Warning! There are several large capacitors in ATX power supplies, that will store a dangerous charge for a long time. Please let your power supply discharge, completely unplugged from the wall outlet, for a few days before opening it up. You can probably be seriously hurt, so please be very careful. I am not a lawyer, but I hereby release myself from as much liability as I can, for any sort of injury you sustain, or any trouble you get into.
Remove these ads by
Signing UpStep 1Background
Computer power supplies are Switch Mode Power Supplies (SMPS), which use high-frequency switching circuit elements to provide a high-quality output voltage, with good energy efficiency. One side effect of this technology is the minimum load requirement that each power supply has. In order to function properly, the power supply needs at least a very small electrical load connected to it. In other words, ATX power supplies will only work if you have something connected to it. We will be using a power resistor to provide this minimum load.
Also, modern power supplies do not simply have an OFF/ON switch, they have what is known as a "soft" power switch. This normally makes no difference to the user, as the computer behaves the same, but when you shutdown your computer, the motherboard can turn off the power supply when it has finished shutting down. This requires us to add our own power switch to the power supply chassis.
To protect our circuit from accidental (and careless!) short circuits, we will install some fuse-holders and fuses, which will disconnect the circuit supply lines if too much current flows. The size of the fuses are up to you, but a 1 amp fuse will work just fine for most circuits. You really should put fuses on all supply lines.
Update: While the diagrams show fuses on all voltage rails and no fuse on the ground line, when I actually built my power supply, I was young and foolish and only put a fuse on the ground wire. It's much safer and a better idea to put fuses on all signal lines and not the ground line. Thanks to many emails and messages on Instructables about this oversight.
I would connect as many of the wires as you can to the binding posts, but I only connected one wire per post. This determines the maximum current you can draw from the binding post (one wire can safely carry less current than a bunch of wires).
I also tried to convert my 350W ATX, but there are aome problems.
First of all I'd like to mention that I didn't a 10Ω 10W resistor, so I replaced it with two 22Ω 5W resistors in parallel. Is this fine?
When I turn on the switch of the ATX, the Stand By LED lights up. But when I short the green wire to ground, the fan spins for a second (or less) and then.... nothing. The Power On LED doesn't even light up. Firstly, I thought that my PSU is "clever". I thought that the fan was heat controlled. So, in order to test that, I connected an LED to the 5V output, using also a 330Ω resistor. And guess what... The same exactly thing happened. It just blinked.
Any ideas of what's going on here?
P.S. The PSU certainly works, because I just unplugged it from a working PC!
1. The pair of 22 ohm 5W resistors in parallel will have an equivalent resistance of 11 ohms. This will draw I = V / R = 5v / 11 ohm = 0.45 amps, making for TOTAL power dissipation of P = V * I = 5v * 0.45A = 2.2727 Watts, which is split between the two 5W resistors, so you should be just fine.
2. That's a good idea about the PSU being too clever, and I've heard from other people that that happens. It sounds like the PSU thinks it has no load (and shuts off), but if you have the 0.45A load on the 5v line that should work ok I would think.
Perhaps you can try moving that load to 12V or 3.3V, or adding extra loads to those lines?
Good luck, let us know if you solve it!
I have an AT power supply, it was creating 11.43v from the yellow 12v wire. I wired a 12v globe to one of the black wires and one of the red (5v) wires. I put the multimeter on the 12v and ground wire while the globe was on. it read -12.21 I was wondering why it said negative? and also my lipo charger can handle 12v-17v, would it be ok if I put another globe on the 5v rail? or is one enough already?
cheers
I've heard that on newer PSUs you also need load resistors on 3v3 so that matches with what you've said.
Yeah, with your 12v line being 13.14 volts that makes sense based on what I've heard and what I know about how these switching supplies actually operate. If you add a small load it should drop down to 12 volts. You can use a computer fan as a good 12v load if you don't have anything else. Hope that helps, good luck!
Just to confirm, you are still connecting the green wire to ground to turn it on, right? Even with the LED in your rocker switch, the green wire needs to be connected to ground to signal the PSU to turn on.
Connect the 5vS wire to one of the 5v wires, and then connect one of the 10 ohm 10 watt resistors between 5v and ground.
Connect the 3.3vS wire to one of the 3.3v wires, and then connect another 10 ohm 10 watt resistors between 3.3v and ground.
