Introduction: ARDUINO IR REMOTE RECIEVER
Picture of ARDUINO IR REMOTE RECIEVER
WELCOME TO ARDUINO PROJECTS!!!!!in this ibles i am going to teach you about ir receiver using arduino.
programming my Arduino to identify sets of digits transmitted from my IR remote.
With this program you can control LEDs over a normal tv remote.
sounds interestinn right let's get started with billing electroics;-
Step 1: BILLING ELECTRONICS:-
Picture of BILLING ELECTRONICS:-
You will need:
- A TV IR Remote (I used one from samsung)
- 4 LEDs or more
- A IR Receiver (TSOP4838, or a similar)
- any Arduino
Step 2: BUILDING:-
Picture of BUILDING:-
connect led to arduino board:
LED1 : Pin D4
LED2 : Pin D5
LED3 : Pin D6
LED4 : Pin D7
connect Reciver:
Pin1 : Pin D9
Pin2 : Gnd
Pin3 : 5v
Use an Digital Pin and write the Pin into the Code.
Step 3: CODING:-
Picture of CODING:-
#include
int RECV_PIN = 9;
int reversePin = 4; int forwardPin = 5; int playPin = 6; int pausePin = 7;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup() {
Serial.begin(9600);
irrecv.enableIRIn();
// Start the receiver
pinMode(reversePin, OUTPUT);
// sets the digital pin as output
pinMode(forwardPin, OUTPUT);
pinMode(playPin, OUTPUT);
pinMode(pausePin, OUTPUT);
// sets the digital pin as output }
void loop() {
if (irrecv.decode(&results)) {
long int decCode = results.value;
Serial.println(decCode);
switch (results.value) {
case 1431986946:
Serial.println("Forward");
digitalWrite(forwardPin, HIGH);
// sets the LED on
break;
case -11780576:
Serial.println("Reverse");
digitalWrite(reversePin, HIGH);
// sets the LED on
break;
case -873913272:
Serial.println("Play");
digitalWrite(playPin, HIGH);
// sets the LED on
break;
case -1025287420:
Serial.println("Pause");
digitalWrite(pausePin, HIGH);
// sets the LED on
break;
case 1791365666:
Serial.println("Stop");
digitalWrite(forwardPin, LOW);
// sets the LED off
digitalWrite(reversePin, LOW);
// sets the LED off
digitalWrite(playPin, LOW);
// sets the LED off
digitalWrite(pausePin, LOW);
// sets the LED off
break;
default:
Serial.println("Waiting ..."); }
irrecv.resume(); // Receive the next value } }
About This Instructable
1,757views
23favorites
License:
More by appytechie:Program the Linkit One Using a Raspberry PILinkit One Controlled El-wireLinkit One - Dice
Add instructable to:
