Introduction: ARDUINO AIRSOFT TIME BOMB GAME
Picture of ARDUINO AIRSOFT TIME BOMB GAME
Take a look at the video to see it at work.
Check the next steps for the Schematic and code.
Step 1: The Schematic and Parts List.
Picture of The Schematic and Parts List.
Just connect it as the schematic shows. Upload the code and it should work.
I added a on/off switch a reset button and a power jack, those are not
shown on the schematic but easy to add.
To add a reset button just add a button to the reset pin, put one wire in the
reset pin and one in ground.
You can also add extra buttons for C and D as shown on the schematic.
My final project will have a red button for the red team and green for green team.
Parts list.
  1. Arduino UNO
  2. Potentiometer (+ knob optional)
  3. buzzer
  4. On/Off switch
  5. 1 Channel relay
  6. lcd 1602 - Blue Backlight
  7. 4x4 Keypad
  8. 2x Red leds, 1x green led.
  9. 2x 220 Ohm (220 R) resistors
  10. A set of MM FF MF Jumper wires
  11. Female Power jack & adapter (optional) (You can also add batterys of course)
  12. 2 buttons for C & D(optional)
  13. 1 button for reset (optional)
  14. Alarm Strobe? Alarm Sound?
(i used male and female audio plugs to connect the lamp)
Step 2: The Code.
Picture of The Code.
There are multiple codes inside.
Open and upload the Time_Bomb_Airsoft_Game.ino
If you connected everything the right way it should work right away.
Be creative! make a nice enclosure for it.
Good luck!
StrangeBeacons (author)2017-12-15
Does anyone have a "How To" guide on playing this game? I'm looking for a step-by-step guide on how to play all three games after the project is assembled and the code is uploaded. I have completed all of that and would really like some help on how to actually use it. Thank you.
EmanueleM6 made it! (author)2016-04-18
Here is my modified code for the time bomb there is one skretch for control the battery status in NOT CHECKED and I don't now if does it work.
There is a modified code for work whith 4x3 keypad.
USAGE:
2 UP, 4 RIGHT, 8 DOWN, 3 LEFT, * CANCEL, # CONFIRM.
I have complete traslate the program to change the frase just modificated the skreck named alang for better work you have to change the position of cursor of the LCD screen.
PS sorry for my bad english
WagnerR12 (author)EmanueleM62017-10-25
can you share your code here?
magno_23 (author)EmanueleM62017-07-09
how do you get into the second menu?
LordKaos (author)magno_232017-10-08
Hi!
Change line 30 in menu.ino file.
to: if(var == BT_DOWN && i<3){
That shows the config menu, but some code is missing. The test relay works fine. :D
EmanueleM6 made it! (author)EmanueleM62016-04-20
This is the best version I made for international players for me is the best and build plug and play if you want to traslate in your language just to cancel the italian phrases in your language and and it's all.
XikoM1 (author)EmanueleM62017-02-16
why when i try to send to arduino gave an error " 'menuPrincipal' was not declared in this scope"
you can help me?
DardoG (author)XikoM12017-06-23
same problem here menuPrincipal not declared. I'm new to the arduino platform electronics is no problem but I need to solve the menu problem please help
vandenbrande (author)EmanueleM62016-04-20
Thank you! I will update mine soon to. I added some more stuff.
Zaudio (author)EmanueleM62016-08-17
looks great!
If i connect everything and upload the sketch and try to use a button for the menu the LCD display gets weird and shows random?! characters.
Any idea to fix this?! thanks!
amurillo3 (author)Zaudio2016-08-22
Hi Zaudio, the same thing happen to me, I had to flash the code to the arduino a couple of times and that was it, I did check the cables 1st and it was working ok, but after a while it started to show random characters... after the flashing it stop...
vandenbrande (author)Zaudio2016-08-17
Just try again, and check your wiring. Probably did something wrong
Zaudio (author)vandenbrande2016-08-18
already tried, even with only the LCD keypad shield and keypad it goes crazy
Zaudio (author)Zaudio2016-08-17
Also tried the other one you made (Time bomb TRASALATE.zip)
We can work together on this project to. Your in italy right? you can help me with some parts that i need from italy.
EmanueleM6 (author)vandenbrande2016-04-20
Yes what do you need ?
vandenbrande (author)EmanueleM62016-05-17
Sorry for the late reaction, I need the gun case i used for my project they are perfect, they come from italy. They are being sold with bruni alarm pistols, those pistols are being made in italy and the cases are made by negrini. But I only need the cases.
EmanueleM6 (author)vandenbrande2016-05-26
What do you need specifically
Replicas will do to. No problem. Best blank with no logo. or brand name.
vandenbrande (author)EmanueleM62016-04-18
Cool thanks
WagnerR12 (author)2017-10-25
nobody can share a code that works?
АртёмС13 (author)2017-05-15
Hello. I can not understand why it does not work on arduino pro mini? On arduino uno everything works well. On the LCD screen, it is found to serch&destroy, but keyboard input is not possible. I've tried everything to fix it, but it does not work out. Please write to my email address nanofaradc@list.ru
ViktorB19 (author)АртёмС132017-05-17
Артем,используй обычную плату Ардуино. Все прекрасно работает( правда у меня 2 кнопки подключеные к клавиатуре не работают ).Все остальные режимы показывают отличные результаты.
АртёмС13 (author)ViktorB192017-05-25
Я то ведь хотел компактным сделать, заказал 3 ардуинки про мини, думал сделаю все норм будет, в итоге не фига не работает. Главное на ЖК дисплее все норм высвечивается, а управление с клавиатуры не работает((( https://www.youtube.com/watch?v=zk9jqAJWMQs&t=1s
ViktorB19 (author)АртёмС132017-10-19
Насколько компактным? В любом случае и сама плата и блок с батареями займет место.
Проект и сама схема вполне себе рабочая. Подтверждаю.
profya (author)2017-10-08
hello , where in code i can setup the 14. alarm sound when game is ending ( for all scenario ) and how to plug light / alarm with relay to arduino d9 pins ?
thanks for repplying , best regards
GlaucoF1 (author)2017-06-19
Hello .. Good evening. I have a pump project for AIRFSOT and I looked at your project and I interceded for it, I do not know anything about programming, I downloaded your code and put it to run on Arduino and presented the errors below ... how can I solve this ... ?? ? Can you help me .... ????
Thank you ... !!!!!
time_bomb:196: error: variable or field 'keypadEvent' declared void
void keypadEvent(KeypadEvent key){
time_bomb:196: error: 'KeypadEvent' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\bomba_0_0.ino: In function 'void menuPrincipal()':
bomba_0_0:5: error: 'GREENLED' was not declared in this scope
digitalWrite(GREENLED, LOW);
bomba_0_0:6: error: 'REDLED' was not declared in this scope
digitalWrite(REDLED, LOW);
bomba_0_0:9: error: 'saStatus' was not declared in this scope
saStatus=false;
bomba_0_0:10: error: 'sdStatus' was not declared in this scope
sdStatus=false;
bomba_0_0:11: error: 'doStatus' was not declared in this scope
doStatus=false;
bomba_0_0:16: error: 'lcd' was not declared in this scope
lcd.print(menu1[i]);
bomba_0_0:16: error: 'menu1' was not declared in this scope
bomba_0_0:21: error: 'var' was not declared in this scope
var = keypad.waitForKey();
bomba_0_0:21: error: 'keypad' was not declared in this scope
bomba_0_0:22: error: 'BT_UP' was not declared in this scope
if(var == BT_UP && i>0){
bomba_0_0:23: error: 'tonepin' was not declared in this scope
tone(tonepin,2400,30);
bomba_0_0:30: error: 'BT_DOWN' was not declared in this scope
if(var == BT_DOWN && i<2){
bomba_0_0:31: error: 'tonepin' was not declared in this scope
bomba_0_0:39: error: 'BT_SEL' was not declared in this scope
if(var == BT_SEL){
bomba_0_0:40: error: 'tonepin' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\bomba_0_0.ino: In function 'void config()':
bomba_0_0:74: error: 'lcd' was not declared in this scope
lcd.clear();
bomba_0_0:79: error: 'menu2' was not declared in this scope
lcd.print(menu2[i]);
bomba_0_0:83: error: 'var' was not declared in this scope
var=keypad.waitForKey();
bomba_0_0:83: error: 'keypad' was not declared in this scope
bomba_0_0:84: error: 'BT_UP' was not declared in this scope
bomba_0_0:85: error: 'tonepin' was not declared in this scope
bomba_0_0:93: error: 'BT_DOWN' was not declared in this scope
bomba_0_0:94: error: 'tonepin' was not declared in this scope
bomba_0_0:101: error: 'BT_CANCEL' was not declared in this scope
if(var == BT_CANCEL){
bomba_0_0:102: error: 'tonepin' was not declared in this scope
bomba_0_0:105: error: 'BT_SEL' was not declared in this scope
if(var == BT_SEL){
bomba_0_0:106: error: 'tonepin' was not declared in this scope
bomba_0_0:121: error: 'RELAYPIN' was not declared in this scope
digitalWrite(RELAYPIN, HIGH); // turn the LED on (HIGH is the voltage level)
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\bomba_0_0.ino: In function 'void configQuickGame()':
bomba_0_0:139: error: 'sdStatus' was not declared in this scope
if(sdStatus || doStatus || saStatus){
bomba_0_0:139: error: 'doStatus' was not declared in this scope
bomba_0_0:139: error: 'saStatus' was not declared in this scope
bomba_0_0:142: error: 'lcd' was not declared in this scope
lcd.print(GAME_TIME);
bomba_0_0:142: error: 'GAME_TIME' was not declared in this scope
bomba_0_0:160: error: 'time' was not declared in this scope
time[i] = varu;
bomba_0_0:165: error: 'tonepin' was not declared in this scope
bomba_0_0:178: error: 'var' was not declared in this scope
bomba_0_0:178: error: 'keypad' was not declared in this scope
bomba_0_0:181: error: 'tonepin' was not declared in this scope
bomba_0_0:182: error: 'GAMEMINUTES' was not declared in this scope
GAMEMINUTES= ((time[0]*600)+(time[1]*60)+(time[2]*10)+(time[3]));
bomba_0_0:182: error: 'time' was not declared in this scope
bomba_0_0:187: error: 'tonepin' was not declared in this scope
bomba_0_0:191: error: 'tonepin' was not declared in this scope
bomba_0_0:195: error: 'sdStatus' was not declared in this scope
if(sdStatus || saStatus){
bomba_0_0:195: error: 'saStatus' was not declared in this scope
bomba_0_0:199: error: 'lcd' was not declared in this scope
lcd.print(BOMB_TIME);
bomba_0_0:199: error: 'BOMB_TIME' was not declared in this scope
bomba_0_0:202: error: 'ZERO_MINUTES' was not declared in this scope
lcd.print(ZERO_MINUTES);
bomba_0_0:210: error: 'time' was not declared in this scope
time[i] = varu;
bomba_0_0:212: error: 'tonepin' was not declared in this scope
bomba_0_0:224: error: 'var' was not declared in this scope
bomba_0_0:224: error: 'keypad' was not declared in this scope
bomba_0_0:227: error: 'tonepin' was not declared in this scope
bomba_0_0:228: error: 'BOMBMINUTES' was not declared in this scope
BOMBMINUTES= ((time[0]*10)+(time[1]));
bomba_0_0:228: error: 'time' was not declared in this scope
bomba_0_0:233: error: 'tonepin' was not declared in this scope
bomba_0_0:237: error: 'tonepin' was not declared in this scope
bomba_0_0:242: error: 'sdStatus' was not declared in this scope
bomba_0_0:242: error: 'doStatus' was not declared in this scope
bomba_0_0:242: error: 'saStatus' was not declared in this scope
bomba_0_0:246: error: 'lcd' was not declared in this scope
lcd.print(ARM_TIME);
bomba_0_0:246: error: 'ARM_TIME' was not declared in this scope
bomba_0_0:249: error: 'ZERO_SECS' was not declared in this scope
lcd.print(ZERO_SECS);
bomba_0_0:257: error: 'time' was not declared in this scope
time[i] = varu;
bomba_0_0:259: error: 'tonepin' was not declared in this scope
bomba_0_0:272: error: 'var' was not declared in this scope
