Repair Dead AVR's - Attiny Fusebit Doctor (HVSP)
78,245
72
25
Posted
Introduction: Repair Dead AVR's - Attiny Fusebit Doctor (HVSP)
Did you make a mistake while programming fusebits, or purposely disabled reset pin (RSTDISBL) or ISP programming (SPIEN)? No need to buy or make inconvenient HV programmer only for unlock couple of Tiny AVR’s. This Attiny fusebit HV doctor will cure your dead tiny microcontrollers, by restoring all fusebits to factory settings – nice and easy. Supports all of the serial high voltage interface AVRs, that is 8-pins: Attiny11, Attiny12, Attiny13, Attiny15, Attiny25, Attiny45, Attiny85, and 14-pins: Attiny24, Attiny44, Attiny84. This is very simple and cheap to make, the brain of device is an Attiny2313 uC, couple of resistors and transistors, and a 5V stabilizer. You need 12V stabilized supply for this. Repair begins after the button START is pressed. Button is active again after 250ms, so pressing it will reset device and start a new repair process.
Step 1: LEDs Explanation
LEDs explanation:
green on – patient successfully cured, fusebits repaired. If lockbits are enabled, just verify fusebits with factory ones – and if they ok – light up green.
red on – signature problem, can’t read, no device in socket, or no such signature in database.
green flashing – signature ok, fusebits are wrong. Lockbits enabled, chip erase permission required (read below).
red flashing – signature ok, no lockbits, but for some reason can’t write new fusebits, can’t pass verification after 10 attempts.
Step 2: How It Works
Device uses the High-Voltage Serial Programming (HVSP) to repair fusebits. First of all patient is switched to HV memory programming, then we read signature and check if it’s supported. Then the chip erase is performed if user allows it. Next the lockbits are read, if they not set, patient receives new fusebits, proper for readed model. After that, fusebits are verified, and if they pass the test – this is end of work. If not, doctor will repeat write-verify cycle 10 times, and give up when no success.
Step 3: Jumper Setting
You can find two jumpers on board:
chip erase – permit to erase whole flash memory. If lockbits are enabled, there is no possibility to set new fusebits. And there is only one way to disable lockbits – by erasing whole flash. Jumper close – permission to erase flash
unknown signature – it happens very rare, but it happens, that uC has erased signature. Signature, calibration bytes, and other data are not permanently stored in uC structure and they can be accidentally erased due to power supply spikes during programming or power cycling. Generally signature will be read as FF FF FF, but chip will work good, flash can be readed and written. If signature will not match to one from doctor database (FF FF FF or 00 00 00 too), closing this jumper will write a universal fusebits pack which will mess oscillator options and such, but will repair functionality of reset (disable RSTDISBL) and ISP programming (enable SPIEN). Microcontroller will be possible to further repair on SPI normal programmer. DO NOT use this option with Attiny11 or Attiny15.
Step 4: Download
Fusebits: internal 4MHz clock not divided by 8. Will be good to select the “fast rising power” too.
ATTENTION: FIRMWARE IN BETA VERSION. I was not able to test all of the mentioned uC’s, so if something is going bad, please contact me and i immediately make corrections in code.
DOWNLOAD eagle 5.4.0 project files, PDF & PNG schematic and PCB’s
and
HEX & BIN beta firmware.
Project site: AVR Attiny Fusebit Doctor (HVSP) - check for code update
Coming soon: AVR Atmega Fusebit Doctor (HVPP)
    • Pocket-Sized Contest
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    1 Questions
    Can I use an atmega 328p instead of attiny2313?
    Well it wont plug and play the atmega 328p is 28 pins and the attiny 2313 is 20 pins. But if you are asking if you wire the circuit board for atmega 328p will it do the same job, then yes. Just search programming attiny with arduino uno.
    22 Comments
    hello,
    I tested Fuse Doctor with a new USB RS232 card and everything works with BASCOM AVR terminal, I found fault with my old card RS232, screen printing of the card was reversed, the RX is marked TX and TX is marked RX.
    Thanks for this powerfull doctor card :=)
    hello,
    thank you very much for fuse
    I built the circuit board version 2h
    it works perfectly
    i wass saved 2 ATtiny2313, 1 ATTINY45, 1 ATmega8 (without terminal mode) just with LED
    it helped me a lot,
    before I had already tried the method clock 500KHz the input crystal without success.
    I use the LED mode because I have not managed to use the terminal mode with any of these microcontrollers.
    On your website you give as setting
    Terminal settings:
      baudrate: 4800
      parity: none
      databits: 8
      stopbits: 1
      handshake: none
    I have an emulator with USB 5-pin RS232
    1 TX
    1 RX
    1 GND
    1 +5 V
    1 +3.3 V
    I connect RX TX and GND pins on the 3 pins of FUSE DOCTOR PCB
    it is recognized as COM7 terminal BASCOM AVR but nothing appears on the screen
    when I run the reset of the microcontroller while the green LED at the end to let me know that the operation was successful .
    what can i do?
    Bests regards Mic
    To everyone who wanted to fix their mega8 and tiny2313 - at least i finished my MEGA DOCTOR for mega family uc's.
    Everything is on my site here:
    diy.elektroda.eu/atmega-fusebit-doctor-hvpp/#eng (with english descr)
    For now it only supports mega16, mega32, and mega8 and these was tested by me. Other uC's will be added as soon as i find some time to do this.
    I will submit this on instructables too, but first must add some more uC's and someone must make this to confirm there are no problems.
    Best regards,
    Manekinen from Poland.
    Well, thanks dude!! Was What I was looking for!
    Hi manekinen,
    Is the link for the above project still up?
    I messed my ATMega128 fused bit...will this project support 128?
    TIA
    Hi.
    Server was dead, now its working :)
    No M128 at this moment, this is early beta firmware. I try to add more uC's soon, i will give an update :)
    Exist perheps non BETA SOftware, and how is like the fuse setings for 2313
    Ivan
    Hi, there is no NON-BETA soft. As far as i know, there are problems with attiny15 - so i will try to fix this and give updated soft.
    People do not inform me about other problems so i guess everything except this tiny15 is ok - if so, treat next update as non-beta full working :) Without people feedback i can't say that this soft is good or not because i have tested only few of mentioned uC's :)
    If you make this circuit and something will be wrong, please contact me and i try to fix the problem :)
    Thank You for answer but I still don't know the Fuse bits settings for Atiny2313.
    Regards Ivan
    Hi , the fusebit for Atiny2313 = lfuse :w: 0x64:m
    hfuse:w:0xdf:m
    efuse:w:0xff:m
