv or do i need to order a specific power supply? thanks for any info!
Jul 15, 2009. 8:17 AMcmsursa says:
I have taken my power supply out . Please send me your address and I will send the power supply to you for repair. Do you require a money order and how much is it for? Thanks, Chris
Jul 3, 2009. 6:48 AMTheoden says:
Please send me an email address or contact situation so that I can see about getting my power supply repaired. Thanks.
Jun 30, 2009. 8:26 AMjgoodbar says:
Hey there, I have a buddy that is giving me this TV because it doesnt work and he said it was the PSU. What do I need to do once I get it removed so I can get it to you.
Apr 2, 2009. 7:26 PMBrucered says:
I know this is a little off the subject but I also have an Akai Model# LCT3285TA that has power supply problems as well. Can you repair this power supply on this one as well? If so how much? Any help would be greatly appreciated! Thanks!
Mar 17, 2009. 4:02 PMleviludwig says:
Hi, I work at a bowling center and we have two akai lct2715 tv's with the same problem. One of them has 14 bulged or leaking capacitors and the other we haven't taken apart yet.. How can I get in contact with you to send the power supplies to you?
Mar 15, 2009. 4:07 AMPar4 says:
My Akai LCT2715 television gave a sizzling sound before it went out. Now it flashes a red light and the screen does not power up. I did some research to find out how many other has the same problem. I took this TV to be repaired to many places and I was told they are unable to physically fix or repair it. It seems no one does repair anymore. One person offer to buy the part on E-bay for $388.00, he will install it and charge me labor plus the cost of the part. Another person said he will send it to the manufacture to be fixed and maybe the part will be cover under a warranty. I don't think the manufacture cares about this product/part anymore, they went bankrupt.
While browsing the web I stumble upon “Twizted”, I read the instruction on removing the power supply. It is very simply, detailed and straight forward. I am not a technical person, but his instruction made me feel like one. I had the part out within 10 minutes.
I contacted Twizted and he gave me instruction on how to send it to him and within 1 week, the part was back and installed. The television works excellent. I am very glad I took this chance and put my trust in Twizted. I will recommend everyone whom is having this problem, to stop shopping around for a good repair deal and put your trust in Twizted. He did the job for us and at a fair price. He not only fixes the TV, he put the smiles back on my kid’s faces. They now have their TV again.
Thank you Twizted, Dude You Rock!
Feb 14, 2009. 12:22 PMmainebear2 says:
I was having power supply issues with my Akai LCD2717. Twizted was a great resource and support. He got it up and working for me. Thank you very much
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:Twizted
