Introduction: AL Light Weight, Finger Skate Board
Aluminum Finger Skate board
Step 1: What You Will Need
You will a need techdeck to drill the holes into the Aluminum, a screwdriver, shock absorber and 8 screws***. Also you need a drill or drillpress with a 1/16 drill bit. A pair of good sizers is needed to cut the shape.
I got an Aluminum drier vent duct connector for $2 at homedepot.
Every thing in the picture is optional, if you want to put trucks on it.
I have tried using soda cans, but it is too thin. You could Epoxy several layers though.
Step 2: Making the Board
Trace the shape of the Tech Deckon to the Aluminum, cut around the shape. Then tape the Aluminum deck to the real Tech Deck and drill through the 8 holes and into the Aluminum deck.
!!!!!!!Bend the sides and ends!!!!!!!!!!!!! screw the shock absorbers and trucks and your all done.
Be warned
do not handle the board too rough because it could bend
the bent edges give it strengh
Pocket-Sized
