loading
[ Play Video ]
One year ago, I began building my own solar system to provide power for my village house.Initially I made a LM317 based charge controller and an Energy meter for monitoring the system.Finally I made PWM charge controller.In April-2014 I posted my PWM solar charge controller designs on the web,it became very popular. Lots of people all over the world have built their own. So many students have made it for their college project by taking help from me.I got several mails every day from people with questions regarding hardware and software modification for different rated solar panel and battery. A very large percentage of the emails are regarding the modification of charge controller for a 12Volt solar system.
You can see my other version charge controllers
ARDUINO MPPT SOLAR CHARGE CONTROLLER ( Version-3.0)
ARDUINO SOLAR CHARGE CONTROLLER (Version-1)
To solve this problem I made this new version charge controller so that any one can use it without changing the hardware and software. I combine both the energy meter and charge controller in this design.
Specification of version-2 charge controller :
1.Charge controller as well energy meter
2. Automatic Battery Voltage Selection (6V/12V)
3.PWM charging algorithm with auto charge set point according to the battery voltage
4.LED indication for the state of charge and load status
5. 20x4 character LCD display for displaying voltages,current,power,energy and temperature.
6.Lightning protection
7.Reverse current flow protection
8.Short Circuit and Over load protection
9. Temperature Compensation for Charging
Electrical specifications :
1.Rated Voltage= 6v /12V
2.Maximum current = 10A
3.Maximum load current =10A
4.Open Circuit Voltage = 8-11V for 6V system /15 -25V for 12V system
Step 1: Parts and Tools Required :
Parts:
1.Arduino Nano (Amazon / eBay)
2.P-MOSFET ( Amazon / IRF 9540 x2 )
3.Power diode ( Amazon / MBR 2045 for 10A and IN5402 for 2A)
4.Buck Converter ( Amazon / eBay) or Voltage Regulator (LM7805)
5.Temperature Sensor( Amazon / LM35)
6.Current Sensor ( Amazon / ACS712)
7.TVS diode ( Amazon / P6KE36CA)
8.Transistors ( 2N3904 or 2N2222)
9.Resistors( 100k x 2, 20k x 2,10k x 2,1k x 2, 330ohm x 5)
10.Ceramic Capacitors (0.1uF x 2)
11.Electrolytic Capacitors ( 100uF and 10uF)
12. 20x4 I2C LCD ( Amazon / eBay)
13.RGB LED ( Amazon / ebay)
14.Bi Color LED ( Amazon )
15.Jumper Wires/Wires(eBay)
16.Header Pins (Male,Female and right angle)
17.Heat Sink ( Amazon / eBay)
18.Fuse Holder and fuses ( Amazon / eBay)
19.Push Button ( Amazon )
20.Perforated Board (Amazon / eBay)
21.Project Enclosure
22.Screw terminals ( 3x 2pin and 1x6 pin)
23.Nuts/Screws/Bolts
24.Plastic Base
Tools :
1.Soldering Iron ( Amazon )
2.Wire Cutter and Stripper ( Amazon )
3.Screw Driver ( Amazon )
4.Cordless Drill ( Amazon )
5.Dremel ( Amazon )
6.Glue Gun ( Amazon )
7.Hobby Knife ( Amazon )
Step 2: How The Charge Controller Works :
The heart of of the charge controller is Arduino nano board.The arduino MCU senses the solar panel and battery voltages.According to this voltages it decides how to charge the battery and control the load.
The amount of charging current is determined by difference between battery voltage and charge set point voltages. The controller uses two stages charging algorithm.According to the charging algorithm it gives a fixed frequency PWM signal to the solar panel side p-MOSFET. The frequency of PWM signal is 490.20Hz(default frequency for pin-3). The duty cycle 0-100% is adjusted by the error signal.
The controller gives HIGH or LOW command to the load side p-MOSFET according to the dusk/dawn and battery voltage.
The full schematic is attached bellow.
Step 3: Main functions of solar charge controller:
The charge controller is designed by taking care of the following points.
1.Prevent Battery Overcharge: To limit the energy supplied to the battery by the solar panel when the battery becomes fully charged.This is implemented in charge_cycle() of my code.
