ATX Workbench Power Supply Project
11,097
157
15
Posted in TechnologyElectronics
Introduction: ATX Workbench Power Supply Project
About: Computer programmer and electronics tinkerer extraordinaire. Writing coding since the 4th grade(1974). Scuba Dive Master, Eagle Scout.
This instructable will show you how to make a professional looking bench power supply. A power supply that is fuse linked. A power supply that if and when the ATX power supply goes bad you can just unplug and replace it.
Step 1: Parts Needed
Step 2: Install Parts in Case.
Install all binding posts, fuse holders and switch.
Hot glue LED holder and LED in place.
Cut and strip 6 (18ga) wires 2-3/4” (5 red – 1 black).
Solder wires to the fuse holders.
Solder wires to the binding posts.
Purchase/Harvest ATX power supply and 20/24 pin ATX power supply extension.
(NOTE: The wire colors do not always match)
Cut off MALE side of extension and strip ALL Wires 3/8”
it’s best to refer to the wires by PIN NUMBER (see chart)
Step 3: Cut and Pair Wires
Pair up wires for soldering.
Solder and heat shrink the ends.
Connect the ATX power supply.
Install screws for the ATX power supply.
Double check wire clearance (Pinched wires are no fun).
Attach rubber stick-on feet to bottom corners.
Step 4: ATX Plug Breakout
Wire Position Chart
Step 5: Step by Step
Steps to follow
Step #1 Install binding posts, fuse holders, toggle switch and LED(hot glue in place) as shown in figure 5
Step #2 Cut wire (18 ga) 2-3/4” long, 5-red / 1-black, strip and solder to fuse holders and to bindings as shown in figure 6, 7 & 8
Step #3 Cut MALE end off the ATX extension and strip ALL wires as show in figure 10
Step #4 Pair up wires for soldering as show in figure 11 (follow the above WIRE PAIRING CHART)
Step #5 Solder the wires to the fuse folders, toggle switch and LED as shown in figure 12
  • #5-a Solder 10 watt power resistor to PIN 3(COM/BLACK) and 4(+5VDC RED) – This creates a load on the power supply
  • #5-b Solder PIN 5, 15, 16 & 17(COM/BLACK) together on fuse holder for BLACK binding post(COM/GND)
  • #5-c Solder PIN 1, 2 & 11(ORANGE & BROWN WIRES) together on fuse holder for GREEN binding post (+3.3VDC)
  • #5-d Solder PIN 19, 20 & 6(+5VDC/RED) together on fuse holder for RED binding post (+5VDC)
  • #5-d Solder PIN 10 (+12VDC/YELLOW) on fuse holder for YELLOW binding post(+12VDC)
  • #5-e Solder PIN 12 (-12VDC/BLUE) on fuse holder for BLUE binding post(-12VDC)
  • #5-f Solder PIN 18 (-12VDC/WHITE) on fuse holder for WHITE binding post(-5VDC)
  • #5-g Solder PIN 7 (COM/BLACK) to 330 ohm resistor and then to CATHODE (-)side of LED (SHORTEST)
  • #5-h Solder PIN 8 (POK/GRAY) to ANODE (+)side of LED (LONGEST)
  • #5-i Solder PIN 13 (COM/BLACK) to center post of toggle switch
  • #5-j Solder PIN 14 (PS-ON/GREEN) to lower post of toggle switch (so toggle down position is OFF)
Step #6 PIN 9 (+5VSB/PURPLE) NOT USED – Cover with heat shrink tubing
Step 6: Final Assembly and Label
Install the cover.
Install cover screws (#6 or #8 pan head 1/4”).
Add a label for voltages and power switch on/off.
The voltage label was made using a Brother P-Touch label maker.
“3.3V(6 spaces)5V(6)12V(6)-5V(4)-12V(5)GND(2)OFF”
Trim the left side of the 3.3V and right of GND on each side to fit.
Attached is a PDF with all the steps and links.
Hope you enjoyed this instructable.
Cheers,
Jeff
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Microcontroller Contest
    1 Questions
    Is there a good reason to fuse every outlet ?
    When I created it I was working on a multi voltage application that was using 12V to run relays and 5V to run sensors and 3.3V to run a processor and if the 5V sensor grounded out the 3.3 would still continue to run.
    15 Comments
    Jeff,
    really like the case, can't find anything similar here in the UK...do you still sell them on ebay?
    Very nice. Did you follow my example and use your own case?
    Send me some inside pics.
    Awesome Job,
    Jeff
    Thank You!!
    I have some already built and some enclosures if you want to build it yourself.
    Let me know if you are interested.
    Jeff
    Welcome to the club: Just a note to let you know I have added this instructable to the collection:
    Encyclopedia of ATX to Bench Power Supply Conversion
    >> https://www.instructables.com/id/Encyclopedia-of-A...
    Take a look at about 70 different approaches to this project. This topic is one of the more popular of all instructables.
    Will yours be the last of this year. Maybe.
    Glad you liked it. I have been making these and selling them for about 4 years now.
    Cheers,
    Jeff
    Hi everyone,
    I have received a couple 3-4 comments in emails about the colors not matching on various power supplies or missing pins on some other supplies as well. As I stated above you can not rely on the colors, go with pin numbers. This instructable is for standard ATX power supplies. If you are trying this with a custom or a manufacturers specific supply I suggest you contact the manufacturer or google the pin layout and cross reference to the charts in my example.
    Check 1st, Check 2nd and Double Check again before you connect anything.
    Cheers,
    Jeff
    I am using Old PC power supply as my test bench power supply
    I have made these several times before. It is the best way to re-use for old PC parts.
