Salient Features
- Simple to make yet can beat many of its counterparts
- Combines at least three spirit levels i.e. horizontal, vertical and 45°, in one
- 360° level i.e. works in all directions
- Accurate and precise
- Inclinometer
- Economic
Highly custimizable
- Sensitivity of spirit level
- Properties of spirit level liquid like colour, surface tension and viscosity are customizable
- Shape of outer body
- Bubble size
- Mountable
This spirit level was not originally inspired from amoeba. Rather name was kept because it suits the spirit level. Amoeba can assume any shape. It is a cell consisting of different parts with cell membrane, cytoplasm and vacuole being the relevant ones. These features of amoeba can be found in this spirit level as follows:
- Cell membrane corresponds to the body of spirit level
- Cytoplasm corresponds to the spirit or the liquid used in spirit level
- Vacuole corresponds to the bubble of the spirit level
- The capability of amoeba assuming any shape corresponds to the level of customization this spirit level can achieve
- What is the principle of working of a spirit level?
- How to calibrate or check a spirit level?
What are the desirable properties of the liquid filled in the spirit level? For instance,
- It should not wet the surface of the tube
- It should be easily visible
- What should be the size of air bubble?
One more point. This spirit level has the spirit of spirit level and not the spirit as liquid! That's why this can be called as spirit level even when there is no spirit in it.
Remove these ads by
Signing UpStep 1: MATERIALS REQUIRED
- Saw
- Cutter
- Syringe
- Glue stick
- Drill press
- Wax polish
- Common salt
- Black gel pen
- Instant adhesive
- Sand paper (#540)
- Glycerine (optional)
- 3mm transparent acrylic sheet
- Water (preferably distilled water)
- 3 geometrical shapes, triangle, circle and octagon
- Tri-square (this is required for all right angles and straight edges)
- 32mm hole cutting saw (other diameters as per requirements can be used)
- Highlighter (green colour recommended; yellow for exact colour; sketch pen may also be used but it will not glow in UV)
Captain Vyom (author) says:
Mar 17, 2013. 1:09 PMReply
audreyobscura says:
Mar 15, 2013. 11:57 AMReply
Not Nice
Visit Our Store »
Go Pro Today »
