ATX to Lab Bench Power Supply Conversion
Step 5Power Resistor
Power Resistor
Most modern ATX power supplies require a small load to stay in the ON mode. I added a 10 ohm, 10 watt resistor between +5V and ground to provide this small load. It is strapped to the back wall of the power supply, where it should get plenty of air flow. It doesn't actually even get warm during normal operation so it's not a big deal.
14 comments
Jul 5, 2011. 9:08 AMaessam1 says:
there is a problem with me
the 10 ohm 10 watt resistor is not available in my country
what can i use instead of it
i have grounded the green wire
but the fan didn't start
and i measured the outputs with a multimeter
and they were 5v and 11.7 and this is good
but a small led with a resistor across the +5 and GND
didn't glow
so what can i use as a replacement for 10 watt resistor ?
PS
my local store is
http://ram-e-shop.com
Jul 7, 2011. 5:24 AMaessam1 says:
really strange isn't it ?
i have tried the led on another known power supply
and it worked fine
i don't know where is the problem
and a question plz
how many resistors should i use and there values ? (1/4 watt)
and thanks for your reply
Jul 9, 2011. 11:12 AMaessam1 says:
thx very much for the idea ,it has worked
but :D i made two biiiiiiiiiiiiiiiiiig mistakes
first : i didn't notice that the fan works by the time i ground the green wire :D
second : about the led i have tried it again and it has worked , maybe there was connection error on the bread board
and i don't know what to say except that it was all my fault
but at all thx for all
Jul 8, 2011. 2:11 PMaessam1 says:
i will try the led test now
and I'm going to buy resistors tomorrow ( in sha2 Allah )
and i will try them and tell you
thanks again
Jan 3, 2010. 5:31 PMmotoruser says:
what will happen if I did not add 10 ohm resistors 10 watts? whether the reduced performance of the power? thanks
please CC to my e-mail at: y_heroe@yahoo.com
May 25, 2011. 12:40 PMSitnalta says:
You will damage the semiconductors in the PSU, which will lead to a very erratic output voltage, which may damage whatever you're trying to power.
Feb 18, 2010. 9:26 PMlokivoid says:
I have been using a illuminated rocker switch rated at 12VDC/30A for both toggleing power and putting draw on the 5v rail.
Mar 1, 2009. 5:40 AMValence_4 says:
Do not tie thw 10 watt bleeder resistor with insulated wire. The resistor may melt the wire's insulation and will come loose. It will also smell bad !
Oct 15, 2009. 9:00 PMpjharro says:
Your telling me you have access to a drill, wire strippers, fuseholders, terminals, soldering iron, and LEDs, but you don't have any wireties!!
I find that very amusing :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:matthewbeckler
A PhD student in Electrical and Computer Engineering at Carnegie Mellon University in Pittsburgh, PA.
