ARDUINO FM RADIO WITH CLOCK AND THERMOMETER
Published
Introduction: ARDUINO FM RADIO WITH CLOCK AND THERMOMETER
The FM broadcast band, used for FM broadcast radio by radio stations, differs between different parts of the world. In Europe, Australia[1] and Africa ((defined as International Telecommunication Union (ITU) region 1)), it spans from 87.5 to 108 megahertz (MHz) - also known as VHF Band II - while in the Americas (ITU region 2) it ranges from 88 to 108 MHz. The FM broadcast band in Japan uses 76 to 95 MHz. The International Radio and Television Organisation (OIRT) band in Eastern Europe is from 65.8 to 74.0 MHz, although these countries now primarily use the 87.5 to 108 MHz band, as in the case of Russia. Some other countries have already discontinued the OIRT band and have changed to the 87.5 to 108 MHz band.
Frequency modulation radio originated in the United States during the 1930s; the system was developed by the American electrical engineer Edwin Howard Armstrong. However, FM broadcasting did not become widespread, even in North America, until the 1960s.
A signal may be carried by an AM or FM radio wave.
FM has better noise (RFI) rejection than AM, as shown in this dramatic New York publicity demonstration by General Electric in 1940. The radio has both AM and FM receivers. With a million-volt arc as a source of interference behind it, the AM receiver produced only a roar of static, while the FM receiver clearly reproduced a music program from Armstrong's experimental FM transmitter W2XMN in New Jersey.
In telecommunications and signal processing, frequency modulation (FM) is the encoding of information in a carrier wave by varying the instantaneous frequency of the wave. In analog frequency modulation, such as FM radio broadcasting of an audio signal representing voice or music, the instantaneous frequency deviation, the difference between the frequency of the carrier and its center frequency, is proportional to the modulating signal.
More here at Wikipedia!
Step 1: Order Your Parts!
1.Arduino UNO or Nano https://i.ebayimg.com/images/g/G2wAAOSwPzhaJ76G/s-...
2.Display SSD1306-White 128X64 OLED I2C https://i.ebayimg.com/images/g/pAEAAOSwHqRZv6D8/s-...
3.Arduino I2C RTC DS1307 AT24C32 Real Time Clock Module https://i.ebayimg.com/images/g/x7EAAOSw8b1Z6W02/s-...
4.DALLAS DS18B20 18B20 TO-92 Thermometer Temperature Sensor https://i.ebayimg.com/images/g/SUkAAOSwywRaPIl0/s-...
5.FM Stereo Module Radio Module RDA5807M https://i.ebayimg.com/images/g/oPMAAOSwIgNXqD0i/s-...
6.1/4W Watt Metal Film Resistor 0.25W-10K...3 pieces https://i.ebayimg.com/images/g/uXUAAOSwo4pYHUuB/s-...
7.1/4W Watt Metal Film Resistor 0.25W-4K7...1pieces https://i.ebayimg.com/images/g/gaYAAOSwTYxZjSAK/s-...
8.Push Button Switch 3pieces https://i.ebayimg.com/images/g/CgkAAOSwVtZZ7rH~/s-...
9.Mini Digital DC 5V Amplifier Board Class D 2*3W USB Power PAM8403 https://i.ebayimg.com/images/g/IiYAAOSwj1hafCGf/s-...
10.Speaker Mini Amplifier 3W 4R (3 Watts 4 Ohms)....2 pieces https://i.ebayimg.com/images/g/qEwAAOSw44BYHYcn/s-...
Step 2: Create the Circuit!
Step 3: Upload the Code!
Step 4: Build Your Case!
Step 5: Enjoy FM Radio !!!
FM broadcasting is a method of radio broadcasting using frequency modulation (FM) technology. Invented in 1933 by American engineer Edwin Armstrong, it is used worldwide to provide high-fidelity sound over broadcast radio. FM broadcasting is capable of better sound quality than AM broadcasting, the chief competing radio broadcasting technology, so it is used for most music broadcasts. FM radio stations use the VHFfrequencies. The term "FM band" describes the frequency band in a given country which is dedicated to FM broadcasting.
Broadcast bands[edit]
Main article: FM broadcast band Throughout the world, the FM broadcast band falls within the VHF part of the radio spectrum. Usually 87.5 to 108.0 MHz is used,[1] or some portion thereof, with few exceptions: In the former Soviet republics, and some former Eastern Bloc countries, the older 65.8–74 MHz band is also used. Assigned frequencies are at intervals of 30 kHz. This band, sometimes referred to as the OIRT band, is slowly being phased out in many countries. In those countries the 87.5–108.0 MHz band is referred to as the CCIR band.In Japan, the band 76–95 MHz is used.
More at wiki
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
