AUBO - an Open Source Autonomous Bot With Arduino
1,583
18
15
Published
Introduction: AUBO - an Open Source Autonomous Bot With Arduino
About: Hi, I'm a Vedaant a 12-year-old from India. I love making with Arduino and am interested in making projects related to RFID, Laser, IR and robotics. Some Projects that I am working on right now are LaserTag...
AUBO is an open source life-size robot that roams around your house, office or anywhere you want. AUBO is fully autonomous meaning you don’t need to control it at all! AUBO is Arduino at heart meaning you can add whatever you want to it. From making it a giant fighter bot to a motion-controlled bot with hands. The only limit is your Imagination. AUBO is perfect for giving out pamphlets and even learning Arduino. AUBO can be easily coded to suit your needs and to add any games you wish AUBO to play with you.
Check out our site: Here (Coming Soon)
Step 1: Materials,Cost and Tools
  • I'm working on designing a PCB for this project to make it cheaper. (check the last step for updates)
The prices that I have stated are all approximated and as per my country. They might be different in your country. Refer to the picture for prices and details. Here is a list of the materials -
  • Motors 60RPM High Tourqe
  • L293D Motor Driver Module
  • Ultrasonic Sensor HC-SR04
  • Arduino Uno + Serial - USB wire
  • Caster Wheels
  • Battery Pack
  • 12v Bike Battery - Lead Acid
  • 12v Battery Charger
  • MDF Board
  • Jumper Wires (Male to Female)
  • Plastic tub/drum
  • Paints
For Mounting of Motors -
  • Bracket for motors
  • Screws
  • Nuts
TOOLS
  • Soldering Iron
  • Assorted collection of screwdrivers
  • Wire cutters
  • Glue Gun
  • Hacksaw, table saw or something to cut the wood (Check the Structure Step)
  • Multimeter (Not required but VERY handy. Saves lives)
  • Drill
Step 2: Setting Up the Structure
The bot requires a good structure as the 12v battery is quite heavy. To cut up the wooden plank -
1) Put the tubs bottom side on the wooden plank.
2) Take a marker and trace the tubs bottom.
3) Cut the traced side of the plank with a table saw or hand saw etc. (I went to my local makerspace. They helped me with cutting the plank in a circular shape)
4) Use sandpaper to smoothen it.
This makes a good structure with good support for the weight of the battery.
I used a 4mm MDF board. Its light compared to other woods. You can get it at your local hardware store or Amazon.
Step 3: Motors and the Driver
I was having problems selecting the right motor for this project as it would become very heavy.
These are the exact specs of the motor (from https://robokits.co.in/motors/60rpm-12v-dc-motor-w...)
  • 60RPM 12V DC motors with Gearbox
  • 125gm weight
  • 2kgcm torque
  • No-load current = 60 mA(Max), Load current = 300 mA(Max)
To be honest, if you ask for a high torque 60 RPM motor you should get what you need.
Take wires and solder one of their ends to each terminal of the motor. Repeat this for the second motor.
Now for the motor driver, I used a simple L293d driver shown in the picture above. You can pick any L293d based motor driver you wish ( Shield not recommended). My driver looked like the picture shown above.
CONNECTIONS :
First, connect the motor wires to the M1 and M2 terminals of the driver shown above.
Motor Driver | Arduino
GND --> GND
GND --> GND
VCC --> 5v
VCC for Motor --> Battery Postive terminal (don't do it as of yet. Wait for the Battery step)
PWM Controls --> Nothing yet
VCC --> 5v
C1A (left) --> D5
C1B (left) --> D6
C2A (right) --> D9
C2B (right) --> D10
Step 4: Battery
WARNING: BE CAUTIOUS WITH THE BATTERY. IT IS A VERY STRONG BATTERY
The battery that I chose was a 12v Lead-Acid battery most commonly used for motorbikes. I went to the shop and took the smallest one I found. This one has about 3.0 Ah of capacity. It is the SF Sonic Mobiker MK1440-TZ4 Battery.
To connect it to the Motor driver and Arduino take a wire and twist its head on the connection port of the battery. Solder a header pin to the other end of the wire and connect to the motor driver. If its loose use a crocodile clipped wire instead.
CONNECTIONS :
Battery | Arduino / Motor Driver
+ (VCC) --> Motor Driver 9v/12v area
- (GND) --> GND
Step 5: Drilling the Board
Before everything is complete in AUBO you need to complete one of the hardest processes in the project. That is drilling and mounting.
Motors: You need to take one of your motors and place it in an ideal location. Take one of the brackets and place it above the motor. Make sure it is tight. Take a marker to mark the location of the drilled hole required to stick the bracket to the structure. Repeat this for the other motor.
Caster Wheels: Place a caster wheel on the two other sides (Refer to Picture). Put the screws for the caster wheels on them (they should be long). Now mark the points for the screws and drill away. Repeat this for the other caster wheel
REMEMBER TO MAKE HOLES NEAR THE MOTORS FOR THE WIRES TO PASS THROUGH
Step 6: Mounting
Yay, you are almost done!
Place the motor where the holes for the bracket is. Firmly tighten the bracket on the motor and screw in the screws and the nuts. Tighten your motor and bring out the glue gun. Glue gun as much you can to keep the motor stuck on the board. Repeat this for the next motor.
Now for the casters, take them and insert long screws in them. Put spacers between the screws to adjust the height of the caster wheel. Screw it in and secure it with a nut.
P.S Touching a glue gun is far better than touching a soldering iron by mistake.
Step 7: Code
I will write a better code for AUBO soon. This is a barebones code to allow AUBO to avoid obstacles and move around.
Step 8: Make It Look Nice (Optional)
The plastic tub will sit on the board to provide a body of some sorts.
I painted the tub white and stuck some stickers on it to make it look even better.
Step 9: Updates and More
This is my debut project on instructables. I hope to make many more.
Planned Updates:
  • Youtube tutorial (Coming Soon)
  • PCBs and Shields
  • Different use case examples
  • And much much more.
I will update this section to keep you all in touch!
Check out our website http://aubo.vedaantyadav.me/ <-- We have all our updates and a blog here! (Coming Soon)
If you would like to contact me check out the website or email me at vedaantyadav10@gmail.com
Thanks for reading and maybe even making,
Vedaant Yadav
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    15 Comments
    Looks interesting. All the best.
    That's awesome! Good job!
    Gud job
    Great going!!!
    Very impressive vedaant !! keep going...
