Introduction: ATtiny Watch Core
Picture of ATtiny Watch Core
This instructable show how to use an ATtiny85 to create a tiny watch core that can run over 1 year before recharge or replace battery.
The instruction to make the watch case may be in next instructable.
I have made a few Arduino watch before, but I found the watch using ATmega boards or ATmega chips are a little bit too big to wear. So I would like to make it with a smaller chips.
I have choose ATtiny85 just because I can easy to get one.
The challenges for using ATtiny85 are:
  1. It only have 8K flash memory
  2. It only have 5 IO pins (I would like to keep the 6th IO pin as reset for easy re-programming)
  3. Since the above 2 limitations, it is hard to find a complete source code for an ATtiny watch on the web
I design to develop a tailor-make code to complete these challenge, it include:
  1. Power control to make the watch can run over 1 year
  2. Revise a time library to utilize WDT for power saving purpose
  3. Trim down a display library to meet 8K binary limitation
  4. Customizable font type
  5. Basic UI for adjust time just like a normal digit watch
Step 1: Preparation
Picture of Preparation
MCU
Today core subject, ATtiny85.
ISP
Any ISP that can program ATtiny85.
Battery
In general expectation, a watch should run over 1 year without charging or replace battery. For my simple measurement of power usage and the battery specification, CR1220 can only run about half an year, CR2016, CR2025 and CR2032 can run over 1 to 2 years representatively.
Display
Since the number of IO pins of ATtiny85 is very limited, I design display and further modules should all run in I2C. Power consumption and source availability are also important factors. I choose an OLED screen drive with SSD1306. It can find in 3 different sizes, 64x32 is the smallest one. (another sizes are 128x64 and 128x32)
Other Parts
A battery holder, a small bread board, some bread board wires, two buttons and a power switch (optional).
Step 2: Assembly
Picture of Assembly
Connect all the parts on the bread board:
ATtiny85
pin 1: not connected
pin 2: set button, other button pin connect to GND
pin 3: up button, other button pin connect to GND
pin 4: GND
pin 5: OLED SDA
pin 6: not connected
pin 7: OLED SCL
pin 8: VCC
Also connect battery and OLED board to VCC and GND.
Step 3: Power Down, WDT and Time
Picture of Power Down, WDT and Time
When MCU and OLED turned on, it consume about 6 mA.
In order to make the watch can run over 1 year, I will use the MCU most power saving sleep mode, SLEEP_MODE_PWR_DOWN, when user not in use. According to my cheap power meter, it show 0.1 uA if disable all the function. But It still need to enable WDT for time keeping, after enable WDT, it show 4 uA. Assume MCU and OLED auto sleep after 5 seconds and user view the watch 12 times every day in average, the watch will consume about 0.2 mAh per day. ((0.004 mA * 24 hours) + (6 mA * (5 / 60 / 60) hours * 12)) So a 150 mAh CR2025 battery can run 750 days.
The time source code mainly come from PaulStoffregen. However, the power down sleep mode will stop the normal timer, use millis() function for time keeping is not valid. So I keep another variable to replace millis() function. For each WDT interrupt, it increase a certain value. The increment value depends on the WDT interval settings and the chip's oscillator. When using 1 second WDT interrupt, my chip's calibrated increment value is 998 (around 1000 milliseconds).
And also I have added the readVcc() function for monitoring the battery status.
Ref.:
WDT and power related: http://www.re-innovation.co.uk/web12/index.php/en...
time function for Arduino v1.4: https://github.com/PaulStoffregen/Time
readVcc: http://www.re-innovation.co.uk/web12/index.php/en...
