Introduction: ATtiny13A Line Follower
Picture of ATtiny13A Line Follower
Create a robot with ATtiny13A is a challenge, it only have 1k flash and 5 IO pins. But it is good enough to create a tiny line follower.
Youtube demo video: https://youtu.be/00PYO1ThzEA
Step 1: Prepare Hardware
Picture of Prepare Hardware
MCU
Today core subject, ATtiny13A. ATtiny13A have different package, I am using DIP8 one, i.e. ATTINY13A-PU.
A DIP8 IC holder
For easier unplug the MCU for reprogram, it may occur hundreds times.
Programmer
I am using a USBtinyISP, but any compatible ISP should be ok. Many page show how to use an Arduino to program the ATtiny.
Power source
A rechargeable battery, LIR2032, it is small but still can provide enough current to drive the motors.
20mm coin cell holder
For holding LIR2032.
A tiny power switch
For easier turn off the robot without unplug the battery.
Left and right light sensors
Actually, at the beginning, I want to use IR emitter and sensor pair. However, after test three pairs from different vendors, I found the readings is very depends on the distance but not the color. So I changed my mind and selected Light Dependent Resistor (LDR)
Left and right Pull-down resistors for light sensors
I found many post on the web use 10k ohm pull-up or pull-down resistor, but I found 47k ohm resistor have a better readings, so I choose it
Light source
White LED, 5mm with straw hat is preferred, because we need a wide-angle light source.
Resistor for the light source
A white LED can consume tens of MA but it is overkill since line follower only require light source for a few mm distance. So add a 5.1k ohm resistor for reduce power consumption, the resistant value very depends on the LED performance.
Left and right motors
The most power consumption is come from the motors. According to ATTINY13A specification, the maximum DC Current per I/O Pin is 40 MA. For simplicity, I don't want any extra transistor to drive the motors and also LIR2032 cannot provide too much power to do that. So I choose a tiny motor that only consume around 20 MA.
Wheel
Since I don't want to add extra gears, the wheel should as small as possible to reduce required torque and reduce power consumption. The wheel design is come from Shlonkin.
Front wheel and chassis
In first run, I just treat the LED as front wheel. It run smooth on the white paper and many surface but hard to run on the line. After few days trial, I found it is caused by the sticky surface produce by the marker ink. I have try a few front wheel design, but hard to move forward, left and right smooth at the same time. Finally I use a 8 mm steel ball to make it. It is very easy to glue the motors by hot glue, but since I cannot direct glue the steel ball as a front wheel, and lucky I can use a 3D printer right now. So I printed a chassis for the motors and front wheel. If you also can use a 3D printer, you may try to print it here.
A multipurpose PC board
It require a 6 x 5 holes multipurpose PC board to stick all parts together.
Step 2: Prepare Software
Compiler and programmer
I am familiar to Arduino in other previous project, so simply use it.
Add ATtiny13A support
Arduino need extract source for ATtiny13A support. more detail can be found in instructables by diy_bloke.
Step 3: Stick All Parts Together
Picture of Stick All Parts Together
I have draft a very low quality circuit for soldering on the multipurpose board. Since it is very simply, I think it is good enough.
Here is the summary for the connection:
  • PIN 1 - not connected
  • PIN 2 - left light sensor with pull-down resistor (light sensor other side connect to VCC and resistor other side connect to GND)
  • PIN 3 - left motor (test the motor turning direction before soldering, it should turn counter-clockwise, motor other side connect to GND)
  • PIN 4 - GND
  • PIN 5 - not connected
  • PIN 6 - right motor (test the motor turning direction before soldering, it should turn clockwise, motor other side connect to GND)
  • PIN 7 - right light sensor with pull-down resistor (light sensor other side connect to VCC and resistor other side connect to GND)
  • PIN 8 - VCC
  • LED PIN - long PIN connect to VCC and short PIN connect to resistor and then GND
Step 4: Install Chassis
Picture of Install Chassis
I am using the 3D printed chassis, it makes all easier. If you cannot access a 3D printer, it can simply glue by hot glue or blu tack.
I think 8mm steel ball is overkill, but I did not have a smaller ball in hand. If you don't have one, treat the LED as front wheel is fine on smooth surface. The route drawing by a marker pen is sticky, printing route by laser printer should be smoother.
Step 5: Program Code
Program code splint in two parts. if uncomment "#define testrun", it only test run the motor ability; comment it return to the normal flow.
Program steps:
  1. Download and open the attached ino file, it may prompt create program folder alert, simply accept it.
  2. Select Tools menu -> Board -> ATtiny13A, 600 kHz - 1.2 MHz is fine
  3. Press the tick button to compile the code
  4. Connect your ISP and select Tools menu -> programmer -> your programmer
  5. If everything ok, press the upload button
Reference:
https://blog.adafruit.com/2009/11/21/how-to-progra...
https://www.instructables.com/id/Programming-an-ATT...
https://learn.sparkfun.com/tutorials/tiny-avr-prog...
