AUTOMATED PRODUCTION LINE WITH BOTTLE FILLING FEEDBACK CONTROL SYSTEM
5,741
12
6
Published
Introduction: AUTOMATED PRODUCTION LINE WITH BOTTLE FILLING FEEDBACK CONTROL SYSTEM
The use of automatic filling stations using a belt conveyor system is most economical, fast and commonly used system used in almost all beverages and pharmaceutical (liquid) industries. This project works as a prototype for basic concept of automatic filling stations in beverages, pharmaceutical and dairy process industries.
Step 1:
The objective of the project is to detect the presence of a glass bottle at the filling station, fill the liquid in the bottle to a certain height and forward the bottle for further processing. The project consists of a belt conveyor, for filling of bottles to a required level of liquid, driven by a DC motor at a constant preset speed. The motor will keep driving the conveyor until an infrared (IR) sensor detects the presence of a bottle right below the filling station. The IR sensor sends the signal to the controller which in return sends a signal to the motor to stop. As soon as the conveyor stops, the actuator for filling, i.e. a solenoid valve, turns the filling on. The liquid level in the bottle is continuously monitored using an ultrasonic sensor. A preset required level of liquid is already entered in the controller. The controller compares the instantaneous level to the preset required level. As soon as the desired level is reached, the solenoid valve turns off the filling. When filling stops, the conveyor starts moving so that next bottle can be filled.
Step 2: Components
TIP 122:
In electronics,
the Darlington transistor (often called a Darlington pair) is a compound structure consisting of two bipolar transistors (either integrated or separated devices) connected in such a way that the current amplified by the first transistor is amplified further by the second one.
Sonar HC-SR04
Ultrasonic ranging module HC - SR04 provides 2cm - 400cm non-contact measurement function, the ranging accuracy can reach to 3mm. The modules includes ultrasonic transmitters, receiver and control circuit. The basic principle of work:
(1) Using IO trigger for at least 10us high level signal,
(2) The Module automatically sends eight 40 kHz and detect whether there is a pulse signal back.
(3) IF the signal back, through high level , time of high output IO duration is the time from sending ultrasonic to returning.
Test distance = (high level time × velocity of sound (340M/S) / 2.
Step 3: Components
Solenoid valve (12V, ¼”)
A solenoid valve is an electromagnetically operated valve. The valve is controlled by an electric current through a solenoid: in the case of a two-port valve the flow is switched on or off; in the case of a three-port valve, the outflow is switched between the two outlet ports. Multiple solenoid valves can be placed together on a manifold.
Infrared Sensor for detection
An infrared sensor is a sensor that reacts to infrared (IR) ray of light projection. An infra red ray of light emerges from one terminal known as emitter and is received by another terminal known as receiver. The emitter and receiver may be on the same side or the opposite side. The sensing can be to sense an obstacle that breaks the projection to imply presence of an external object, or to sense the projection at receiver to imply moving of an object that was supposed to be breaking the light beam, or both.
Step 4: Circuits
WORKING DESCRIPTION
The circuit is supplied with two different power sources (two 9 volts battery) and one 12v 2.0amp source. There are two switches which will turn on the circuit. When the beaker is placed on the conveyor belt, when it comes in between the LED and Phototransistor, then the output signal will be generated by a comparator, which has some preset value set by a potentiometer against the sensitivity of the light received by the phototransistor. This output is then read by a 8bit 32KB AVR microcontroller (ATMEGA 328) which then immediately stops the conveyor and through relay it will turn on the solenoid valve and hence the liquid will flow through it by the action of gravity into the beaker via valve from the reservoir. The ultrasonic sensor will detect the level of water, following the Doppler’s phenomena, the value of level is experimentally set in the programming. Once the level of the liquid is achieved the controller after taking decision will switch off the solenoid valve and turn on the conveyor and will weight for the other beaker to come.
Step 5: Arduino Code
Program (SourceCode)
#include<Liquidcrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#define echoPin 7 // Echo Pin
#define trigPin 8 // Trigger Pin
#define relay 10 // Onboard LED
#define Glass 9 // Bottle detection
#define solenoid 13 // Solenoid detection
byte armsUp[8] = {
0b00100,
0b01010,
0b00100,
0b10101,
0b01110,
0b00100,
0b00100,
0b01010
int maximumRange = 200; // Maximum range needed
int minimumRange = 0; // Minimum range needed
long duration, distance; // Duration used to calculate distance
void setup() {
lcd.createChar(4, armsUp);
lcd.begin(16, 2);
lcd.write(4);
lcd.print(" Production Line Automation by Saad Zeeshan Waqas Saeed Adeel ");
for (int positionCounter = 15; positionCounter < 84; positionCounter++) {
// scroll one position left:
lcd.scrollDisplayLeft();
// wait a bit:
delay(400);
delay(1000);
lcd.clear();
delay(2000);
pinMode(trigPin, OUTPUT);
pinMode(solenoid, OUTPUT);
pinMode(Glass, INPUT);
pinMode(echoPin, INPUT);
pinMode(relay, OUTPUT); // Use LED indicator (if required)
void loop()
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
//Calculate the distance (in cm) based on the speed of sound.
distance = duration/58.2;
int Detect_glass =digitalRead(Glass);
if(Detect_glass == HIGH) //no glass
digitalWrite(relay, HIGH); //conveyor
lcd.setCursor(0, 0);
lcd.print("Conveyor Start");
digitalWrite(solenoid, LOW);
if(relay==HIGH)
delay(40); //int a = a++;
if(Detect_glass == LOW)
lcd.print("Conveyor Stop");
digitalWrite(relay, LOW); //conveyor off
delay(1000);
digitalWrite(solenoid, HIGH); //solenoid on
//sonar value for level detector
if(distance<=9)
digitalWrite(solenoid, LOW); //water off
delay(1000);
digitalWrite(relay, HIGH); //conveyor on
delay(3000);
delay(50);
    • Microcontroller Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    6 Comments
    what were the other misc components used?
    Can someone please tell me how can the connections be made??
    I was wondering if there were any problem in the ultrasonic sensor on getting the accurate distance from the liquid inside the bottle and not any other distance. I like your project and I might be doing something like this very soon.
    This project just again shows that if one is a little handy you will safe thousands of $$$.
    Thank you for an awesome project.
