Remove these ads by
Signing UpStep 1Laser Cut the cover and mechanism out of masonite.
Laser Cutter
3 Staples
Spring (Clicky-pen springs work great)
Nut, Bolt, and Washer
Length of String
A whole lot of newsprint for the pages.
Spray Fixatif
Magicians Flashpaper
Fireplace Matches (The brand I picked in the photo is the best of the ones I have tried)
Binding thread / needle
Exacto Knife
Duct Tape.
Breathable Cloth book cover
Download the File that I've attached and modify it as you need to for whatever type of laser-cutter you have. Basically you want to cut out all of these pieces from masonite. Masonite is a good choice because it's cheap, solid, and it burns up. You should note that if the staples you have are not the same width as the holes in my diagram or the tracks on the match slider you'll need to adjust the plans.
match_rigBookd2.pdf(2592x1728) 204 KB| « Previous Step | Download PDFView All Steps | Next Step » |
I thought about using electric ignition since that would be nicer, but I wanted to have a piece that burned entirely, and was worried about having batteries in a fire.
Also digging your ratchet book, BTW. Can't wait to see what's next.
anyway, thanks for the compliments!
(My books are only antagonistic before they're published... well, some are antagonistic after, but at that point, it's the reader's problem, isn't it? :) )
He'll probably put your picture on his mantle of something.
And you would deserve it, too; your Antagonistic Book series is too effing awesome!!
Just kidding. Very cool ideas, cleverly thought through.
I have no idea wheather or not you could get a really thin PTFE bag though. or you could get the Sulphuric acid or Potassium permanganate to make it XD
