I was lucky enough to acquire a steel cart that was used to display Absolut Vodka in liquor stores. I was told it was made to carry half a pallet of vodka, so I figured it would be fine for my lighter duty welding and construction activities.
I think this is something you could do to other types of carts. I hope it will at the least give other people ideas for their projects.
Remove these ads by
Signing UpStep 1: Tools and Materials
HARDWARE
- Casters - 4 of 3-inch total locking casters from Woodcraft, call 800-225-1153 or web site is http://www.woodcraft.com, part# 141051.
- 16 of 5/16 inch bolts for attaching new casters to cart - home improvement store
- 16 of 5/16 inch lock washers - home improvement store
- 16 of 5/16 inch nuts - home improvement store
- 3-inch long deck screws
- 2 pieces of 3/4 inch diameter all-thread at 3 feet long each
TOOLS
The tools I used on the project were as follows:
- Cordless drill
- Drill press
- Hacksaw or cutoff saw
- Screwdrivers and wrenches
- Bolt Cutters
- Grinder
- Various clamps
WOOD
- 2x4 lumber as needed for the size of your cart
MISCELLANEOUS
Corian or other solid surface material
- Top piece is 24 inches by 36 inches
- Bottom piece is 28 inches by 41.75 inches
Metal Welding Surface
- This is a piece of steel 24 inches wide, 36 inches long, and 3/8-inches thick. I think it weighs about 95 pounds.
NOTE: If you plan on using any tool for a project please make sure you are familiar with the tool and all of the dangers associated with it. If you are not familiar with a tool then you should ask someone who is to show you the proper way to use it. A lot of communities have classes at local colleges on the proper use of tools and machinery. There are also local woodworking clubs that offer classes at very reasonable rates for beginners. I highly recommend using these resources for your safety and for the most efficient use of the tool.
SAFETY FIRST
Always wear eye and hearing protection.
Always work safe with the proper safety equipment and guards on your tools.
Visit Our Store »
Go Pro Today »
1st- there are a couple of threaded inserts that are for use in wood.
2nd- what about welding a short section of pipe on the bottom of the metal plate? Tthis way the jacking screws would be able to do their job as well as hold the top from sliding around.
Thanks for the idea.
The reason I say this is welding supply companies get a little nervous when they find weld splatter on the bottles. It can cause them to be rejected as "damaged" been there, done that.
Also, I usually have a couple of quick clamps that I place on the 2 foot long ends of the metal top to keep it in place. Surprisingly, it does not slide around very easy.
Thanks for sharing the picture.