Use your rocker switch to either leave the green wire disconnected, or connect it to ground. If your switch has an LED you can power it from the 5vSB (5v standby, which is always on) wire if you want it to be lit up whenenever it's plugged in, or power the rocker switch LED from the regular 5v line if you only want it on when the switch is set to "on".
Does that make sense? Good luck, hope you get things working!
you're working on a PhD in electrical engineering. if your not an expert, who is? :)
You probably need to have a 10 ohm 10W power "sandbar" resistor between the regular red wire 5v line and ground. You might also need to do the same on the 12v wire or the 3.3v wire. Separate resistors for all lines you want to add a constant load. Different PSU's have different loading needs, you'll have to experiment a little bit. I've even had some people report not needing any load at all!
Some power supplies have "sense" wires which need to be connected to their corresponding voltage wires, but these are uncommon. I think you said you have one, so connect the 3.3v sense wire to the 3.3v supply line.
If the power supply doesn't come on (meaning you can measure proper voltages at the 5v and 12v lines, as well as the PG wire goes high (5v I think), then your power supply might be broken. Good luck!
(also, there are lots and lots of different areas in EE, and my area of digital electronics and IC chip test are pretty far from analog circuits and power electronics :- )
I've looked around, and I think I could just connect them the wires they were connected to.
The extra pink and brown wires are probably "sense" wires that are used to read-in the outputted voltage to make sure each wire is reasonably close to whatever voltage it's supposed to be. I would connect them to the 3.3v and 5v rails again as they were.
I used a 350W ATX power supply to power a CD car radio and an automated aerial over 12V and here's the results:
- the 3.3V line had to be loaded with almost 2 Ohms of resistance!
The reason is this: the 12V are supplied from the same transformer as the 3.3V and are not regulated as opposed to the 3.3V line. So when I cranked up the volume the PS would shut down since the load on the 12V caused the 3.3V to dip. But since the 3.3V line had no current going out the PS decided to shut down. So in order to get any good power out of the 12V line the 3.3V line should be loaded with at least 1 Amp.
Now I can draw almost 3 Amps on the 12V line without a problem.
PS: your mileage might wary with the load resistor :)
So my brother-in-law is an R/C plane hobbiest, saw my little project last night, and really wanted one of these to charge his batteries with. so with another PSU i had laying around, i first tested it by jumping "PS_ON" and ground, and it worked like a champ.
after all internal mods were done, i went to test the PSU before giving it to my brother-in-law and nothing......my +5vSB LED comes on but thats it. i did notice that this PSU had a +3.3vS line so i connected it to the +3.3v wires in the PSU, no worky worky. it puzzles me that this PSU would turn on before taking the PSU "apart" but not now. im going to take the switch out of the loop tonight and solder the "PS_ON" to ground, but other than that any ideas? maybe i have to connect the 3.3vS wire to the +5.5v line?
just a little background on my self, 9.5 year aircraft avionics tech with basic Electronic Principals knowledge. I can use an "O" scope and DMM like nobody business, and know OHM's Law very well. i appologize for not doing anymore troubleshooting before posting this, but im at work and would like as many ideas as possible to go home with to troubleshoot. thank you everyone in advance!
Yeah, that's a strange case for your second PSU, that it would originally work just with shorting PS_ON to ground, but then when you did the mods that same thing doesn't work. Odd.
Perhaps you created a short by accident when you did the modifications? Did you cut down the extra wires near the PCB? Could a stray strand of wire shorted against the case or another wire? I'd look for that.
I've heard that some newer power supplies might need loads on the 3.3v line so that might be something else to try?
PS. You did plenty of troubleshooting, definitely more troubleshooting than most people do before posting. Good luck, let us know how you get it working!
P.S. do you have any experience with server PSU's? im about to buy one i found online for $15 that has a 32amp rating on the 12v rail. for R/C hobbyists that charge batteries with these its perfect. wish me luck :)
I haven't played with server PSUs before, but I'd hope they operate in a similar fashion, but might have a different pin out, you know? Probably would still have a pin for "ground to turn it on" but it might be in a different place in the main connector. Let us know what you find out!
I'm also building a reprap prusa, which needs a lot of current at 12v for heating coils and the like, so I picked up this 12v 30A dedicated PSU from Amazon for about $40 including shipping. If you can get your server PSU working that'd definitely be a better deal. Good luck! http://www.amazon.com/Universal-Regulated-Switching-Computer-Project/dp/B004CIW8LA/ref=sr_1_1?ie=UTF8&qid=1325513725&sr=8-1
