A(T)tiny StarBird
 by masynmachien
Featured
This Ible describes the design and build of miniature tribute to the 70’s StarBird toy by MB. It mimics the original Starbird’s sound effects, which is an electronic “engine” noise that rises in pitch when the craft’s nose is tilted upwards and lowers when the nose is tilted downwards. It also has a button to fire two red “main cannons”, accompanied by a classic space gun sound.
Here's a video:
The project features a self-made tilt switch and a resistive touch switch. The sketch and the circuit are kept quite simple. The intention is to use it in "starships" built by children. At this stage it is a module built by me (requires some experience in cutting printed circuit boards and soldering) and a paper StarBird silhouette coloured by my youngest daughter aged 4 to make it into a "starship".
I’m still working on a version where the circuit is to be built in a workshop for children aged 6 to 12 (where soldering is not practical with 20 kids). I hope their parents will forgive when they bring this noisy toy home. However my version is not only  smaller, but also less loud than the original one.
I’m also planning on making an even smaller one, based on a laser cut StarBird silhouette and a circuit made with Bare conductive ink or paint (something to share with my oldest daughter, Ibles member Tika.
Some words on how I came to doing this project:
When I was a kid MB created the StarBird especially for me ;-)
They even went through the trouble of making a box picturing a boy that looked just like me at that age. My parents offered me the StarBird and I played a lot with it. Later on, it became what was probably one of my first hacks, when I dismantled it to use the electronics in starship builds of my own. At some time, it became lost in space…
Last year I came across a StarBird in reasonably good shape at a good price and bought it for my youngest daughter. Not surprisingly my oldest daughter (and I) played with it too.
I wanted to build toys around the sound effect module again, but considered a vintage StarBird to precious to hack. When I recently picked up Arduino “making”, reproducing the StarBird sound effects became my first project.
When Ugifer’s Morse Throwie ible showed me how simple and cheap an ATtiny based circuit can be (THANK YOU UGIFER!), I started on planning to use them in my creative workshops for children. The StarBird light and sound effect again made the first project.
If you like this Ible, please give it your vote.
English is not my native language, nor are electronics and programming my core competence, so please feel free to point out any mistakes.
Step 1: Parts, Materials and Tools
Note: As we will be touching the bare wires when playing with the A(T)tiny StarBird, it is important to use lead free parts en solder (look for the "Rohs" label, which is about standard these days).
Parts and Materials::
an ATtiny 25, 45 or 85
an IC socket with 8 contacts
two 3 mm LEDs
a small piezo speaker (17mm diameter or smaller)
a 10mm steel ball
4 long connector pins (15 mm or longer)
two 100 Ohm resistors, ¼ W
three resistors around 10 MOhm (exact value is not critical)
a 3V coin battery (e.g. CR2032)
a battery holder for this battery
two pieces of prototyping printed circuit board, so called stripboard or “common bus” pattern (like this):
      - one piece about 90 mm long and 13 mm wide (36 holes long, 5 wide, tracks in longitudinal direction).
      - a smaller piece 13 mm wide and 15 mm long (6 holes long, 5 wide)
a small switch (preferably with angled pins for print mounting)
some clear heat shrink tubing, 1” nominal diameter, about 10 cm long
lead free solder for electronics
Tools:
a soldering iron for electronics
3mm and 6mm drill bits and a drill (or Dremel style tool)
small cutting pliers
flat nosed pliers
a small sharp hobby knife
an Arduino, breadboard and jumper wires or other hard- en software to program ATtiny
a computer
a heat source to shrink the shrink tubing (hot air gun, paint stripper...)
a hacksaw and sanding paper or file to cut out and finish the circuit board
For decoration:
Whatever you like, for example paper,  colour markers, scissors, (double sided) tape and a printer
mikered says: May 14, 2013. 8:17 AM
Cool - I'll have to make this
I did have the original as a kid and it was probably my favorite toy ever
 I bet my 7 year old nephew would love a tilt operated sound effect to go inside his lego...
spikec says: Apr 20, 2013. 4:13 PM
Nice job, I bet you kids loved it.
janw says: Oct 23, 2012. 12:49 AM
Nice!!!
papercrafter408 says: Sep 3, 2012. 5:30 PM
it reminds me of those little wind-up airline toys you get at the airport that make the turbine noises! :)
M.C. Langer says: Sep 2, 2012. 5:35 PM
Great project! :-)
Ugifer says: Aug 31, 2012. 8:22 AM
This is lovely - and I'm thrilled if any part of the inspiration for this came from my electronic fumblings. It's amazing what will spark off the imagination.
I particularly love the tilt-switch. Much more fun and instructional than using a bought one. I may well be using this project - or at least ripping off the tilt-switch - in return!
How many kits are you making? You could get 60 PCBs manufactured for these kits for $55 USD including shipping to Europe. It would make a lovely professional kit with those, although it would be for soldering, so I suppose not suitable for your workshops.
I had assumed you had entered this into "Hands on Learning" but I don't see it listed in the entries - maybe it's not yet been formally accepted yet. When it is then you can count on one vote at least!
masynmachien (author) in reply to UgiferAug 31, 2012. 12:21 PM
Thanks,
For now, it's in the LED Contest...
ynze says: Aug 31, 2012. 3:27 AM
Cooooooooooooooooool!
masynmachien (author) in reply to ynzeAug 31, 2012. 4:42 AM
Thanks,
If have kits left from the the workshop I'm preparing for October 13th, I will bring them to the Maker Faire 050 in Groningen the next Saturday. :-)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