bomba_0_0:272: error: 'keypad' was not declared in this scope
bomba_0_0:275: error: 'tonepin' was not declared in this scope
bomba_0_0:276: error: 'ACTIVATESECONDS' was not declared in this scope
ACTIVATESECONDS= ((time[0]*10)+(time[1]));
bomba_0_0:276: error: 'time' was not declared in this scope
bomba_0_0:281: error: 'tonepin' was not declared in this scope
bomba_0_0:285: error: 'tonepin' was not declared in this scope
bomba_0_0:289: error: 'sdStatus' was not declared in this scope
if(sdStatus || saStatus || doStatus){
bomba_0_0:289: error: 'saStatus' was not declared in this scope
bomba_0_0:289: error: 'doStatus' was not declared in this scope
bomba_0_0:291: error: 'lcd' was not declared in this scope
lcd.print(ENABLE_SOUND);
bomba_0_0:291: error: 'ENABLE_SOUND' was not declared in this scope
bomba_0_0:293: error: 'YES_OR_NOT' was not declared in this scope
lcd.print(YES_OR_NOT);
bomba_0_0:297: error: 'var' was not declared in this scope
bomba_0_0:297: error: 'keypad' was not declared in this scope
bomba_0_0:299: error: 'soundEnable' was not declared in this scope
soundEnable=true;
bomba_0_0:300: error: 'tonepin' was not declared in this scope
bomba_0_0:305: error: 'soundEnable' was not declared in this scope
soundEnable=false;
bomba_0_0:306: error: 'tonepin' was not declared in this scope
bomba_0_0:313: error: 'sdStatus' was not declared in this scope
bomba_0_0:313: error: 'saStatus' was not declared in this scope
bomba_0_0:315: error: 'lcd' was not declared in this scope
lcd.print(ENABLE_RELAYPIN);
bomba_0_0:315: error: 'ENABLE_RELAYPIN' was not declared in this scope
bomba_0_0:317: error: 'YES_OR_NOT' was not declared in this scope
bomba_0_0:320: error: 'var' was not declared in this scope
bomba_0_0:320: error: 'keypad' was not declared in this scope
bomba_0_0:322: error: 'relayEnable' was not declared in this scope
relayEnable=true;
bomba_0_0:323: error: 'tonepin' was not declared in this scope
bomba_0_0:327: error: 'relayEnable' was not declared in this scope
relayEnable=false;
bomba_0_0:328: error: 'tonepin' was not declared in this scope
bomba_0_0:334: error: 'sdStatus' was not declared in this scope
bomba_0_0:334: error: 'saStatus' was not declared in this scope
bomba_0_0:336: error: 'lcd' was not declared in this scope
lcd.print(ENABLE_CODE);
bomba_0_0:336: error: 'ENABLE_CODE' was not declared in this scope
bomba_0_0:338: error: 'YES_OR_NOT' was not declared in this scope
bomba_0_0:342: error: 'var' was not declared in this scope
bomba_0_0:342: error: 'keypad' was not declared in this scope
bomba_0_0:344: error: 'tonepin' was not declared in this scope
bomba_0_0:346: error: 'passwordEnable' was not declared in this scope
passwordEnable = true;
bomba_0_0:350: error: 'tonepin' was not declared in this scope
bomba_0_0:351: error: 'passwordEnable' was not declared in this scope
passwordEnable = false;
bomba_0_0:355: error: 'tonepin' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\domination.ino: In function 'void domination()':
domination:4: error: 'GAMEMINUTES' was not declared in this scope
int minutos = GAMEMINUTES-1;
domination:10: error: 'team' was not declared in this scope
team=0;
domination:11: error: 'iZoneTime' was not declared in this scope
iZoneTime=0;
domination:13: error: 'redTime' was not declared in this scope
redTime=0;
domination:14: error: 'greenTime' was not declared in this scope
greenTime=0;
domination:22: error: 'endGame' was not declared in this scope
if(endGame){
domination:26: error: 'keypad' was not declared in this scope
keypad.getKey();
domination:29: error: 'timeCalcVar' was not declared in this scope
timeCalcVar=(millis()- iTime)%1000;
domination:32: error: 'GREENLED' was not declared in this scope
if(team==1)digitalWrite(GREENLED, HIGH);
domination:33: error: 'REDLED' was not declared in this scope
if(team==2)digitalWrite(REDLED, HIGH);
domination:37: error: 'GREENLED' was not declared in this scope
if(team==1)digitalWrite(GREENLED, LOW);
domination:38: error: 'REDLED' was not declared in this scope
if(team==2)digitalWrite(REDLED, LOW);
domination:41: error: 'soundEnable' was not declared in this scope
if(timeCalcVar >= 0 && timeCalcVar <= 40 && soundEnable)tone(tonepin,activeTone,largoTono);
domination:41: error: 'tonepin' was not declared in this scope
domination:41: error: 'activeTone' was not declared in this scope
domination:43: error: 'soundEnable' was not declared in this scope
if(timeCalcVar >= 245 && timeCalcVar <= 255 && minutos-aTime/60000<2 && soundEnable)tone(tonepin,activeTone,largoTono);
domination:43: error: 'tonepin' was not declared in this scope
domination:43: error: 'activeTone' was not declared in this scope
domination:44: error: 'soundEnable' was not declared in this scope
if(timeCalcVar >= 495 && timeCalcVar <= 510 && minutos-aTime/60000<4 && soundEnable)tone(tonepin,activeTone,largoTono);
domination:44: error: 'tonepin' was not declared in this scope
domination:44: error: 'activeTone' was not declared in this scope
domination:45: error: 'soundEnable' was not declared in this scope
if(timeCalcVar >= 745 && timeCalcVar <= 760 && minutos-aTime/60000<2 && soundEnable)tone(tonepin,activeTone,largoTono);
domination:45: error: 'tonepin' was not declared in this scope
domination:45: error: 'activeTone' was not declared in this scope
domination:55: error: 'lcd' was not declared in this scope
lcd.setCursor(3,0);
domination:62: error: 'lcd' was not declared in this scope
lcd.setCursor(2,0);
domination:82: error: 'defusing' was not declared in this scope
while((defusing || cancelando) && team > 0)
domination:82: error: 'cancelando' was not declared in this scope
domination:85: error: 'lcd' was not declared in this scope
if(team>0)lcd.print("NEUTRALIZING...");
domination:86: error: 'lcd' was not declared in this scope
lcd.setCursor(0,1);
domination:94: error: 'endGame' was not declared in this scope
endGame = true;
domination:102: error: 'soundEnable' was not declared in this scope
if(soundEnable)tone(tonepin,alarmTone1,200);
domination:102: error: 'tonepin' was not declared in this scope
domination:102: error: 'alarmTone1' was not declared in this scope
domination:106: error: 'soundEnable' was not declared in this scope
if(soundEnable)tone(tonepin,alarmTone2,200);
domination:106: error: 'tonepin' was not declared in this scope
domination:106: error: 'alarmTone2' was not declared in this scope
domination:107: error: 'REDLED' was not declared in this scope
domination:111: error: 'ACTIVATESECONDS' was not declared in this scope
percent = (seconds)/(ACTIVATESECONDS*10);
domination:136: error: 'defusing' was not declared in this scope
while(defusing && team == 0 )
domination:139: error: 'lcd' was not declared in this scope
if(team==0)lcd.print(" CAPTURING ZONE");
domination:140: error: 'lcd' was not declared in this scope
lcd.setCursor(0,1);
domination:149: error: 'endGame' was not declared in this scope
endGame = true;
domination:155: error: 'REDLED' was not declared in this scope
domination:156: error: 'soundEnable' was not declared in this scope
domination:156: error: 'tonepin' was not declared in this scope
domination:156: error: 'alarmTone1' was not declared in this scope
domination:160: error: 'soundEnable' was not declared in this scope
domination:160: error: 'tonepin' was not declared in this scope
domination:160: error: 'alarmTone2' was not declared in this scope
domination:161: error: 'REDLED' was not declared in this scope
domination:165: error: 'ACTIVATESECONDS' was not declared in this scope
domination:170: error: 'GREENLED' was not declared in this scope
domination:178: error: 'REDLED' was not declared in this scope
domination:182: error: 'cancelando' was not declared in this scope
while(cancelando && team == 0 )
domination:185: error: 'lcd' was not declared in this scope
domination:186: error: 'lcd' was not declared in this scope
lcd.setCursor(0,1);
domination:195: error: 'endGame' was not declared in this scope
endGame = true;
domination:201: error: 'GREENLED' was not declared in this scope
domination:202: error: 'soundEnable' was not declared in this scope
domination:202: error: 'tonepin' was not declared in this scope
domination:202: error: 'alarmTone1' was not declared in this scope
domination:206: error: 'soundEnable' was not declared in this scope
domination:206: error: 'tonepin' was not declared in this scope
domination:206: error: 'alarmTone2' was not declared in this scope
domination:207: error: 'GREENLED' was not declared in this scope
domination:211: error: 'ACTIVATESECONDS' was not declared in this scope
domination:216: error: 'GREENLED' was not declared in this scope
domination:224: error: 'GREENLED' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\domination.ino: In function 'void gameOver()':
domination:231: error: 'team' was not declared in this scope
if(team==1)greenTime+=millis()-iZoneTime;
domination:231: error: 'greenTime' was not declared in this scope
domination:231: error: 'iZoneTime' was not declared in this scope
domination:232: error: 'team' was not declared in this scope
if(team==2)redTime+=millis()-iZoneTime;
domination:232: error: 'redTime' was not declared in this scope
domination:232: error: 'iZoneTime' was not declared in this scope
domination:233: error: 'GREENLED' was not declared in this scope
domination:234: error: 'REDLED' was not declared in this scope
domination:235: error: 'defusing' was not declared in this scope
while(!defusing){
domination:236: error: 'keypad' was not declared in this scope
keypad.getKey();
domination:241: error: 'lcd' was not declared in this scope
lcd.clear();
domination:247: error: 'greenTime' was not declared in this scope
if(greenTime>redTime){
domination:247: error: 'redTime' was not declared in this scope
domination:266: error: 'redTime' was not declared in this scope
printTimeDom(redTime,false);
domination:276: error: 'greenTime' was not declared in this scope
printTimeDom(greenTime,false);
domination:286: error: 'lcd' was not declared in this scope
lcd.print("Play Again?");
domination:291: error: 'var' was not declared in this scope
domination:291: error: 'keypad' was not declared in this scope
domination:293: error: 'tonepin' was not declared in this scope
domination:299: error: 'tonepin' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\key.ino: In function 'boolean comparePassword()':
key:5: error: 'codeInput' was not declared in this scope
if(codeInput[i]!=password[i])return false;
key:5: error: 'password' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\key.ino: In function 'void setCode()':
key:13: error: 'lcd' was not declared in this scope
lcd.setCursor(0, 1);
key:16: error: 'var' was not declared in this scope
var= getNumber();
key:18: error: 'codeInput' was not declared in this scope
codeInput[i] = var;
key:29: error: 'tonepin' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\key.ino: In function 'void setCodeTime()':
key:37: error: 'timeCalcVar' was not declared in this scope
timeCalcVar=millis();
key:41: error: 'ACTIVATESECONDS' was not declared in this scope
if(ACTIVATESECONDS*1000+timeCalcVar-millis()<=100){
key:42: error: 'codeInput' was not declared in this scope
codeInput[i]='x';
key:46: error: 'lcd' was not declared in this scope
lcd.setCursor(11,0);
key:47: error: 'ACTIVATESECONDS' was not declared in this scope
printTimeDom(ACTIVATESECONDS*1000+timeCalcVar-millis(),false);
key:49: error: 'var' was not declared in this scope
var= getNumber();
key:51: error: 'codeInput' was not declared in this scope
codeInput[i] = var;
key:62: error: 'tonepin' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\key.ino: In function 'void setPass()':
