Introduction: ARDUINO STROBE WITH ARDUINO UNO VERSION 1
Picture of ARDUINO STROBE WITH ARDUINO UNO VERSION 1
THIS IS MY FIRST INSTRUCTABLE SO I WILL PRESENT ARDUINO STROBE SO LETS START
Step 1: THE MATERIALS
Picture of THE MATERIALS
1 ARDUINO
1 USB CABLE
4 LEDS
4 CABLE
1 PROTOBOARD
Step 2: THE CODE
Picture of THE CODE
void setup()
{ pinMode(13,OUTPUT); }
void loop() {
digitalWrite(13,HIGH);
delay(50);
digitalWrite(13,LOW);
delay(50);
delay(50);
delay(50);
Step 3: THE CIRCUIT DESIGN (FRITZING)
Picture of THE CIRCUIT DESIGN (FRITZING)
THIS IS THE CIRCUIT THAT YOU NEED TO BUILD
Step 4: THE REAL CIRCUIT
Picture of THE REAL CIRCUIT
THIS IS THE REAL CIRCUIT
WE ARE GOING TO USE THE NEXT PORTS
DIGITAL 13
GND
3.3 VOLTS
Step 5: PLUG TO YOUR COMPUTER
Picture of PLUG TO YOUR COMPUTER
REMEMBER THAT YOU NEED TO PLUG IN THE PORT THAT YOU HAD SELECTED
Step 6: DOWNLOAD THE CODE
Picture of DOWNLOAD THE CODE
Step 7: SEE THE LEDS GLOW
Picture of SEE THE LEDS GLOW
CONGRATULATIONS YOU HAVE BUILDED AN ARDUINO STROBE THANKS FOR WATCHING
ibenkos (author)2014-10-18
Smart idea! I really like this project. Thanks for shearig :)
ktrantham (author)2014-09-10
I think you did great! For your first time, GJ. But I have to make a few suggestions,First of all you need resistors in this circuit! Even if you are using 3.3V. 100 ohm or so will work fine. And as domints stated, if you draw more than 40mA off any pin on the arduino and your could damage it or ruin it all together. Lastly your coding/Sketch in the Loop, from the 5th line and after , is defunct. It repeats the same commands as the first lines of Loop code. Basically it (your led project) will function the same without repeating those lines. The loop will loop doing the same so its pointless extra lines of code. Overall good job
domints (author)2014-09-07
You shouldn't do it like this because of too high current on ATmega pin.
MsSweetSatisfaction (author)2014-09-07
Cool, I shall have to think about building it for my next dance party! Thanks for sharing!
About This Instructable
1,017views
18favorites
License:
Bio: I love to do electronics projects, and also to share them
More by ofernandez5:How to Wire an Arduino With a Led (Como Conectar Un Arduino Con Un Led)Recycle the Electronic Ballast From  Compact Fluorescent Lamp (Reciclar La Balastra Electronica De Un Foco Ahorrador )Strip Traffic Light With Arduino
Add instructable to:
