How does it work?
The ATtiny85 controls 2 channels of servos (4 (in parallel) on one channel, 2 (in parallel) on another channel) which will open the gate of each one of the food containers. If you want, you can easily change this configuration by modifying the Eagle Layout I made.
The Feeder will operate on a DC power supply from 6 to 9V.
(Be aware that using a higher value of supply voltage will result in need of heat dissipation for the voltage regulator)
I am sorry for the bad image quality (all were HD but it seems that while uploading they get compressed).
This is my first tutorial, any help is appreciated.
I hope you like it!
Remove these ads by
Signing UpStep 1: Get the parts
- 1 Microcontroller : ATtiny85 / ATtiny45
- 1 DIL8 Socket
- 1 Resistor (330 Ohm or 220 Ohm, it's for the LED)
- 1 Voltage Regulator 7805 (look for a low dropout voltage regulator if powering with 6V, LM2940CT-5.0 is fine)
- 1 DC power adapter
- 2 Capacitors (10microFarad is fine, they're for the voltage reg.)
- 1 to 6 Servos (Small ones preferably)
- 1 to 6 Servo extention leads
- Some wire
- Some thin balsa wood
- Transparent plastic tube (This is the food container)
- Metal wire (aluminium wire)
- Glue
- Double sided sellotape or velcro
- 1 Project Box (70x50x25 mm)
- 1 SPST Switch
- 1 LED
- 1 Self-adhesive PCB Mounting Pillar (if you plan to use one make sure that it's small enough to fit inside the box)
- 1 Barrel Jack
- 1 Male pinhead connectors row
- Stuff to make your PCB : Copper board, etchant, laser printer, iron, soldering equipment, etc.
Appart from this list and if you don't have an AVR programmer, you will eventually need the components of the following tutorial:
http://www.instructables.com/id/Program-an-ATtiny-with-Arduino/
Those are required to program your ATtiny with an Arduino Board!! (and that is how I programmed it)
Visit Our Store »
Go Pro Today »
he may never try but u dont wanna chance it
http://www.cunningturtle.com/wordpress/wp-content/uploads/2011/11/servo8bit_arduino_example.zip
but otherwise it still a nice instructable.
Otherwise a nice one :) shame I don't keep fishes anymore
