Home Made Maximum Power Point Tracking (MPPT) Charge Controller | Alternative Energy
8,289
46
5
Posted in TechnologyArduino
Introduction: Home Made Maximum Power Point Tracking (MPPT) Charge Controller | Alternative Energy
About: Electronicslovers started in July 2011 with the mission to produce ideas to student and engineer or hobbyist to learn electronics practically. Electronicslovers provides information by publishing tutorial, e...
ARDUINO BASED MPPT SOLAR CHARGE CONTROLLER
For schematic and code visit my WebsiteARDUINO BASED MPPT SOLAR CHARGE CONTROLLER
what is Mppt( Maximum power point tracking)?
"we use MPPT algorithm to get the maximum available power from the Photovoltaic module under certain conditions"
How MPPT works? Why 150W solar panel does not equal to 150 w?
For example, you bought a new solar panel from the market which puts out 7 amps. under charge the setting of a battery is configured to 12 volts: 7 amps times 12 volts = 84w (P=V*I) You lost over 66 watts - but you paid for 150 watts. That 66 watt is not going anywhere, but it,s due to the poor match of the solar output current and battery voltage.
After using MPPT algorithm we can get the Maximum available power
Battery gets is now 12 amps at 12 volts Output power is equal to p= V*I p=12*12=144w Now you still have almost 144 watts, and everyone is happy.
Specification of the project 1.This project is Based on MPPT(Maximum power point tracker) algorithm 2. LED indication to show the low mid and high level of charge stat 3. LCD (20x4 character ) display for displaying power,current,voltages etc 4. Lightning /Overvoltage Protection 5. Protection For Reverse power flow 6. Over load & Short Circuit protection 7. Logging data through WiFi 8.Charge your Cellphone, tablets any gadgets throug USB port Electrical specifications : 1.Rated Voltage= 12V 2.Maximum input current = 5A 3.Load current support upto =10A 4. In put Voltage = Solar panel 12 to 24V 5.power of Solar panel = 50 Watts
PARTS REQUIRED:
Resistors ( 3 x 200R ,3 x330R,1 x 1K, 2 x 10K, 2 x 20K, 2x 100k, 1x 470K )
TVS diode ( 2x P6KE36CA )
Arduino Nano
( ACS712-5A ) Current Sensor
Buck Converter ( LM2596 )
Wifi Module ( ESP8266 )
LCD display ( 20x4 I2C )
MOSFETs ( 4x IRFZ44N )
MOSFET driver ( IR2104 )
3.3V Linear regulator ( AMS 1117 )
Transistor ( 2N2222 )
Diodes ( 2x IN4148 , 1 x UF4007 )
Capacitors ( 4 x 0.1 uF, 3 x 10uF ,1 x100 uF ,1x 220uF)
Inductor ( 1x 33uH -5A )
LEDs ( Red ,Yellow ,Green )
Fuses ( 5A)
  • Simulation of MPPT Charge Controller Project in Proteus software
This Simulation has been designed in Proteus Software 8.6 version. You can make your own by using Arduino Library for Proteus and a simulation tool known as Proteus. Kindly Contact Us if you want to Buy a proteus simulation source file for this project.
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    5 Comments
    What is the purpose of two diodes backed up one to the other. D1 and D2 and D11 and D12 ? All diodes leak some and this will give you potential problems .
    You seem to have your battery connected straight across your panel. There can be no control like that? Look again at the circuit you copied . It has the battery across the mosfet Q1 and thus no power goes in unles Q1 is on
    Silly ,don't use this
    Hi.. does not MPPT also designed to convert from higher V-in to higher I-out lower V-out?
    if yes, then what is needed to modify your setup to handle this case?
    many thx..
    buck converter
    Can i get d connections of buck converter ? N even the lcd display two more days to complete our project plz need help :(
    hi, nice project..
    from the schematic the buck converter connector output pin is connected at 5V arduino pin. is suppose to be connected there or Vin arduino pin?