2.Prevent Battery Over discharge: To disconnect the battery from electrical loads when the battery reaches low state of charge.This is implemented in load_control() of my code.
3.Provide Load Control Functions: To automatically connect and disconnect an electrical load at a specified time. The load will ON when sunset and OFF when sunrise.This is implemented in load_control() of my code.
4.Monitoring Power and Energy : To monitor the load power and energy and display it.
5.Protect from abnormal Condition: To protect the circuit from different abnormal situation like lightening,over voltage,over current and short circuit etc.
6.Indicating and Displaying: To indicate and display the various parameters
7.Serial Communication: To print various parameters in serial monitor
Step 4: Sensing Voltages,Current and temperature :
1.Voltage Sensor:
The voltage sensors are used to sense the voltage of solar panel and battery.It is implemented by using two voltage divider circuits.It consists of two resistors R1=100k and R2=20k for sensing the solar panel voltage ans similarly R3=100k and R4=20k for battery voltage.The out put from the R1and R2 is connected to arduino analog pin A0 and out put from the R3 and R4 is connected to arduino analog pin A1.
2.Current Sensor :
The current sensor is used for measuring the load current.later this current is used to calculate the load power and energy.I used a hall effect current sensor (ACS712-20A)
3.Temperature Sensor :
The temperature sensor is used to sense the room temperature. I used LM35 temperature sensor which is rated for −55°C to +150°C Range.
Why Temperature monitoring is Required ?
The battery’s chemical reactions change with temperature.As the battery gets warmer, the gassing increases. As the battery gets colder,it becomes more resistant to charging. Depending on how much the battery temperature varies, it is important to adjust the charging for temperature changes.So it is important to adjust charging to account for the temperature effects. The temperature sensor will measure the battery temperature, and the Solar Charge Controller uses this input to adjust the charge set point as required.The compensation value is - 5mv /degC/cell for lead acid type batteries.(–30mV/ºC for 12V and 15mV/ºC for 6V battery).The negative sign of temperature compensation indicates,increase in temperature require a reduction in charge set point.
For more details on Understanding and Optimizing Battery Temperature Compensation
Step 5: Sensors Callibration
Voltage Sensors :
5V = ADC count 1024
1 ADC count = (5/1024)Volt= 0.0048828Volt
Vout=Vin*R2/(R1+R2)
Vin = Vout*(R1+R2)/R2 R1=100 and R2=20
Vin= ADC count*0.00488*(120/20) Volt
Current Sensor:
As per seller information for ACS 712 current sensor
Sensitivity is =100mV / A =0.100V/A
No test current through the output voltage is VCC / 2= 2.5
ADC count= 1024/5*Vin and Vin=2.5+0.100*I (where I=current)
ADC count= 204.8(2.5+0.1*I) =512+20.48*I
=> 20.48*I = (ADC count-512)
=> I =(ADC count/20.48)- 512/20.48
Current (I) =0.04882*ADC -25
More details on ACS712
As per data sheet of LM35
Sensitivity=10 mV/°C
Temp in deg C =(5/1024)*ADC count*100
Note : The sensors are calibrated by assuming the arduino Vcc= 5V reference.But in practical it is not 5V always.So there may be chance of getting wrong value from the actual value.It can be solved by following way.
Measure the voltage between arduino 5V and GND by a multimeter.Use this voltage instead of 5V for Vcc in your code.Hit and try to edit this value until it matches the actual value.
Example: I got 4.47V instead of 5V.So the change should be 4.47/1024=0.0043652 instead of 0.0048828.
Step 6: Charging Algorithm
1.Bulk :At this mode, a preset maximum constant amount of current (amps) is fed into the battery as no PWM is present. As the battery is being charged up , the voltage of the battery increases gradually
2. Absorption: When the battery reaches the bulk charge set voltage, the PWM begins to hold the voltage constant. This is to avoid over-heating and over-gassing the battery. The current will taper down to safe levels as the battery becomes more fully charged.
3. Float: When the battery is fully recharged, the charging voltage is reduced to prevent further heating or gassing of the battery
This is the ideal charging procedure.