key:69: error: 'lcd' was not declared in this scope
key:73: error: 'var' was not declared in this scope
var= getNumber();
key:75: error: 'password' was not declared in this scope
password[i] = var;
key:85: error: 'tonepin' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\key.ino: In function 'void setNewPass()':
key:95: error: 'lcd' was not declared in this scope
lcd.clear();
key:118: error: 'soundEnable' was not declared in this scope
if(soundEnable)tone(tonepin,errorTone,200);
key:118: error: 'tonepin' was not declared in this scope
key:118: error: 'errorTone' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\key.ino: In function 'char getNumber()':
key:130: error: 'var' was not declared in this scope
var = keypad.getKey();
key:130: error: 'keypad' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\key.ino: In function 'byte getRealNumber()':
key:164: error: 'var' was not declared in this scope
key:164: error: 'keypad' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino: At global scope:
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:1:80: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* menu1[]={"Search&Destroy","Sabotage","Domination", "Configuration" };
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:2:79: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* menu2[]={"Game Config","Sound Config", "Relay Test", "Auto Test" };
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:3:19: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* GAME_TIME="Game Time:";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:4:19: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* BOMB_TIME="Bomb Time:";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:5:22: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* ZERO_MINUTES="00 minutes";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:6:18: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* ARM_TIME="Arm Time:";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:7:19: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* ZERO_SECS="00 seconds";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:8:22: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* ENABLE_SOUND="Enable Sound?";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:9:20: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* YES_OR_NOT="A : Yes B : No";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:10:25: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* ENABLE_RELAYPIN="Enable Relay?";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:11:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* ENABLE_CODE="Enable Code Arm?";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:12:23: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* GAME_TIME_TOP="GAME TIME";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:13:23: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* ARMING_BOMB = "ARMING BOMB";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:14:22: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* ENTER_CODE = "Enter Code";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:15:22: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* CODE_ERROR = "Code Error!";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:16:22: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* BOMB_ARMED = "BOMB ARMED";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:17:25: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* DETONATION_IN = "DETONATION IN";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:18:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* DISARMING = "DISARMING BOMB" ;
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:19:18: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* DISARM = "DISARMING";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:20:21: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* GAME_OVER = " GAME OVER! ";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:21:25: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* DEFENDERS_WIN = " DEFENDERS WIN ";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\lang.ino:22:24: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* SABOTAGE_FAIL= "SABOTAGE FAIL!";
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\sabotage.ino: In function 'void sabotage()':
sabotage:2: error: 'endGame' was not declared in this scope
endGame = false;
sabotage:3: error: 'refresh' was not declared in this scope
refresh = true;
sabotage:5: error: 'REDLED' was not declared in this scope
sabotage:6: error: 'GREENLED' was not declared in this scope
sabotage:8: error: 'GAMEMINUTES' was not declared in this scope
int minutos = GAMEMINUTES - 1;
sabotage:11: error: 'start' was not declared in this scope
if (start) {
sabotage:12: error: 'iTime' was not declared in this scope
iTime = millis(); // initialTime of the game, use this because sabotage mode goes can return to sabotage()
sabotage:25: error: 'timeCalcVar' was not declared in this scope
timeCalcVar = (millis() - iTime) % 1000;
sabotage:25: error: 'iTime' was not declared in this scope
sabotage:29: error: 'lcd' was not declared in this scope
lcd.setCursor(3, 0);
sabotage:44: error: 'keypad' was not declared in this scope
if ('d' == keypad.getKey() && passwordEnable) {
sabotage:44: error: 'passwordEnable' was not declared in this scope
sabotage:63: error: 'soundEnable' was not declared in this scope
if (soundEnable)tone(tonepin, errorTone, 200);
sabotage:63: error: 'tonepin' was not declared in this scope
sabotage:63: error: 'errorTone' was not declared in this scope
sabotage:69: error: 'defusing' was not declared in this scope
while (defusing && !passwordEnable)
sabotage:69: error: 'passwordEnable' was not declared in this scope
sabotage:71: error: 'keypad' was not declared in this scope
keypad.getKey();
sabotage:92: error: 'soundEnable' was not declared in this scope
if (soundEnable)tone(tonepin, alarmTone1, 200);
sabotage:92: error: 'tonepin' was not declared in this scope
sabotage:92: error: 'alarmTone1' was not declared in this scope
sabotage:96: error: 'soundEnable' was not declared in this scope
if (soundEnable)tone(tonepin, alarmTone2, 200);
sabotage:96: error: 'tonepin' was not declared in this scope
sabotage:96: error: 'alarmTone2' was not declared in this scope
sabotage:100: error: 'ACTIVATESECONDS' was not declared in this scope
percent = (seconds) / (ACTIVATESECONDS * 10);
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\sabotage.ino: In function 'void destroySabotage()':
sabotage:116: error: 'endGame' was not declared in this scope
endGame = false;
sabotage:117: error: 'lcd' was not declared in this scope
lcd.clear();
sabotage:121: error: 'BOMBMINUTES' was not declared in this scope
int minutos = BOMBMINUTES - 1;
sabotage:136: error: 'timeCalcVar' was not declared in this scope
sabotage:139: error: 'REDLED' was not declared in this scope
sabotage:140: error: 'soundEnable' was not declared in this scope
if (soundEnable)tone(tonepin, activeTone, largoTono);
sabotage:140: error: 'tonepin' was not declared in this scope
sabotage:140: error: 'activeTone' was not declared in this scope
sabotage:143: error: 'REDLED' was not declared in this scope
sabotage:149: error: 'soundEnable' was not declared in this scope
if (timeCalcVar >= 245 && timeCalcVar <= 255 && minutos - aTime / 60000 < 2 && soundEnable)tone(tonepin, activeTone, largoTono);
sabotage:149: error: 'tonepin' was not declared in this scope
sabotage:149: error: 'activeTone' was not declared in this scope
sabotage:150: error: 'soundEnable' was not declared in this scope
if (timeCalcVar >= 495 && timeCalcVar <= 510 && minutos - aTime / 60000 < 4 && soundEnable)tone(tonepin, activeTone, largoTono);
sabotage:150: error: 'tonepin' was not declared in this scope
sabotage:150: error: 'activeTone' was not declared in this scope
sabotage:151: error: 'soundEnable' was not declared in this scope
if (timeCalcVar >= 745 && timeCalcVar <= 760 && minutos - aTime / 60000 < 2 && soundEnable)tone(tonepin, activeTone, largoTono);
sabotage:151: error: 'tonepin' was not declared in this scope
sabotage:151: error: 'activeTone' was not declared in this scope
sabotage:174: error: 'keypad' was not declared in this scope
sabotage:174: error: 'passwordEnable' was not declared in this scope
sabotage:177: error: 'REDLED' was not declared in this scope
sabotage:178: error: 'GREENLED' was not declared in this scope
sabotage:196: error: 'soundEnable' was not declared in this scope
sabotage:196: error: 'tonepin' was not declared in this scope
sabotage:196: error: 'errorTone' was not declared in this scope
sabotage:201: error: 'defusing' was not declared in this scope
if (defusing && !passwordEnable) // disarming bomb
sabotage:201: error: 'passwordEnable' was not declared in this scope
sabotage:204: error: 'REDLED' was not declared in this scope
sabotage:212: error: 'keypad' was not declared in this scope
keypad.getKey();
sabotage:222: error: 'GREENLED' was not declared in this scope
sabotage:223: error: 'soundEnable' was not declared in this scope
sabotage:223: error: 'tonepin' was not declared in this scope
sabotage:223: error: 'alarmTone1' was not declared in this scope
sabotage:227: error: 'soundEnable' was not declared in this scope
sabotage:227: error: 'tonepin' was not declared in this scope
sabotage:227: error: 'alarmTone2' was not declared in this scope
sabotage:228: error: 'GREENLED' was not declared in this scope
sabotage:231: error: 'ACTIVATESECONDS' was not declared in this scope
percent = seconds / (ACTIVATESECONDS * 10);
sabotage:244: error: 'GREENLED' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\searchdestroy.ino: In function 'void search()':
searchdestroy:2: error: 'refresh' was not declared in this scope
refresh = true;
searchdestroy:4: error: 'REDLED' was not declared in this scope
searchdestroy:5: error: 'GREENLED' was not declared in this scope
searchdestroy:7: error: 'GAMEMINUTES' was not declared in this scope
searchdestroy:16: error: 'endGame' was not declared in this scope
if (endGame) {
searchdestroy:21: error: 'timeCalcVar' was not declared in this scope
searchdestroy:25: error: 'lcd' was not declared in this scope
searchdestroy:40: error: 'keypad' was not declared in this scope
searchdestroy:40: error: 'passwordEnable' was not declared in this scope
searchdestroy:57: error: 'soundEnable' was not declared in this scope
searchdestroy:57: error: 'tonepin' was not declared in this scope
searchdestroy:57: error: 'errorTone' was not declared in this scope
searchdestroy:62: error: 'defusing' was not declared in this scope
searchdestroy:62: error: 'passwordEnable' was not declared in this scope
searchdestroy:73: error: 'keypad' was not declared in this scope
keypad.getKey();
searchdestroy:74: error: 'ACTIVATESECONDS' was not declared in this scope
percent = (millis() - xTime) / (ACTIVATESECONDS * 10);
searchdestroy:81: error: 'endGame' was not declared in this scope
endGame = true;
searchdestroy:88: error: 'soundEnable' was not declared in this scope
searchdestroy:88: error: 'tonepin' was not declared in this scope
searchdestroy:88: error: 'alarmTone1' was not declared in this scope
searchdestroy:92: error: 'soundEnable' was not declared in this scope
searchdestroy:92: error: 'tonepin' was not declared in this scope
searchdestroy:92: error: 'alarmTone2' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\searchdestroy.ino: In function 'void destroy()':
searchdestroy:112: error: 'lcd' was not declared in this scope
lcd.clear();
searchdestroy:116: error: 'BOMBMINUTES' was not declared in this scope
searchdestroy:125: error: 'endGame' was not declared in this scope
if (endGame) {
searchdestroy:131: error: 'timeCalcVar' was not declared in this scope
searchdestroy:134: error: 'REDLED' was not declared in this scope
searchdestroy:135: error: 'soundEnable' was not declared in this scope
searchdestroy:135: error: 'tonepin' was not declared in this scope
searchdestroy:135: error: 'activeTone' was not declared in this scope
searchdestroy:138: error: 'REDLED' was not declared in this scope
searchdestroy:143: error: 'soundEnable' was not declared in this scope
searchdestroy:143: error: 'tonepin' was not declared in this scope
searchdestroy:143: error: 'activeTone' was not declared in this scope
searchdestroy:144: error: 'soundEnable' was not declared in this scope
searchdestroy:144: error: 'tonepin' was not declared in this scope
searchdestroy:144: error: 'activeTone' was not declared in this scope
searchdestroy:145: error: 'soundEnable' was not declared in this scope
searchdestroy:145: error: 'tonepin' was not declared in this scope
searchdestroy:145: error: 'activeTone' was not declared in this scope
searchdestroy:169: error: 'keypad' was not declared in this scope
searchdestroy:169: error: 'passwordEnable' was not declared in this scope
searchdestroy:190: error: 'soundEnable' was not declared in this scope
searchdestroy:190: error: 'tonepin' was not declared in this scope
searchdestroy:190: error: 'errorTone' was not declared in this scope
searchdestroy:195: error: 'defusing' was not declared in this scope
searchdestroy:195: error: 'passwordEnable' was not declared in this scope
searchdestroy:198: error: 'REDLED' was not declared in this scope
searchdestroy:206: error: 'keypad' was not declared in this scope
keypad.getKey();
searchdestroy:210: error: 'endGame' was not declared in this scope
endGame = true;
searchdestroy:215: error: 'GREENLED' was not declared in this scope
searchdestroy:216: error: 'soundEnable' was not declared in this scope
searchdestroy:216: error: 'tonepin' was not declared in this scope
searchdestroy:216: error: 'alarmTone1' was not declared in this scope
searchdestroy:220: error: 'soundEnable' was not declared in this scope
searchdestroy:220: error: 'tonepin' was not declared in this scope
searchdestroy:220: error: 'alarmTone2' was not declared in this scope
searchdestroy:221: error: 'GREENLED' was not declared in this scope
searchdestroy:224: error: 'ACTIVATESECONDS' was not declared in this scope
searchdestroy:231: error: 'GREENLED' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\splash.ino: In function 'void explodeSplash()':
splash:2: error: 'REDLED' was not declared in this scope
splash:3: error: 'GREENLED' was not declared in this scope
splash:6: error: 'endGame' was not declared in this scope
endGame = false;
splash:7: error: 'lcd' was not declared in this scope
lcd.setCursor(1,0);
splash:13: error: 'tonepin' was not declared in this scope
tone(tonepin,i);
splash:16: error: 'tonepin' was not declared in this scope
noTone(tonepin);
splash:17: error: 'relayEnable' was not declared in this scope
if(relayEnable){
splash:29: error: 'var' was not declared in this scope
splash:29: error: 'keypad' was not declared in this scope
splash:33: error: 'sdStatus' was not declared in this scope
if(sdStatus){
splash:37: error: 'saStatus' was not declared in this scope
if(saStatus){
splash:40: error: 'start' was not declared in this scope
start=true; //to set iTime to actual millis() :D
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\splash.ino: In function 'void failSplash()':
splash:53: error: 'REDLED' was not declared in this scope
splash:54: error: 'GREENLED' was not declared in this scope
splash:57: error: 'endGame' was not declared in this scope
endGame = false;
splash:58: error: 'lcd' was not declared in this scope
lcd.setCursor(1,0);
splash:64: error: 'tonepin' was not declared in this scope
tone(tonepin,i);
splash:67: error: 'tonepin' was not declared in this scope
noTone(tonepin);
splash:68: error: 'relayEnable' was not declared in this scope
if(relayEnable){
splash:80: error: 'var' was not declared in this scope
splash:80: error: 'keypad' was not declared in this scope
splash:84: error: 'sdStatus' was not declared in this scope
if(sdStatus){
splash:88: error: 'saStatus' was not declared in this scope
if(saStatus){
splash:91: error: 'start' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\splash.ino: In function 'void disarmedSplash()':
splash:104: error: 'endGame' was not declared in this scope
endGame = false;
splash:105: error: 'REDLED' was not declared in this scope
splash:106: error: 'GREENLED' was not declared in this scope
splash:107: error: 'sdStatus' was not declared in this scope
splash:107: error: 'saStatus' was not declared in this scope
splash:108: error: 'lcd' was not declared in this scope
lcd.clear();
splash:118: error: 'lcd' was not declared in this scope
lcd.clear();
splash:126: error: 'var' was not declared in this scope
splash:126: error: 'keypad' was not declared in this scope
splash:128: error: 'tonepin' was not declared in this scope
splash:130: error: 'sdStatus' was not declared in this scope
if(sdStatus){
splash:134: error: 'saStatus' was not declared in this scope
if(saStatus){
splash:137: error: 'start' was not declared in this scope
splash:142: error: 'tonepin' was not declared in this scope
C:\Users\glauc\Desktop\Arduino\Bomba teste\bomba_0_0\time_bomb.ino: In function 'void setup()':
time_bomb:108: error: 'keypadEvent' was not declared in this scope
keypad.addEventListener(keypadEvent);
exit status 1
Morten87 (author)2017-04-11
Hi guys
Im struggeling, i have managed to upload the code and i have wired everything correctly by using to drawings from 2 different makers, where they ar the same.
However, when i power on.. there is a tiny frequensy sound from the buzzer, both led blink one time fast, then both blink again and the red lights up constantly.
There are no digits or symbols on the lcd. I can adjust backlight brightness, but still no symbols.
Hope some can help me. Maybe go over it with me over Teamviewer?
My email is: lofte87@gmail.com
Have a nice day and a nice easter
Best regards
Morten from Norway
Morten87 (author)Morten872017-04-21
I fixed it. I would like the relay to be activated when a game is over. Now the relay trigger when the bomb goes off in Search&Destroy :/
Reason is that I can but a siren on when the game ends.
Pleeeeease help anyone
grinch2787 (author)2017-03-20
Can one at the fake bomb on the function that you can defuse them with different wires?
And could one make the whole also programmable, which the wire defuses the bomb or for example the timer run faster?
AlekseyD4 (author)2017-03-18
Help with the problem
Time_BOMB_Airsoft_GAME:197: error: 'menuPrincipal' was not declared in this scope
exit status 1
Daniel AugustoG made it! (author)2017-02-19
https://www.youtube.com/watch?v=I8_UMfjKdw0
Bees2699 (author)2017-01-31
Hi, I know this is an old post but have am having a problem uploading the code keep getting the message
" 'menuprincipal' was not declaired in this scope "
Hope you can help as really look forward to making this.
Thank you
XikoM1 (author)Bees26992017-02-16
hi, i have the same problem.
you know how we can do it without "menu principal"?
KristoferW5 (author)2017-01-12
haveing problem this is what i get when trying to upload
Arduino: 1.6.12 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Airso\AppData\Local\Temp\Temp1_FYW1PMWILGVF3ZU (5).zip\Time_BOMB_Airsoft_GAME\Time_BOMB_Airsoft_GAME.ino:2:20: fatal error: Keypad.h: No such file or directory
#include <Keypad.h>
compilation terminated.
exit status 1
The Keypad.h file can be found in the original creator's Github:
https://github.com/yinbot/Airsoft-BombPro/tree/mas...
Hope that helps!
АлексейТ15 (author)2017-01-23
Hi, liked your project, I decided to put together a sketch beg perfectly display all shows, but DOES NOT OPERATE Keypad 4x4 connects all as in the picture, using arduino pro mini, then decided to try to arfuino nano, nothing has changed, kdaviatura not work at all, I tried different keypad.h library does not help anything, just tried a second keyboard (I have two) zero result, also tried to connect the resistance 10kom please help, what could be wrong?
Basv29 (author)2016-12-02
I have made it and it works perfect. but i want to ad a game where both teams had to arm the bomb with a password but have some one did this already??
2lol5 (author)2016-11-01
Hey... Is this 1 channel relay compatible with this project?
http://www.ebay.com/itm/5V-One-1-Channel-Relay-Module-Board-Shield-PIC-AVR-DSP-ARM-MCU-Arduino-/310566336050?hash=item484f323632
АлександрЗ15 (author)2016-10-28
Покажите пожалуйста фотографии. Не могу понять как собирать
NeilB70 (author)2016-10-24
Done what the tutorial said, and used other buttons (the arcade type)
but when I use them the arduino goes all wrong and the screen switches
off and no longer continues with the games sequence, what could be up
with it
GreggJ7 (author)NeilB702016-10-24
The diagram has the switch common to an analog input for some reason. That is definitely not right. Connect the switch common to positive.
I think the problem you are having is when you make the switch you are somehow shorting the power, which suggests you have somethign wrong even with the incorrect diagram!
NeilB70 (author)GreggJ72016-10-26
Thanks, but not sure what you mean??? I did have some issue getting the switches to work to start with.
Could you explain in a bit more detail what you mean by connect it to the positive??
GreggJ7 (author)NeilB702016-10-27
https://www.arduino.cc/en/Tutorial/Button
that link shows a more common way to use switches. You can see that the switch is connected to 5V and 0V (via the resistor). The circuit as drawn will put whatever is on the AI ontot he input, which is weird. Maybe the code is written to use the AI as a 5V source, but it is a weird way to do it.
АлександрЗ15 (author)2016-10-16
Добрый день. Смотрю на схему и видео и не могу понять как подключать все правильно. Если есть возможность, то скиньте пожалуйста подробную схему подключение.
Federicoh8 (author)2016-10-07
I implemented the disarmament of the bomb through wires. I'd like to know how i can to halve the time when a wires is cut.
In another wire i'd like to triple the speed of the countdown.
if (digitalRead(wirePin) != HIGH) {
if (digitalRead(wirePin2) != HIGH) {
AndréC84 (author)2016-09-20
Hi! Maybe someone can help me. I have this old device that i would like to use as an enclosure for my bomb. Is it possible to use the buttons on the arduino? How?
Thank You
vandenbrande (author)AndréC842016-09-20
Yes is possible i think, You need to find a datasheet for this keypad.
amurillo3 (author)2016-08-22
Please ignore the speaker issue, just got another speaker and it work, my bad, somehow the original speaker died on me...
About This Instructable
12,335views
27favorites
License:
Bio: Hello world! I make simple &amp; Advanced projects for people who want to learn programming and electronics. Most of my Instructables are about arduino and the ... More »
More by vandenbrande:ARDUINO - SOLID STATE RELAY FAN/ventilator Control Using the W1209 Thermistor and SSR-25 DA Arduino - SSR-25 DA Solid State Relay and DS3231 RTC Automatic Timer Lamp Arduino & C# - RGB LED / LED STRIP CONTROL C# Application
Add instructable to:
