Introduction: Annas Cape From Frozen Diy Disney
Picture of  Annas Cape From Frozen Diy Disney
Hello!
here is how to sew a cape from frozen!! Pls forgive the crudity of my examples, i had already made it when i decided to publish it on instructables, it is more guesstimating then a pattern, think of it as custom tailoring ;)
Step 1:
Picture of
What youll need:
scissors
sewing machine
button
2 yards of fleece
2 yards of pink fabric
Top cape: you want to measure it out from your shoulder toshoulder and add about 5-10 inches depending on how long u want it
then make a big circle from where you drew you r measurements, all the way around like a circle, then cut it out,
now draw an inner circle,estimate smaller when you draw a circle to fit your head, start at a circle that is 4x4 inches, and work your way up . you can always cut bigger, not smaller then slip it over your head to see if it fits,
cut a line through the fabric to cut the head hole. cut out the head hole. Example in next picture
Step 2:
Picture of
cut the headhole. think of it as looking at a doughnut with a slit in the front part. then cut around the measured edges.
Step 3:
Picture of
repeat the same step following the pattern of the warm inter facing
Step 4:
Picture of
now you sew the two together: make sure u use pins otherwise it could end up crooked.
Step 5:
Picture of
once youve sewn them together, add a slit in either side of the front, then add a button on the other side then enjoy!! if u want you can add a long bottom cape to look exactally like hers, but other wise it goes both ways for disney frozen, and a regular cape
horseygal2014 (author)2014-01-05
thanks! It only takes like ten minutes! There is no pattern for sale anywhere too..
My sister would love this!
About This Instructable
12,492views
10favorites
License:
Bio: 13 years
More by horseygal2014:Zipper fix with rubber band!DIY Starbucks Frappachino VanillaDIY no sew bowtie!
Add instructable to:
