3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
ATX Power Supply - the elegant way to adapt to benchtop use...
 If you want to use an ATX power supply as a benchtop unit, without hacking it to pieces or risking fire and electrocution, then this approach is definitely for you.
NEWS: due to increasing inquiries I have made this item in to a complete kit. Let me know if you or your college / lab are interested. Full schematics BOM and assembly docs are provided too.
Step 1Acquire the ATX PSU Benchtop Adapter PCB
 This PCB has been specifically designed for this purpose, and is layed out for access to all the ATX supply votlage rails, even the standby supply and the "power good" signal. This PCB can be acquired from http://www.jordandsp.com/index.php?p=1_2_Projects. Since there was enough interest in using it, I had quite a few manufactured to get the price down.
25 comments
Jan 4, 2012. 9:12 AMLegoman132 says:
I got mine and put it together yesterday, and it works MUCH better than just shoving wires in the connectors. However, when I reinforced the 12 and 5v traces with solder (those are what I plan on using heavily), there was a tiny error in the solder mask exposing a sliver of ground plane next to the 12v line. This shut my ATX down initially, but I eventually removed enough solder to where the current blew the short out with a nice pop, after which it worked perfectly. Has anyone else had this happen?
Nov 9, 2011. 1:22 PMbrusho150 says:
HI!
I am new in electronic engineering and wanted a lab power supply will you please tell me that how Can we add a potetiometer(voltage regulator),rheostat, voltmeter and ammeter to calculate and vary voltage and current?
Thanks
Sep 28, 2010. 12:50 PMdarthneo says:
Can i ask where you got the banana posts?
They seem quite expensive on electronics websites (digikey, mouser, jameco)
Ebay has 5 (5 different colors) for 5.30$, i wouldn't expect these to be so expensive...
Jan 26, 2011. 12:29 PMdarthneo says:
Oh, thats cool! i have put all my electronic projects on hold because of college and work, but i ended up getting, i think, 12 banana posts for 10$ off ebay.
Out of curiosity how much are you selling the complete kit for?
May 17, 2011. 10:18 AM1clicc says:
I went to your website but there's no where to order one. Can you point me to the right direction to where i can acquire one? Thanks.
May 17, 2011. 11:16 AMdarthneo says:
I think you just send him $20 through paypal and he sends you one
Jan 18, 2011. 2:50 AMmerlinmalone says:
Nice little project. As an electronic engineer I was planning to do the same, then came across your design. A couple of questions:
1. What are the outputs rated at (without adding solder to the traces)?
2. Do you have problems with the nuts on the posts shorting out between the copper planes on the PCB? In the pictures on your website they seem to overlap in places - maybe if you do another version increase the space around the terminals.
As a suggestion, rather than putting it in a box it might be nice just to have a sheet metal 'L' shape made up which you can bolt both your board and the ATX supply to - it doesn't really matter that it's open and makes it a neat unit.
Also, not sure that adding vias around the holes "offer increased strength for tightening up screws over" - removing material decreases strength, but it looks nice :)
Jan 18, 2011. 4:03 AMmerlinmalone says:
I don't think you'd want to draw 40A on the 12V (down two wires) - you might release the 'brown' smell. :)
Looking at the image on your site: http://www.jordandsp.com/images/board_and_multimeter.jpg the nut under the yellow terminal in particular looks like it overlaps the plane gap. Maybe the chamfer on the nut is enough to clear it though.
I personally probably wouldn't use the croc clip points (nice feature for many though) and would mount the board on the back of a metal panel using the terminals. Depending on the length of terminal you use you should be able to clear the components on the board, maybe need some stand-offs on the mounting holes..
A good source for the 4mm terminals is Farnell if you have one in your country. Links to the relevant UK parts: http://uk.farnell.com/jsp/search/results.jsp?N=1011020+401&Ns=PRICE_PLS_006_PRICE1|0
Jan 18, 2011. 2:54 AMmerlinmalone says:
Also, to increase the current capacity of the +12V rail (as it's only 2 pins on the ATX connector) you could add sockets for one or more of the disk drive connectors.
Jan 4, 2011. 5:15 PMalfa2red says:
You done some thinks nice. But if all the part was installed inside like the first project has done years ago it look better.
Sep 28, 2010. 3:51 PMChestum says:
great work, looks great. sent ya an e-mail ( Curtis )
May 1, 2010. 10:05 AMThe Ideanator says:
This is a lovely idea, but for $20, I'd want a nice little acrylic case that can be attached to the psu box with minimal effort (some drilling isnt bad)
Here's a suggestion for revision 2, on the connector side of the board, flip where the holes and connectors are so one could easily mount it on the psu with standoffs (that you might throw in to a kit)
Apr 24, 2010. 10:51 AMfrollard says:
That's really cool!  How would you feel about open sourcing the schematic for the DIY among us?
May 1, 2010. 9:49 AMThe Ideanator says:
Don't forget the pcb images.
Apr 24, 2010. 10:54 AMfrollard says:
Oop:  double post...
How does this circuit deal with the required load on the 5v line?  My understanding is the supply will start cooking itself if it doesnt have any load to regulate for.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:jordanyte
