3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
ANTAGONISTIC BOOKS: Curiosity - How To make a book that can only be opened once
  • last photo ←
This is an instructable on how to make the second book in my Antagonistic Books set (the one that can only be opened once). This one is pretty easy (although it requires basic knowledge of welding). Besides that, theres only one hiccup that can happen, and I'll cover that.
Step 1Materials
You'll need:
Two metal plates cut to the same size.
A Bi-Directional Ratchet
A place to weld
Pages to put inside your book
Rubber Cement
(potentially you may also need a wrench and a needle or awl)
107 comments
1-40 of 107next »
Dec 17, 2009. 7:00 PM77Kapn Krunch77 says:
How about you put a lock on the book, read it, then throw away the key.
Dec 30, 2009. 7:46 PMWarlrosity says:
You cut around the cardboard of the cover...
Dec 31, 2009. 2:46 PM77Kapn Krunch77 says:
Huh
Jan 14, 2010. 2:39 AMWarlrosity says:
Huh? HUH!?!?! You cut around the peice of cover which the lovk is fastened to
Mar 15, 2010. 1:06 AMbiboNL says:
well, "you cut around the cardboard of the cover" isn't the best way to explain that you can just remove the lock by cutting it out.
I understand the huh, and I understand your reaction, but saying "huh" 2  more times was a completely unnecessary way to amplify Kapn Krunch's stupidity.
Actually, it kind of made you look stupid at the same time.
Mar 28, 2010. 9:24 PM77Kapn Krunch77 says:
Shut up! I know I'm stoopy but i believe that rubbing it someones face is not always the best way to solve problems. You see you are acting rather immature by saying that I'm stupid, and i highly suggest trying to have at least some manners thank you.
Mar 24, 2010. 1:16 AMWarlrosity says:
Thats a bit harsh
Mar 28, 2010. 9:14 PM77Kapn Krunch77 says:
lol it is
Mar 29, 2010. 2:40 PMbiboNL says:
sorry, was kind of grumpy at that comment, saw something that could be flamed and did.
Nov 17, 2010. 10:31 AMTekoMuto says:
huh
Dec 17, 2009. 1:22 PMsabbott says:
I love the art element here, and thank you for providing the explanation about your class.
This also made me think of the books in the Harry Potter series that don't behve like ordinary books. e.g. a book that chases you around the room and tries to bit you cannot be digitized either!
Dec 24, 2009. 11:59 AMpolyspace says:
Actually, you could make an ebook with a virus in it - that would bite you!  On a related note, how about an ebook, say the Iliad or Rikki-Tikki-Tavi, that reads your address book and mails itself to everyone you know.  Kind of like an educational virus... or something.
Jan 24, 2010. 9:53 PMO_Kodama says:
Polyspace, you WIN the game.
Dec 31, 2009. 12:46 PMmettaurlover says:
Any more 'ibles in this series coming soon? Can't wait to see what happens next...
Dec 17, 2009. 10:54 AMblakelock says:
actually, i thought it was ~nearly a very useful thing.  at first, i thought it would open once then close, then never open again.  this would be useful for passing information only once, then have the message essentially self-destruct.
Dec 24, 2009. 10:41 AMgrundisimo says:
He should make a sequel to this instructable on how to make a book that only closes once.
Dec 17, 2009. 4:43 AMStephen D. Alverez says:
 What kind of welder are you using? That weld looks very weak, and if it's an ARC welder, than thats understandable
Dec 17, 2009. 5:56 AMzer0vector says:
Not to be rude, but are you implying ARC welding is inherently weak?  I'd say not much aside from skilled TIG would look good in this situation.  He's trying to weld light gauge sheet to hardened tool steel, definitely not a prescription for an easy weld.
Dec 20, 2009. 11:01 AMStephen D. Alverez says:
No, I meant that the kind of welds ARC and TIG/MIG make are very different, and that if it was TIG/MIG, it could be weak, but ARC's welds are different.
Dec 20, 2009. 12:11 PMBig Bear says:
Welds are weak only from a skill standpoint not from the type of welding being done. MIG can not be weak when that is what is used to assemble a NASCAR.
Dec 18, 2009. 12:01 PMelleadnih says:
sooooo just to be sure this book once open it stays that way? or once close it stays close for ever?, and is there a way to revert the process?
Dec 18, 2009. 2:37 PMberky93 says:
you could re-close and reset it by cutting the weld on the switch so you can change the ratchet to go the other direction...
Dec 18, 2009. 8:06 AMdesertdog says:
Interesting.  Seems a waste to use a Craftsman ratchet though.  You can often find a cheap, functional China tool at the dollar store
Dec 18, 2009. 7:02 AMangelicdevil says:
for the some of you that DO NOT UNDERSTAND THIS.... this is meant to keep the book OPEN as in once its open, you cannot close it. hence you would be able to tell if someone was reading your books since it would be permanently open XD
Dec 16, 2009. 5:02 AMpaulzef says:
(removed by author or community request)
Dec 18, 2009. 4:55 AMMaggithaMay says:
It's useful as a prank, silly!
Dec 17, 2009. 6:27 PMcttvnerd says:
 Because you can! Kinda like climbing a mountain.
Dec 17, 2009. 3:29 PMtristantech says:
It may be useless, but think of all the things you could apply a similar mechanism to
Dec 17, 2009. 1:33 PMWhiternoise says:
Perhaps if you want to play at being a spy? ;)
Dec 17, 2009. 6:55 AMCreamaster says:
 Things of this nature generally fall in to the category of Art.
Dec 17, 2009. 8:57 AMtaiphoon says:
Not everything on instructables is useful.  Sometimes they're supposed to make you think, guys.  Seriously, some people just don't get it.
Dec 17, 2009. 9:48 AMCreamaster says:
 aka: Art.
Dec 17, 2009. 10:23 AMtaiphoon says:
 For sure.  Btw, I was agreeing with you.
Dec 17, 2009. 11:09 AMCreamaster says:
 Oh yeah, I know. It's just this thing where I like to have the last word. See, I did it again... maybe
Dec 17, 2009. 11:57 AMMaXoR says:
Immature juvenile tenancies make me laugh!
Dec 17, 2009. 1:29 PMyeah i know says:
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH
AHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
AHAHAHAHAHAHAHA
Dec 18, 2009. 8:14 AMgrundisimo says:
I win now.
Dec 19, 2009. 1:10 PMkhearn says:
 Yup, you win.
Dec 20, 2009. 11:43 AMgrundisimo says:
nope i do
1-40 of 107next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:stfj
