3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
About OHM and his LAW
OHM's LAW - What it is. How it works.
A personal LEARNING AID for the interested and patient learner. Just read the following pages with care or call them up using the HELP function under program execution.
A) Learn the color code for resistors through practice.
B) Learn to calculate rsistance for SERIES, PARALLEL, SERIES-PARALLEL circuits. Circuits are auto-generated and displayed. Answers are verified and a score card is kept. Chose a level of difficulty: (E)asy, (D)ifficult, (E)xpert. A calculator and notepad is needed for the more advanced levels. Just a notepad will do for the (E)asy level.
IMPORTANT: Answering questions on impulse will lead to failure and frustration. READ the instructions that preceed the cursor with care and respond in kind before going on (pressing ENTER).
REMEMBER: GIGO - Garbage In, Garbage Out
Step 1A summary of what is available
HELP : Start by reading ALL the pages (5) in the (H)elp section. The pages are presented below along with some expanatory note.
28 comments
Jan 30, 2007. 4:07 PMAKA1 says:
I've always known OHMs law and Rs in series and parallel BUT did NOT know (or forgot) how to calculate Networked Rs - so spending 10mins on STEP 5 was very satisfying especially as working from the RHS calculating series R taken in parallel with next R loop to the left and so on NOW seems very LOGICAL - A much appreciated intuitive tutorial! NOT wishing to be critical BUT why make life hard and write R.exe as a CONSOLE app rather than a Windows based program? Your successful project was my reason for registering with Instructables.com SO thanx AKA1 - so thanx
Nov 20, 2006. 11:13 AMLasVegas says:
When I took Basic Electronics in 9th grade, this was a quiz the teacher put on the board the first day. He offered an extra A grade to anyone that produced the right equation that solved it...
Dec 4, 2006. 12:20 PMshredder03 says:
thats a solution from point A to the furthest point B. If the points were on the same face, so that one resistor is in series with A, what would the resistance bee then? What about to the opposite side of one face, on your cube in the problem it would be the corner where you have written Vs
Currents cannot be used because they do not follow a symetrical pathway, from A to the closest point *im calling this B* you would have 3 possible pathways, and from A to the opposite corner of a face *I am calling this C* you would have 2 possible pathways.
Nov 20, 2006. 10:12 PMcpotoso says:
(removed by author or community request)
Nov 20, 2006. 10:43 PMLasVegas says:
Except for your typo… It's 1/3 + 1/6 + 1/3 = 5/6V, therefore 5/6MΩ or 833.33KΩ :)
Nov 21, 2006. 8:58 PMLasVegas says:
My solution followed the same logic as cpotoso's. Labeling the other corners A1, A2, A3, B1, B2 & B3. Then following the current and applying Ohm's Law to determine the total resistance. Yes, I among others, did receive the credit. I did not solve it though until learning Ohm's Law later in the course. I have to admit that I do like your logic for the solution as well. I wouldn't have approached it from that direction. Also, thanks for the links. I've never seen that problem elsewhere on the net. Your collegue's solution was flawed to begin with and I suspect wasn't thought through long.
Nov 20, 2006. 10:21 PMcpotoso says:
Nov 20, 2006. 1:23 PMmikesty says:
250 kOhms???
Nov 20, 2006. 3:21 PMLasVegas says:
Some guessed correctly and incorrectly. Others actually built the bridge and measured it! Of course, none in either group got an 'A' out of it.
Nov 20, 2006. 8:12 PMTool Using Animal says:
Half a meg
Nov 20, 2006. 8:23 PMLasVegas says:
Again; Without an equation, there would be no credit wether your answer were right or wrong… Perhaps more conventional 2 dimensional schematics of the circuit would help:
Nov 20, 2006. 8:25 PMTool Using Animal says:
I'm to buzzed for equations lets say it's six three meg resistors in parallel so 3 meg divided by number of legs equals half a meg.
Dec 3, 2006. 11:22 PMshredder03 says:
I have a question for you. What if you're trying to find the resistance from the starting point to the point closest to it? If you could get back to me ASAP, it would be greatly appreciated.
Nov 20, 2006. 5:09 PMsupes says:
From what I am told from my OLD electronics teacher...They used to use "Bad Boys Rape Our Young Girls, But Violet Gives Willingly (for SILVER and GOLD!)" when he was growing up but that slowly phased out due to its offensiveness. I dont think many people have a replacement for it, thus a device like this is not used.
Nov 22, 2006. 4:16 PMtheRIAA says:
awsome
Nov 20, 2006. 3:35 AMdan says:
this looks very useful for classroom use, are you teaching a class with it currently?
Nov 20, 2006. 9:42 AMjaredforshey says:
I found this one penciled into a Navy issue electronics textbook from around 1940: "Bad Boys Rape Our Young Girls, But Violet Gives Willingly (for SILVER and GOLD!)
Nov 20, 2006. 2:15 PMShark500 says:
my father (an electritian @ the budwizer brewary in newark nj) tough my that. i never forgot that.
Nov 20, 2006. 10:57 AMLasVegas says:
My father taught me a more politically correct version when I was too young for that version that went: "Big Boys Race Our Young Girls But Violet Generally Wins Good & Straight!" Same results, less offending!
Nov 20, 2006. 10:16 AMwestfw says:
Thanks for adding the screen shots!
Nov 20, 2006. 10:15 AMwestfw says:
Somewhat more politically correct: Bad Booze Rots Our Young Guts, But Vodka Goes Well I found it easy enough to memorize based on the roy g biv sort of spectrum, what with brown and black being "below" red and white being "above" violet. Two things memorized at once!
Nov 20, 2006. 6:13 AMElastometer says:
At school we used to remember the basic colour code system by means of the following: 'Big Bastards Ravish Our Young Girls But Virgins Go Without' For this reason - I'll never forget the code! Excellent Instructable though and very educational for those getting started in Electronics.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:richjd
Retired teacher and High School Principal. Teacher of math, science, digital electronics, computer leteracy, computer programing