The present charge cycle block of code is not implements 3 stages charging.I use a easier logic in 2 stages.It works good.
I am trying the following logic for implementing the 3 stages charging.
Future Planning for Charging Cycle :
The bulk charge begins when solar panel voltage is larger than battery voltage. When the battery voltage reaches 14.4V, absorption charge will be entered. The charging current will be regulated by PWM signal to maintain the battery voltage at 14.4V for one hour. Float charge will then enter after one hour. The float stage generates a trickle charge to keep the battery voltage at 13.6V. When the battery voltage falls below 13.6V for 10mins, the charging cycle will be repeated.
I request community members to help me for writing the piece of code to implement the above logic.
Step 7: Load Control
To automatically connect and disconnect the load by monitoring dusk/dawn and battery voltage,load control is used.
The primary purpose of load control is to disconnect the load from battery to protect it from deep discharging. Deep discharging could damage the battery.
The DC load terminal is designed for low power DC load such as street light.
The PV panel itself is used as the light sensor.
Assuming solar panel voltage >5V means dawn and when < 5V dusk.
ON Condition:
In the evening, when the PV voltage level falls bellow 5V and battery voltage is higher than LVD setting, the controller will turn on the load and the load green led will glow.
OFF Condition:
The load will cut off in the following two condition.
1.In the morning when the PV voltage is larger than 5v,
2.When the battery voltage is lower than the LVD setting
The load red led ON indicates that load is cut off.
LVD is refers to Low Voltage Disconnect
Step 8: Power and Energy
Power :
Power is product of voltage (volt) and current (Amp)
P=VxI
Unit of power is Watt or KW
Energy:
Energy is product of power (watt) and time (Hour)
E= Pxt
Unit of Energy is Watt Hour or Kilowatt Hour (kWh)
To monitor the load power and energy above logic is implemented in software and the parameters are displayed in a 20x4 char LCD.
Step 9: Protection
1.Reverse polarity protection for solar panel
2. Overcharge protection
3. Deep discharge protection
4. Short circuit and Overload protection
5.Reverse current protection at night
6.Over voltage protection at solar panel input
For reverse polarity and reverse current flow protection I used a power diode (MBR2045).Power diode is used to handle large amount of current.In my earlier design I used a normal diode(IN4007).
Overcharge and Deep discharge protection is implemented by the software.
Over current and overload protection is implemented by using two fuses ( one at the solar panel side and other at load side).
Temporary over voltages occur in power systems for a variety of reasons, but lightning causes the most severe over voltages. This is particularly true with PV systems due to the exposed locations and system connecting cables.In this new design I used a 600 watt bidirectional TVS diode (P6KE36CA ) to suppress the lightning and over voltage at the PV terminals.In my earlier design I used a zeener diode.You can also use a similar TVS diode on the load side.
For selection guide of TVS diode click here
For choosing a right part no for TVS diode click here
Step 10: LED Indication
Battery State Of Charge (SOC) LED:
One important parameter that defines the energy content of the battery is the State of Charge (SOC). This parameter indicates how much charge is available in the battery
A RGB LED is used to indicate the battery state of charge.For connection refer the above schematic
Battery LED ------------>Battery Status
RED --------------------> Voltage is LOW
GREEN --------------------> Voltage is Healthy
BLUE --------------------> Fully Charged
Load LED :
A bi color (red/green) led is used for load status indication.Refer the above schematic for connection.
Load LED --------------------->Load Status
GREEN -------------------------> Connected (ON)
RED ---------------------------> Disconnected (OFF)
I include a third led for indicating the solar panel status.
Step 11: LCD display
To display the voltage,current,power,energy and temperature a 20x4 I2C LCD is used.If you do not want to display the parameter then disable the lcd_display() from the void loop() function.After disable you have indication led to monitor the battery and load status.
You can refer this instructable for I2C LCD
Download the LiquidCrystal _I2C library from here
Note : In code you have to change the I2C module address.You can use the address scanner code given in the link.
Step 12: Bread Board Testing
It is always a good idea to test your circuit on a breadboard before soldering it together.