Step 4: I2C Display
The code is reference from DigisparkOLED, but since its example code complied size is over 6K, the complete example cannot put on their ATtiny85 product, Digispark or Digithumb. (it require to comment out the bitmap code for running) The complete example can only run on their another product, Digispark Pro. (it have around 14K flash available)
Here are something I have revised or rewritten:
  1. Trim out many unused data, including font and bitmap
  2. Init SSD1306 setting according to the SSD1306 data sheet page 64
  3. Try to support all known resolution (64x32, 128x32, 128x64)
  4. Support custom font
  5. Function for turning OLED on and off for power saving purpose
It use TinyWireM library, but it have a bug (reported), you need revise one line of code in write() function to cover this:
if (USI_BufIdx >= USI_BUF_SIZE - 1) return 0; // dont blow out the buffer
Ref.:
TinyWireM: https://github.com/adafruit/TinyWireM
DigisparkOLED: https://github.com/digistump/DigistumpArduino/tre...
SSD1306 data sheet: https://www.adafruit.com/datasheets/SSD1306.pdf
Another instructables using ATtiny85 and SSD1306: https://www.instructables.com/id/ATTiny85-connects-...
Step 5: Custom Font
8K flash has no enough room to store all characters in large font size. (such as 24 pixels font height)
As watch only require 10 digital characters, we can tailor-make a selected font type binary to fit in limited space.
I will use imagicmagick command line tools to show how to convert custom font characters to a c header file.
This program need 10 digit in 2 font sizes, one with font height 8 pixels to show date digits and one with font height 24 pixels to show time digits:
convert -depth 1 -font Lucida-Sans-Unicode -pointsize 11 label:00123456789 -crop 70x8+7+4 -flip -rotate 90 watch_digit.xbm
convert -depth 1 -font Cooper-Black -pointsize 25 label:00123456789 -crop 150x24+14+4 -flip -rotate 90 watch_3x_digit.xbm
Lucida-Sans-Unicode and Cooper-Black are the font type in Windows 7, you may use your selected font type in your OS.
The corp, flip and rotate option help to adjust the binary data in correct position and direction. You may change the output format from xbm to png to preview the output bitmap.
After export the xbm files, we can copy the font binary code to the watchdigit.h source file:
#include <avr/pgmspace.h>
#define FONTWIDTH 7
#define FONT3XWIDTH 15
static const uint8_t watch_digit[] PROGMEM = {
//watch_digit.xbm binary code
static const uint8_t watch_3x_digit[] PROGMEM = {
//watch_3x_digit.xbm binary code
Ref.:
http://www.imagemagick.org/script/index.php
Step 6: Program
Picture of Program
I am using a littlewire board as ISP, and I have make a hacking ISP connector for easier plug and play.
Any ISP that can program ATtiny85 should be ok.
Reference:
https://digistump.com/wiki/digispark/tutorials/pro...
https://blog.adafruit.com/2009/11/21/how-to-progra...
https://www.instructables.com/id/Programming-an-ATT...
https://learn.sparkfun.com/tutorials/tiny-avr-prog...
Step 7: User Input
Picture of User Input
2 buttons UI for adjust time, operation method just like any simple digital watch.
Set button: select adjust field, the field will highlighted
Up button: increment value of selected field
Step 8: Calibration
Picture of Calibration
Debug Screen
Press up button when not selected any field will enter debug screen.
Time Calibration
The first number is WDT interrupt count, this value is used to calibrate the value of wdt_millis_per_interrupt.
This value for you chips should be calculate from:
actual time (in millisecond) passed / WDT interrupt count
e.g. if you turn it on at 2016/01/07 23:10 and it is now 2016/01/08 13:25, it passed 51300000 milliseconds. At the same time the first line of debug screen show 51454 then you should set wdt_millis_per_interrupt as:
51300000 / 51454 ~= 997
Voltage Value
The second number is current battery voltage in millivolt. It require calibrate the constant value in readVcc() with the real readings from a multimeter.
actual millivolt / debug value * current voltage reference value
e.g. current voltage reference value is 1125300, debug screen second line show 2823 and multimeter show 2.81 volt then you should alter voltage reference value as:
2810 / 2823 * 1125300 ~= 1120118
Step 9: What's Next?
  • watch case, it may be a big ring on a finger (should use a smaller battery like CR1220)
  • more precise time, try to tune WDT millis with current volt and temperature
  • connect other I2C modules
  • research sync time method, GPS, WiFi + internet, BLE + mobile phone and more
Hanzalaibnzahid (author)2017-11-30
can it work with arduino pro mini???
陳亮 (author)Hanzalaibnzahid2017-11-30
Hi Hanzalaibnzabid, the code depends on tinyWireM library, and it is tailor made for ATtiny core.
matthewfelgate (author)2017-06-30
Does the ATtiny85 not need a Crystal to work?
陳亮 (author)matthewfelgate2017-06-30
yes, attiny can use internal oscillator only
AaravM (author)2016-06-22
can we use this microcontroller instead http://www.amazon.in/VEEROBOT-CRUX-ATtiny85-Development-Board/dp/B0115IZ7XU?ie=UTF8&keywords=attiny%2085&qid=1466594287&ref_=sr_1_3&sr=8-3
陳亮 (author)AaravM2016-06-22
no idea, never use it yet. but it have a USB socket, seems similar to Digispark. if true, the boot loader eat up around 2 KB memory, then may not have enough room to fit this program.
RyeMAC3 (author)2016-03-05
How do you modify the code for a 64x48 display?
陳亮 (author)RyeMAC32016-03-22
just guess it similar to 64x32, but have 2 more page.
ReneR2 made it! (author)2016-03-22
Works fine, but i have bigger OLED ( http://www.ebay.com/itm/351493950611?_trksid=p2057872.m2749.l2648&ssPageName=STRK%3AMEBIDX%3AIT ) and cant seem to find where to edit so it fills my screen, also id like to be able to edit sleep so it can be on all the time, where to do these changes?
陳亮 (author)ReneR22016-03-22
I have made an ring watch base on this core, you may find more details here:
https://m.instructables.com/id/ATtiny85-Ring-Watch/
diy_bloke (author)2016-02-07
You left one pin unused what a waste :-)
Seriously though: great project and looks good too
KharyL (author)diy_bloke2016-02-29
can you send me the download files i don't want to pay thank you email; klambie at enutil-energy.com
diy_bloke (author)KharyL2016-02-29
which download files? I have no idea what you are talking about
陳亮 (author)diy_bloke2016-02-07
Not waste, I just reserve it for future development. Actually, in my latest code, I change to used only one pin to connect three or more buttons, and reserve remain more pin for further features, such as serial GPS or BLE.
diy_bloke (author)陳亮2016-02-08
good idea though the purist in me would then think....hmmm attiny10 ;-)
Great project, well done
dan3008 (author)2016-02-14
wow, I think i'm going to base my Attiny85 pocket watch on this :)
Jfieldcap (author)2015-12-28
Nice idea and 'ible! I wonder if this could be compacted even more, maybe an SMD attiny, SMD buttons, and like you mentioned, a smaller battery? I wonder just how tiny this could be made. Also, I wonder if there's green on black versions of this display? Then you could make the font look like an old terminal, so it'd look like an ancient computer. Anyways, neat idea and project, I might make it sometime.
陳亮 (author)Jfieldcap2016-02-07
coming soon
Jfieldcap (author)陳亮2016-02-08
Cool! I noticed the buttons and the resistor are still through hole, though. If you're not too intimidated by SMD soldering, couldn't it be just a bit smaller? ;)
陳亮 (author)Jfieldcap2016-02-09
yes, I do not have SMD button and resistor in hand. And I design add one more button and use resistors for the button panel too late, so it is temporary solution.
Jfieldcap (author)陳亮2016-02-09
Ah, ok. Well, I look forward to seeing it once you've finished with it!
FrankenPC. (author)2015-12-29
Even thermal compensated RTC units drift over time. How stable is the ATTiny as it relates to time drift?
陳亮 (author)FrankenPC.2015-12-29
It needs time to measure, in my previous experience, use Lithium battery is better than rechargeable battery. It run a few days ago, and the variation still not over 1 minute.
PeteWK8S (author)陳亮2016-01-07
How do you calibrate? Step by step please! My build of this loose minutes every hour. Suggestions please
陳亮 (author)PeteWK8S2016-01-07
Revised step 8 for the time calibration details
PeteWK8S (author)陳亮2016-01-08
Thank your for revised Calibration Step. However, to help the "clueless" like myself, it could also specify the calibrated values are edited into WDT_Time.cpp at lines:
static uint16_t wdt_millis_per_interrupt = 1076; // calibrate value
and for readVcc()
result = 3094575L / result; // calibrated value
陳亮 (author)PeteWK8S2016-01-08
Good!
Sorry for the misleading, the code come from over 3 sources and I have substantially revised. I will try to move also calibrate value at the top in next instrucables. (ATtiny Ring Watch)
PeteWK8S (author)陳亮2016-01-10
Sorry but I'm still doing something wrong. After I determine the ms and mv numbers I still loose too much time. So I think I am not computing the calibration numbers correctly.
陳亮 (author)PeteWK8S2016-01-11
can you show your calculation?
PeteWK8S (author)陳亮2016-01-11
WDT_Time.cpp shows to compute measured voltage in mv:
// result = 1125300L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
result = 3375900UL / result; // calibrated value
return result; // Vcc in millivolts
My measured voltage is 3.3V which is 3375900 by this formula - When I make results=3375900UL then debug shows 14806 This is confusing to me.
I have updated step 8 for voltage calibration.
Please be noted that:
wdt_millis_per_interrupt vale should be within +/- 10 of 1000 milliseconds
voltage reference value should be within +/- 100k(~0.1 v) of 1125300UL
auto tune wdt_millis_per_interrupt by voltage level not yet implement (i.e. voltage reference calibration not affect time accuracy)
PeteWK8S (author)陳亮2016-01-14
This is not working for me. Using Atmel Attiny85 20PU - IDE 1.65 with settings Tiny85 at 1Mhz Internal
  1. Program chip with Attiny85_Watch_ino with WDT_Time.cpp with default or original entries
static uint16_t wdt_millis_per_interrupt = 998; // calibrate value
result = 1089952UL / result; // calibrated value
  1. Note down current local time
  2. Set time on Attiny chip
  3. Measure and note actual Mv on Attiny chip
  4. Wait 1 to 8 hours and note elapsed time in milliseconds
  5. Note Debug values
  6. Compute wdt_millis_per_interrupt as: 51300000 / x = y (x = debug value noted, y= calibrated value)
  7. Enter value of y at “static uint16_t wdt_millis_per_interrupt = 998; // calibrate value” in WDT_Time.cpp replacing 998
  8. Compute millivolts using x / debug value * 1125300 = y (x=measured millivolts, y= calibrated value)
  9. Enter values of x and y at “result = 1089952UL / result; // calibrated value” replacing 1089952 in WDT_Time.cpp
  10. Reprogram Attiny85 chip with the newly calibrated values.
  11. Reset time of Attiny85 to current local time.
I then recheck the Attiny clock but time is either gaining or losing after only a few minutes. Am I still doing something wrong?
陳亮 (author)PeteWK8S2016-01-14
I am writing a new version to help auto calibrate the value, it should release at these few days.
Thanks -- looking forward to it.
陳亮 (author)PeteWK8S2016-01-15
Try this:
https://github.com/moononournation/ATtinyWatch
it will auto tune the interrupt value when you set the time, if this not the first time of time setting and the previous setting is over 1 hour.
PeteWK8S (author)陳亮2016-01-20
Hello, this version works but with caveat. I must reset the unit when trying to set time for self calibration. The time will start rapidly changing by itself. Once I reset it, it behaves and keeps time accurately. Thanks for your work and sharing. Pete
PeteWK8S (author)PeteWK8S2016-01-22
This version works quite well. However, I have a question. How and where do I change where the text begins to display.? It displays low, towards the bottom of the display. Its a 128x64 0.96 inch display. Maybe your display is smaller and the text seems bigger because of that. Thanks again for all your help.
陳亮 (author)PeteWK8S2016-02-01
Sorry for late reply, I have just tested on 128x32 and 128x64 screen. You may uncomment the screen #define at the file ssd1306.h for change resolution setting.
Please find the updated at the same place:
https://github.com/moononournation/ATtinyWatch.git
joe57005 (author)FrankenPC.2016-01-02
Haven't tried with attiny, but the megas drift several seconds every hour. An experiment was off by about twenty minutes after roughly 8 hours at room temperature. My mechanical watch was more accurate.
dunk8888 (author)2016-01-25
Hi,that ssd1306 looks verry small,it looks smaller than mine,my ssd1306 128x64 wont fit on half a small breadboard like this does,where did you buy it from?
陳亮 (author)dunk88882016-01-25
the resolution is 64x32
Hi does the number on these batterys corraspond to mah cr2025 and cr2016 etc?
CR2016, CR2025 and CR2032, the first 2 digits if the battery diameter and the last 2 digits is thickness. Thicker battery should have more mAh.
ronw5 (author)2016-01-17
these are the errors when i try to compile:
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Arduino: 1.0.6 (Windows NT (unknown)), Board: "ATtiny85 @ 8 MHz (internal oscillator; BOD disabled)"
attiny85watch.ino: In function 'void setup()':
attiny85watch:17: error: 'INPUT_PULLUP' was not declared in this scope
attiny85watch:23: error: 'TinyWireM' was not declared in this scope
attiny85watch:24: error: 'class SSD1306' has no member named 'begin'
attiny85watch:25: error: 'class SSD1306' has no member named 'fill'
attiny85watch.ino: In function 'void enter_sleep()':
attiny85watch:42: error: 'class SSD1306' has no member named 'fill'
attiny85watch:43: error: 'class SSD1306' has no member named 'off'
attiny85watch.ino: In function 'void wake_up()':
attiny85watch:53: error: 'class SSD1306' has no member named 'on'
attiny85watch.ino: In function 'void draw_oled()':
attiny85watch:74: error: 'class SSD1306' has no member named 'fill'
attiny85watch:80: error: 'class SSD1306' has no member named 'print_digits'
attiny85watch:82: error: 'class SSD1306' has no member named 'draw_pattern'
attiny85watch:83: error: 'class SSD1306' has no member named 'print_digits'
attiny85watch:84: error: 'class SSD1306' has no member named 'draw_pattern'
attiny85watch:85: error: 'class SSD1306' has no member named 'print_digits'
attiny85watch:87: error: 'class SSD1306' has no member named 'print_digits'
attiny85watch:88: error: 'class SSD1306' has no member named 'draw_pattern'
attiny85watch:89: error: 'class SSD1306' has no member named 'print_digits'
attiny85watch:91: error: 'class SSD1306' has no member named 'print_digits'
attiny85watch:92: error: 'class SSD1306' has no member named 'print_digits'
陳亮 (author)ronw52016-01-17
it require Arduino 1.6.5, ATtiny core source and TinyWireM library.
ronw5 (author)陳亮2016-01-18
thank you.
ChristianK35 (author)2016-01-07
Hi i want to make an weather station with an dht22 sensor and this oled display and the attiny, everithing works grat with an 20x4 display lcd
i just need the code to print some text how i use the command oled.print_digits("some text"); ?
Solved! i use this code:
#include "SSD1306_minimal.h"
#define DEG "\xa7" "C"
SSD1306_Mini oled;
void setup(){
oled.init(0x3c);
oled.clear();
delay(1000);
void loop(){
oled.startScreen();
oled.cursorTo(15,1);
oled.printString( "Oled_Attiny85");
陳亮 (author)ChristianK352016-01-07
Good!
In this program, it only contain digit bitmap font, so it cannot display any other character. I will implement it in the future if it still have enough room in the 8K flash.
nhuynhduc (author)2016-01-04
Dear 陳亮
I'm upload error
sketch\WDT_Time.cpp: In function 'void setup_watchdog(int)':
WDT_Time.cpp:323: error: 'WDTCR' was not declared in this scope
WDTCR |= (1 << WDCE) | (1 << WDE);
How can i debug ?
Thanks
About This Instructable
43,792views
531favorites
License:
Bio: Do it yourself if you cannot buy one!
More by 陳亮:Battery Powered ESP IoTBattery Powered ESP DesignESP32 Photo Clock
Add instructable to:
