3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
ASL: American Sign Language introduction
Step 6A few more involved signs
A few slightly more complex signs.
Frequency (as it applies to the electromagnetic spectrum, not to frequency of an occurrence):
Start by opening both hands flat, first raising the left hand to about shoulder height, thumb towards you and palm facing right and hold it there. Bring the right hand up, open and flat, thumb toward you but as you bring it up, bend the hand at the knuckles and making a circular motion brush the fingertips against the left palm in a counterclockwise direction. Then, with the right hand, sign an S, then a W then, with the left hand still holding a palm facing right position, point to the palm with the right index finger and then trace a sine wave out from the left hand in the air.
Resistance: Bring the right hand up and sign an R, and wiggle it back and forth a few times. Then sign an O, and then an R. Taking that right hand, open it if flat, palm outwards away from your body, fingers upwards, bring the left hand around and place it against the right hand, finger to finger, palm to palm. Move both hands together forward and backwards (away from and closer to yourself) a few times. Again, with the right hand, sign an O then an R. Now open the right hand flat again, palm facing left but somewhat downwards (about a 450 angle), and do the same with the left hand. Now you have both hands / arms crossed in front of you.
Vector: Sign a V with the right hand, bring the left hand up and over the right. Point with the index finger of the left hand as if making a line over the V and then wiggle the V back and forth slightly a few times.
Momentum: Bring the right hand up, flat & open and palm towards you, while bringing it up, start to bring the left hand up in similar manner. Pass the right hand out in front of the rising left hand, downwards, then back behind the left hand as the left hand follows suit and goes forward then downward, circling one another.
As with any language, this can only be barely touching on the subject, a mere getting one's feet a bit wet as it were. I do hope this is useful to someone, or at least interesting to some.
Here is another resource worth checking out: Deaf - Blind world signs
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
137
Author:Goodhart(Old as the hills...)
I am, most definitely older than 00010101 and to put it simply, still curious about nearly everything :-) I then tend to read and/or experiment in those areas - when I have the time... My two "spe...
more »