After connecting everything upload the code.The code is attached bellow.
The entire software is broken into small functional block for flexibility.Suppose the user is not interested to use a lcd display and happy with the led indication .Then just disable the lcd_display() from the void loop().Thats all.
Similarly according to the user requirement he can enable and disable the various functionality.
Download the code from my GitHub Account
ARDUINO-SOLAR-CHARGE-CONTROLLER-V-2
Step 13: Power Supply and Terminals :
Terminals :
Add 3 screw terminals for solar input,battery and load terminal connections.Then solder it.I used the middle screw terminal for battery connection,left to it is for solar panel and the right one is for load.
Power Supply:
In my previous version the power supply for arduino was provided by a 9V battery.In this version the power is taken from the charging battery itself.The battery voltage is step down to 5V by a voltage regulator(LM7805).
Solder LM7805 voltage regulator near to the battery terminal.Then solder the electrolytic capacitors as per schematic.At this stage connect the battery to the screw terminal and check the voltage between pin 2 and 3 of LM7805.It should be near to 5V.
When I used a 6V battery the LM7805 works perfectly.But for 12V battery it heated up after some time.So I request to use a heat sink for it.
Efficient Power supply :
After few testing I found that the voltage regulator LM7805 is not the best way to power the arduino as it waste lots of power in the form heat.So I decide to change it by a DC DC buck converter which is highly efficient.If you plan to make this controller, I advice to use a buck converter rather than LM7805 voltage regulator.
Buck Converter Connection:
IN+ -------> BAT+
IN- --------> BAT-
OUT+ -----> 5V
OUT- -----> GND
Refer the above pictures.
You can buy it from eBay
Step 14: Mount the Arduino :
Cut 2 female header strips of 15 pins each.Place the nano board for reference.Insert the two headers according to the nano pin.Check it whether the nano board is perfect to fit into it.Then solder it back side.
Insert two rows of male header on both sides of nano borad for external connections.Then join the solder points between arduino pin and header pins.See the above picture.
Initially I forgot to add Vcc and GND headers.At this stage you can put headers with 4 to 5 pins for Vcc and GND.
As you can see I connected the voltage regulator 5V and GND to the nano 5V and GND by red and black wire.Later I removed it and soldered at the back side for better look of the board.
Step 15: Solder the components
Before soldering the components make holes at corners for mounting.
Solder all the components as per schematic.
Apply heat sink to two MOSFETs as well as power diode.
Note: The power diode MBR2045 have two anode and one cathode.So short the two anode.
I used thick wire for power lines and ground and thin wires for signal.signal. Thick wire is mandatory as the controller is designed for higher current.
Step 16: Connect the Current Sensor
After connecting all the components solder two thick wire to the load mosfet's drain and upper terminal of load side fuse holder.Then connect these wires to the screw terminal provided in current sensor( ACS 712).
Step 17: Make the Indication and temperature sensor panel
I have shown two led in my schematic.But I added a third led(bi color) for indicating the solar panel status in future.
Prepare small size perforated board as shown.Then make two holes (3.5mm) by drill on left and right( for mounting).
Insert the leds and solder it to the back side of the board.
Insert a 3 pins female header for temperature sensor and then solder it.
Solder 10 pins right angle header for external connection.
Now connect the RGB led anode terminal to the temperature sensor Vcc(pin-1).
Solder the cathode terminals of two bi color led.
Then join the solder points the leds terminal to the headers.You can paste a sticker with pin name for easy identifications.
Step 18: ​Connections for Charge controller
Connect the Charge Controller to the Battery first, because this allows the Charge Controller to get calibrated to whether it is 6V or 12V system. Connect the negative terminal first and then positive. Connect the solar panel(negative first and then positive) At last connect the load.
The charge controller load terminal is suitable for only DC load.
How to run an AC Load ?
If you want to run AC appliances then you must need an inverter. Connect the inverter directly to the battery.See the above picture.
Step 19: Final Testing :
After making the main board and indication board connect the header with jumper wires(female-female)
Refer the schematic during this connection.Wrong connection may damage the circuits.So be care full in this stage.
Plug the usb cable to the arduino and then upload the code.Remove the usb cable.If you want to see the serial monitor then keep it connected.
Fuse Rating: In demo I have put a 5A fuse in the fuse holder.But in practical use, put a fuse with 120 to 125% of short circuit current.
Example :A 100W solar panel having Isc=6.32A needs a fuse 6.32x1.25 = 7.9 or 8A
How to test ?
I used a buck boost converter and black cloth to test the controller.The converter input terminals are connected to battery and the output is connected to the charge controller battery terminal.
Battery status :
Rotate the converter potentiometer by a screw driver to simulate different battery voltages.As the battery voltages change the corresponding led will turn off and turn on.
Note: During this process Solar panel should be disconnected or covered with a black cloth or card board.
Dawn/Dusk : To simulate dawn and dusk use a black cloth.
Night : Cover the solar panel entirely.
Day: Remove the cloth from the solar panel.
Transition : slow the remove or cover the cloth to adjust different solar panel voltages.
Load Control : According to the battery condition and dawn/dusk situation the load will turn on and off.
Temperature Compensation :
Hold the temperature sensor to increase the temperature and place any cold things like ice to decrease the temp.It will be immediately displayed on the LCD.
The compensated charge set point value can be seen on the serial monitor.
In the next step onward I will describe the making of enclosure for this charge controller.
Step 20: Mounting the main board:
Place the main board inside the enclosure.Mark the hole position by a pencil.
Then apply hot glue to the marking position.
Place the plastic base over the glue.
Then place the board over the base and screw the nuts.
Step 21: Make Space for LCD:
Mark the LCD size on the front cover of the enclosure.
Cut out the marked portion by using a dremel or any other cutting tool.After cutting finish it by using a hobby knife.
Step 22: Drill Holes:
Drill holes for mounting the LCD,Led indication panel,Reset button and external terminals
Step 23: Mount Everything:
After making holes mount the panels, 6 pin screw terminal and reset button.
Step 24: Connect the External 6 pin terminal :
For connecting the solar panel,battery and load a external 6pin screw terminal is used.
Connect the external terminal to the corresponding terminal of the main board.
Step 25: Connect the LCD, Indicator panel and Reset Button :
Connect the indicator panel and LCD to the main board as per schematic.(Use female-female jumper wires)
One terminal of the reset button goes to RST of Arduino and other goes to GND.
After all connections.Close the front cover and screw it.
Step 26: Ideas and Planning
How to plot real time graphs ?
It is very interesting, if you can plot the serial monitor parameters (like battery and solar voltages) on a graph on your laptop screen.It can be done very easily, if you know little bit on Processing.
To know more you can refer Arduino and Processing ( Graph Example ).
How to save that data ?
This can be done easily by using SD card but this include more complexity and cost.To solve this I searched through internet and found a easy solution.You can save data in Excel sheets.
For details you can refer seeing-sensors-how-to-visualize-and-save-arduino-sensed-data
The above pictures downloaded from web.I attached to understand what I want to do and what you can do.
Future Planning :
1. Remote data logging via Ethernet or WiFi.
2. More powerful charging algorithm and load control
3.Adding a USB charging point for smart phone/tablets
Hope you enjoy my instructables.
Please suggest any improvements.Raise a comments if any mistakes or errors.
Follow me for more updates and new interesting projects.
<p>great instructable deba....is there a way to make the maximum amperage 30a </p><p>or more?</p>
Great job dude! But for everyone that builds this I have a great advise! For the solar and battery &quot;sensors&quot; use a slightly bigger capacitor! For me 22uF works the best! Great project dude! Keep tinkering!