Step 6: Test Run and Tuning
Picture of Test Run and Tuning
The motor ability is the biggest variant in this project, so it should first test it before using the light sensor.
  1. Program to test run mode.
  2. Connect MCU and battery.
  3. Turn it on and place it to a white paper (or any surface you would like it to run).
  4. The test run try to turn left and right in 3 level, then dash and turn, and then dash only.
  5. Check the dash can run in a straight line, if not, try to define LEFTDUTY and RIGHTDUTY to make it.
  6. Check the dash and turning ability and fine tune the figure. (Hint: you should find some figures, the value to turn around 15-30 degree, the value to dash a half the robot size and then turn a right angle. It can help to keep track on the line and how to land the line when first find it.
  7. Then place the robot on the middle of the prepared track.
  8. If the robot seems cannot detect the line, try to adjust the value of the THRESHOLD (0-64), I think 56 is reasonable.
  9. Show it to your friends and kids.
  10. HAPPY PLAYING!!!
Sembot (author)2017-11-20
Is it possible that the motors are wrong connected in the schematic, normally one side of the motor is min and not +
陳亮 (author)Sembot2017-11-20
Hi Sembot, it just depends on the which battery pole connected to the switch. The battery holder +ve pin out easier connect to the switch, so the motors connect behine the switch is +ve. If you want to reconnect it to -ve, remember revise the code high/low level.
bwantha (author)2016-11-29
this sketch use 3 kb attiny13A flash memory 1kb so this sketch not uplorded plese help us
陳亮 (author)bwantha2016-11-29
try older version
YUSUF6731 (author)2016-07-20
Hello maker,I wanna know that can ATtiny13A can be programmed via ARDUINO IDE ?
陳亮 (author)YUSUF67312016-08-28
Hello, sorry for late reply. It is logically yes. However, ATtiny13A only have 1k flash, the Arduino Blink example binary already use up over 800 bytes. It is a big challenge to fit your program in it.
haminhtranhanh (author)2016-08-28
Hi there,
Nice stuff to play around. Would you please tell me how long the battery serviced? Thanks!
陳亮 (author)haminhtranhanh2016-08-28
I have not tested it, since I just play a few round every time. But I have never recharge the battery in the developing period and never encounter battery exhaust.
ZipDriveRT (author)2016-03-29
very nice, now do you know off hand if this attiny has connections for IMU MPU6050 ? (SCL & SDA ?) i need this type of chip and at lease 4 analog output pins with one or two inout pins
陳亮 (author)ZipDriveRT2016-03-29
hi, I don't have much knowledge about MPU6050, but I have another instructables use ATtiny85 connect to I2C OLED display. You may take a look: https://m.instructables.com/id/ATtiny85-Ring-Watch/
Jfieldcap (author)2015-12-28
Wow. Great job!
aequanimitas (author)2015-12-26
nice project, thanks!
Scramblbot126 (author)2015-12-01
Thanks!
Scramblbot126 (author)2015-11-30
Did you program the ATtiny with the arduino?
陳亮 (author)Scramblbot1262015-11-30
I am using USBtinyISP
陳亮 (author)2015-11-30
DaveHee (author)2015-11-17
would the attiny 45 work
陳亮 (author)DaveHee2015-11-17
yes, sure! ATtiny45 is the same series but have 4 times of flash. You can write more complicated logic for it.
jqvr (author)2015-11-07
It's a beauty! I like the minimalistic approach. Please post a video of it running.
陳亮 (author)jqvr2015-11-07
posted
DylanD581 (author)2015-11-07
Cool Electronics and 3D Printing Project! Uploading the 3D-Printed Chassis to the Instructable Would Benefit Everyone!
陳亮 (author)DylanD5812015-11-07
done
Starsword7 (author)2015-11-07
Cool instructable!
could you post a video of it in action?
陳亮 (author)Starsword72015-11-07
I actually already attached the m4v video file before, I have just found instructables video feature still "coming soon". So I have put it on the Youtube.
grayl (author)2015-11-06
Can you tell us the specs on the motor you used?
陳亮 (author)grayl2015-11-06
motor body 12mm long, 4mm diameter. 60000rpm, 0.04A. I have measured the current, it consume below 25 MA without load.
grayl (author)陳亮2015-11-07
I actually wanted to know where you bought the motors. Thanks for the specs.
陳亮 (author)grayl2015-11-07
It usually used for vibrator, you may try to google "tiny motor" in image mode for more details.
Mic100 (author)2015-11-06
Very nice idea :)
easy to build can you post a video please
I made a robot that looks like him with detection by IR
https://www.instructables.com/id/Mini-2-wheel-robot-with-IR-sensor-weight-14gr-and-/
seamster (author)2015-11-06
Very cool! Nice, simple little robot. Very well done, thanks for sharing!
About This Instructable
10,603views
205favorites
License:
Bio: Make it yourself if you cannot buy one!
More by 陳亮:Kids Photo Album With Flashcard CommercialBattery Powered ESP IoTBattery Powered ESP Design
Add instructable to:
