3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
AVR mini board with additional boards
Somewhat similar to PIC 12f675 mini protoboard, but extended and with additional boards.
Using attiny2313.
Step 1Scheme
Let us first start with a scheme. The scheme is pretty obvious since it only connects attiny2313 with the pins and the only additional elements are resistors and capacitor for reseting the microcontroller.
34 comments
Apr 11, 2012. 11:09 PMLasrin says:
Better than Arduino. Each function is separated (power, IC, HID, etc..) I'm looking forward to when you're offering these for purchase. :) Yeah, easy to make, but why not support someone with a great idea?
Jan 27, 2011. 4:30 PMArduino Guy says:
This is like a mini arduino with sheilds! awsome.
May 20, 2007. 2:58 PM25Kilovolt says:
where do you get your parts from and can i get the part numbers ive been having trouble finding those kind of headers
May 21, 2007. 7:32 PMjhoug says:
Digikey part A209-ND is a close match, and will allow stacking. The socket isn't as deep, but will accept its own pins. The catalog page. (I can't post the datasheet for the actual part because the URL has an embedded space that the Instructables link tool won't parse correctly).
Jun 1, 2010. 4:10 PMGranz says:
I have found that Digikey often charges outrageous prices for the things that I can get from other sources.  Jameco has the WW sockets/headers for about half of what Digikey wants.  They have 20-pin and 30-pin SIPs rather than the 25-pin that Digikey has - the 20-pin is just under half price and the 30-pin is just over half the Digikey price.
Jameco part numbers:
101283 - 20-pin WW2 single row
104054 - 30-pin WW2 single row
Check out Jameco's catalog page at: www.jameco.com/Jameco/catalogs/c102/P83.pdf - the part numbers are links to the description page which has the datasheets and pricing ($1.95 and $2.95 today as opposed to Digikey's $5.42 - even in Qty of 500, Digikey is higher than Jameco's single qty price)
May 21, 2007. 9:09 PM25Kilovolt says:
cool thanks
May 20, 2007. 3:08 PM25Kilovolt says:
i usually order off digikey it the only place that let you get small orders and has prices in Canadian $. thank for the response but the page was in German, and probably cost alot for shipping.
Jan 19, 2009. 6:22 PMiknowirule3 says:
What do you buy for this? (I'm not a technogenius.)
Jan 18, 2010. 9:16 AMbillbillt says:
That is hopless. All you can do with that is lots of love.
Apr 13, 2009. 7:27 AMcomputergeek says:
This is like arduino shields for the attiny2313! Can you post the designs for the PCBs?
Jan 23, 2009. 6:44 PMiknowirule3 says:
Actually where do you buy the connectors in US?
Sep 1, 2008. 8:58 PMKT Gadget says:
i need a little more understanding on where to put the capacitors and resistors to prevent switching noises or whatever it makes when being programmed.
Aug 18, 2008. 7:01 PMThe Real Elliot says:
I love it. Takes the advantages of both of the carrier types that I've made and then goes modular/stackable. And you still have all of the pins directly accessible from the top. Hotness!
Jul 15, 2008. 9:06 AMDerin says:
if u use the reply button they may see your comment
Jun 10, 2007. 6:37 AMrickick says:
what does it do exactly?
Jun 13, 2008. 12:35 PMDerin says:
look under you
May 28, 2007. 7:12 AM25Kilovolt says:
You should create some boards with motors and wheels then some sensors and you'd have a nice little robotics platform.
May 21, 2007. 9:18 PM25Kilovolt says:
this reminds me of some robots i saw on discovery channel a while ago. They were form some American university like MIT of some thing. they had piggy backing boards with functions like wheels, treads, micro controller, battery, and many different sensor boards. i really like the modular idea to it.
May 27, 2007. 4:20 PMMyself says:
For more on the stacking concept, check out the PC/104 standard used in many industrial and embedded designs. It's an ISA slot (yes, old 16-bit!) implemented on stackable pins like this, with a physical standard that defines how big the boards can be and where their mounting holes are.
May 19, 2007. 3:35 PMT3h_Muffinator says:
Awesome! I could see a modular-type electronics toy based on this in the future. Nice job!
May 19, 2007. 4:45 PMgmoon says:
Very nice! I like the stackable concept.
You should add info about the ISP cable for your main board--a DAPA cable. Another instructable with the cable/programming info is here:
http://www.instructables.com/id/E5H5UDWB5UEUKIKV8V/
May 23, 2007. 6:49 AMPunkguyta says:
Internet service provider pins? Woot haxxoring isps!
May 19, 2007. 4:47 PMgmoon says:
oooops. Didn't really intend to post this comment as reply to Muffinator....
May 19, 2007. 5:40 PMT3h_Muffinator says:
Hehe, you can delete your comment and re-post, if you want =)
May 20, 2007. 6:06 AMgmoon says:
Yeah, but I think it'll mess the thread up too much now ;)
May 20, 2007. 2:56 PM25Kilovolt says:
Awesome i already built the avr ghetto programmer and now I am making a serial programmer. Instructables like this are great for getting started with micro controller programing.
May 20, 2007. 2:19 AMDzwiedziu says:
Very good idea. If you have an separate programming board, a "module" won't be neccesary. But making one will make things simpler.
May 19, 2007. 8:23 PMSgt.Waffles says:
I have no idea what that is/does, but the instructable is well put together.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:b0j3
