ARDUINO AS a 8051 PROGRAMMER - CHEAPEST PROGRAMMER IN THE WORLD
45,819
35
47
Posted
Introduction: ARDUINO AS a 8051 PROGRAMMER - CHEAPEST PROGRAMMER IN THE WORLD
ITS TO HARD TO FIND 8051 PROGRAMMER WITH USB CONNECTIVITY.
YOU WILL FIND SO MANY CIRCUITS FOR 8051 PROGRAMMING BY MAX232 BUT IT WILL NOT WORK IF ITS NOT ICSP OR THE BOOTLOADER IS NOT INSTALLED ON CHIP.
BUT IF YOU HAVE ARDUINO YOU CAN USE IT AS PROGRAMMER FOR 89S52(ATMEGA89S52).
I HAVE CREATED ARDUINO SHIELD.
THIS IS THE CHEAPEST PROGRAMMER IN THE WORLD
COST WILL BE VERY LOW IF YOU HAVE ARDUINIO ALREADY.
Step 1: WHAT YOU NEED?
ARDUINO UNO (ANY ARDUINO)
AT89S52
IC STAND
PCB
22PF CAPACITOR 2 NO.
CRYSTAL 12Mhz(8Mhz to 16Mhz can work)
MALE PIN HEADER
USB CABLE
10K OHM RESISTOR
10uF capacitor
Step 2: TOTAL PRICE
CURRENCY IN INDIAN Rs.
IC STAND:- 5Rs
CRYSTAL:- 10Rs
CAPACITOR:- 3Rs
PCB:- 10Rs
MALE PIN
HEADER:- 5Rs
AT89S52 40Rs
TOTAL ONLY:-70Rs.
Step 3: Circuit Diagram and Software
upload at89s52program skatch to arduino
connect the circuit as per diagram
open 89s52programmer.exe
select com port of your arduino
click open hex file, and browse it ..
then click on identify chip you will see the message at bottom of the window (chip detected)
then click on upload hex
wait for a moment and message to diplay(finished writting).
now enjoy....
Step 4: Here Is Program for Arduino
#define dummyData 0xAA
#define RDY 75 #define NRDY 76
const int _MISO = 4; const int _MOSI = 5; const int _CLK = 3; const int RST = 2;
/* Variable definition block */
byte data; byte AL,AH; // 16-bit address byte lockByte; // embed lock bits here byte SigH,SigL; // Signature Bytes
void setup() { pinMode(_MISO, INPUT); pinMode(_MOSI, OUTPUT); pinMode(_CLK, OUTPUT); pinMode(RST, OUTPUT); Serial.begin(115200); // depends on the setting of the host PC
void loop() { while (!Serial.available()); // wait for character if (Serial.available() > 0) switch (Serial.read()) { case 'p': Serial.write(progEnable()); break; case 'r': readProgmem(); Serial.write(data); break; case 'a': while(!Serial.available()); AL = Serial.read(); break; case 'A': while(!Serial.available()); AH = Serial.read(); break; case 'd': while(!Serial.available()); data = Serial.read(); break; case 'S': AH = 0; AL = 0; SigH = readSign(); Serial.write(SigH); break; case 's': AH = 2; AL = 0; SigL = readSign(); Serial.write(SigL); AH = 1; AL = 0; SigL = readSign(); Serial.write(SigL); break; // read SigL case 'o': digitalWrite(RST,1);break; case 'c': digitalWrite(RST,0);break; case 'e': eraseChip(); Serial.write(RDY); break; case 'j': break; case 'w': writeProgmem(); break; }
unsigned char SendSPI(unsigned char data) { uint8_t retval = 0; uint8_t intData = data; int t; for (int ctr = 0; ctr < 7; ctr++) { if (intData & 0x80) digitalWrite(_MOSI,1); else digitalWrite(_MOSI,0);
digitalWrite(_CLK,1); delayMicroseconds(1);
t = digitalRead(_MISO); digitalWrite(_CLK,0);
if (t) retval |= 1; else retval &= 0xFE; retval<<=1; intData<<= 1; delayMicroseconds(1); }
if (intData & 0x80) digitalWrite(_MOSI,1); else digitalWrite(_MOSI,0); digitalWrite(_CLK,1); delayMicroseconds(1);
t = digitalRead(_MISO); digitalWrite(_CLK,0); if (t) retval |= 1; else retval &= 0xFE;
return retval; }
byte progEnable() { SendSPI(0xAC); SendSPI(0x53); SendSPI(dummyData); return SendSPI(dummyData); }
void eraseChip() { SendSPI(0xAC); SendSPI(0x9F); SendSPI(dummyData); SendSPI(dummyData); delay(520); }
void readProgmem() {
SendSPI(0x20); SendSPI(AH); SendSPI(AL); data = SendSPI(dummyData); }
void writeProgmem() { SendSPI(0x40); SendSPI(AH); SendSPI(AL); SendSPI(data); }
void writeLockBits() { SendSPI(0xAC); SendSPI(lockByte); SendSPI(dummyData); SendSPI(dummyData); }
void readLockBits() { SendSPI(0x24); SendSPI(dummyData); SendSPI(dummyData); lockByte = SendSPI(dummyData); }
byte readSign() { SendSPI(0x28); SendSPI(AH); SendSPI(AL); return SendSPI(dummyData); }
Step 5: Refrence
http://tiktakx.wordpress.com/2014/04/19/programmin...
and
www.facebook.com/SparkingElectronics
like this page for more projects like this.
how to generate hex file and make shield like this will be updated soon .. keep visiting..
  • Remote Control Contest 2017
  • Arduino Contest 2017
  • LED Contest 2017
    LED Contest 2017
Questions & Answers
43 Comments
I will Try this
If It works Thanks
@tapan mojidra, great work bro, i have following questions,
1- did u try this circuit yourself, by uploading simple program?
2- suppose i want to make a program for blinking led,
can i make the led blinking program in arduino language?
in other words can we upload arduino sketch to 89s52?
Waiting for your valuable reply....
i have try this circuit myself and
you cant use arduino lenguage to program 89s52 chip.
this is just only a programmer for 8051 you have to generate hex file for that separately. you can upload hex file using this programmer.
the arduino chip will behave like as a isp programmer for 89s52 .
and 89s52 can be programmed with this programmer.
I have a doubt. How to dump the hex file to 8051 using arduino. Am I supposed to copy the hex file content and paste in the serial monitor in the arduino. Please clearly explain the steps you have followed one by one.
Thanks
we cant upload arduino sketch to 89s52 chip.
i have use kail simmulater to make program for 89s52 chip...
i have try and successfully completed the projects on 16*2 LCD programming and works perfectly.
Hello!
Will this work for AT89C51?
Thank you.
How to check whether if the program is get uploaded or not ?
Hello! AT89S52 is AT89S52-24PU? if they are the same: The program says Port open. then i click identify and nothing. Can somebody help me?