<p>I'm looking to use this charge controller design for my own system use.<br> My battery will be at 12VDC but my load will be a 5 VDC load. For this <br>application is it as simple as adding a DC to DC buck converter to step <br>the voltage down to my load voltage?</p>
<p>Excellent Project! I would love to make it. Instead of the 12V lead acid battery I would like to use 3 18650 batteries in series so that the minimum and maximum voltages are 11.1V and 12.6V .What are the modifications that I should make? Would the same charging algorithm work for these Li-Po batteries as well? I would be using a 10W 12V solar panel.</p>
<p>Thanks !</p><p>The charging algorith for lithium battery is different.So my code will not work.</p><p>You need a 3S balance charge for charging your battery pack.</p>
<p>Thanks!</p>
<p>Hi deba,I made solar charge controller following your this tutorial and now i have made a smart parking control and access. To watch video and know more about it ,visit my instructable profile. Thanks:)</p>
<p>Congrats !</p><p>Dude your work work is excellent !</p>
<p>Thanks!! :)</p>
<p>Dear Deba,</p><p>Here,if I use UNO board,what would be happen.</p>
<p>You can use the same code.It will work</p>
<p>Deba,Pls send me your mail address.My one is cgayanath@gmail.com</p>
hi Deba, can I use Arduino Uno? Or do I have to change some components if I use uno?
<p>Yes, of course you can use Arduino uno</p>
can i use a power supply instead of solar panel ?
<p>i have strayed away from solar mostly because the wattage to dollar ration is so high. im looking to go motor generator on a 48 volt system recharging with ordinary 12 volt alternators giving me an equivalent of over 400 amps return and allowing me to safely recharge my battery pack in a relatively short period of time. first generation is running on Propane, but i am hitting some walls on on demand hydrogen production and mostly storage. my battery pack is 1250 amp hours and my recharge time is generally 4 hours. recharge run time at approximately once every 9 days depending on the season. also most appliances are now running on propane to minimize my electrical output. im not a huge fan of Solar but i am of power invertors. you seem to have a better grasp on pulse width modulation have you considered a higher voltage invertor and or any any method of using PWM technology to create stable power from a higher voltage say 96VDC and creating a PWM circuit to control the excess voltage of the battery to create stable A/c voltage at either 120 or 240 VAC? and what about if it could be stabilized by going to 1250 VAC then using a common transformer to bring it back down to 220VAC at the typical 1to 5 ration. maybe even decreasing the battery size and going to a higher VDC. if so then can we use PWM to set the HZ and control the input to 1250 and have it stabilize itself in the power transformers that are now currently readily available. food for thought and discussion. criticisms are welcome. keeps me out of trouble with unforseen problems. </p>
<p>hi deba,,in current sensor calibration in code you used 0.04882 based on 5v Vcc calculation right.so if i measure 4.50 Vcc i need to calculate new based on 4.50 Vcc.its true?so from my calculate i get 0.04395,its this value i replace on the code.because no load condition my LCD display current value around 2 amp.</p>
<p>Could I charge a bank of NiCd batteries with this? of course the voltage of the bank would be 12v</p>
<p>hi, i want to ask somethin, if add piezo sensor become a generator same function like solar panel, what about the circuit still same or need add some electronic.<br>thank you</p>
<p>Hello everyone. I would like to make this circuit but I want to have two power sources to charge the battery. One is the solar power and another one is AC main. The solar power will charge the battery if the PV voltage is above 18V. If the PV voltage is below than 18V (rain, night, cloudy), the AC main will charge the battery. Anyone can help me with the circuit and Arduino programming? Thank you very much. </p>
<p>Hi Deba. I need to make this circuit using <strong>wall power </strong>instead of solar power, much like a mobile phone charger. I need to have about 800 mA (peak) plus a bit of current for charging. Seems like this contraption of yours will work for my purposes. There are plenty of mobile phone charger builds on the internet, but none with load sharing! The load I have is a Nano, a servo and 2 white LEDs. Any help please?</p>
<p>Oh yes, I see the night time part of the charging cycle in the graph - that's a problem. How do I make the thing forget that it's day or night?</p>
<p>Note: the circuit is working of wall or battery power, I just want it to have power management and charging, with wall and battery as alternate inputs and battery and load circuit as outputs. You can see my fruity endeavours so far at </p><p>https://forum.arduino.cc/index.php?topic=425890.0</p>
<p>I know this is anti-planet, but it a self preservation home security type deal, so it is pro-safety.</p>
<p>Hello,</p><p>I've made it.</p><p>This is my design for who need.</p><p>For 1 layer PCB, 150X100mm</p>
<p>can you upload the code for both of these?</p>
<p>Can you connect the A0,A1,D2,D3 directly to the Arduino Nano board without using the external wire connection ? It will make it more neat and clean.</p>
<p>Hi deba168</p><p>Yep, but 2 layers only. Impossible with one layer</p><p>Always 150X100mm</p>
<p>hi lioneim</p><p>this is 2 layers?</p>
<p>The diode TVS P6KE36C ?</p>
<p>Not in this design because i've the protection in the solar panel directly and no fuse because mine are wired...</p>
<p>Very good! Thanks so much!</p>
<p>Nice work, Thanks.</p>
<p>Thank You so much for sharing the PCB.</p><p>I am really happy to see it.I am sure it will be helpful to all.Keep it up :)</p>
<p>Dear Deba:</p><p>First of all, i want to ask you some important questions, your answer will be so important to remove the some confusions.....</p><p>Question 1:</p><p> I Make small test...I have 12V Lead-Acid battery i measured the voltage which was 12.3v....then i applied charger of voltage 13.45v on the battery terminals for 1 second....then i remove charger terminals.....I measured the voltage on battery terminals immediately the result was 13.3V and decreasing then after around 3-4 minutes the voltage of battery became stable at 12.4V......repeat this test for 6V battery and the time was 1.5 to 2 minutes .....so i think that this was the relaxation time for battery.......</p><p>The question is how could measure the battery voltage during charging although the battery needs relaxation time to measure the accurate voltage ??? if you measure the voltage after short time or during toff this will gives you wrong readings.</p><p>Question 2:</p><p>In bulk charging, to provide constant charging current, you need to increase the charger voltage gradually.....but if you applied constant voltage, the current will not kept constant</p><p>thanks </p>
<p>Hello</p><p>I want to achieve</p>
<p>How would I change the circuit in order to accomodate a larger battery pack such as a 48v 400Ah battery pack (four series connected 100Ah batteries)</p>
<p>The problem that i am facing is that whenever the mosfet q1 turns on the panel gets connected to the voltage divider circuit of the battery and then it first measures the panel voltage excluding the drop and shows full charged battery and blue led turns on and after that it measures the battery voltage and shows the battery status.Is it normal or there is some problem .Reply Please.All in all it was a great project :).</p>
<p>Thanks </p><p>This is normal.You don't have to worry about it.</p><p>A PWM signal consist of ON and OFF time period.So when the MOSFET is ON the solar panel is shorted to battery, so voltage drags to battery voltage and when MOSFET is OFF the solar panel is output is open.You are getting solar panel voltage.</p>
<p>When we connect battery to solar charger, so the voltage at battery terminals shows the voltage of solar charger. Then software will also read the same voltage then how can we cut off charging in this case because as soon as we stop charging, arduino now will read the actual battery voltage which will be low so it will again start charging. Didnt you faced this kind of situtation?</p>
100ms is very less time so this wont happen
<p>As you can see in the image, solar volt is 13.7 and battery is 11.97v/12.0v which is correct but suddenly it shows solar volt: 13.06 and battery 13.04 which is wrong. SO how to protect from overcharging in this case. </p>
<p>Facing the same problem. How did you solved it.?</p>
Just add 50 or 100ms of delay just before measuring the battery voltage <br>P.S:i have interfaced a clock and sd card and used python to draw the graph of battery and panel voltage(its smart solar charge controller?)
<p>I tried adding the delay but it still shows solar voltage sometime.</p>
<p>hi , how I can do this project in simulation?</p>
<p>I don't know.Never tried yet :)</p>
<p>is there any alternative model of p-mosfet that can be used in order to build this project?</p>
<p>You can use a MOSFET according to your requirement.There is no restriction to this MOSFET only</p>
Superb
About This Instructable
460,361views
1,862favorites
License:
Bio: I am an Electrical Engineer.I love to harvest Solar Energy and make things by recycling old stuffs. I believe &quot;&quot;IF YOU TRY YOU MIGHT ... More »
More by deba168:3 Useful Things From an Old Laptop DIY Mobile Boombox DIY Portable Mini Refrigerator
Add instructable to:
