Introduction: Abstract : Very Low Cost Spirograph Using Laser
Picture of Abstract : Very Low Cost Spirograph Using Laser
In this project we are going to build LASER SPIROGRAPH. We are constructing laser spirograph using laser pointers using external power source, motors, mirrors and switch boxes and potentiometers. This project explores elegant design variations for Spirographs to display Tweets. Our method consisted in first tweaking. Spirographs parameters using a laser-motor drawing tool we developed specifically. We then identified particularly interesting Spirographs patterns and gave them flower names to better recall and describe them: sunflower, daisy or chrysanthemum, to name a few. We further customized those patterns, and eventually combined them with other Spirographs to construct more complex ones. As those Spirographs patterns were well suited to segment time into hours or minutes with their “petals”, we investigated one particular
scenario: Those early results show that Spirographs can go beyond simple artworks and can effectively bear both attractiveness and structure, which make them perfect candidate for ambient display.
Step 1: Laser Spirograph : Introduction
Picture of Laser Spirograph : Introduction
Spirographs are geometric curves repetition forming visually appealing patterns, while conserving a strong geometrical aspect, such as symmetries. Such patterns can either have explicit divisions similar to flowers, either have subtle ellipsoid, or the combination of both.
Step 2: Components and Feasibility
Picture of Components and Feasibility
I have build this spirograph at lowest price in Rs.1400 which is nothing but only 25$ approximately as shown in table image.I have used 10K pot and circular mirrors.
If you have used DC motors from toys and mirrors then it may build in only Rs.600 only. ($10)
Step 3: Circuit Digram and Connections
Picture of Circuit Digram and Connections
1. Make connection in series with 5V DC power supplay.(you can use 3V/9V battery also,) .
2. Make sure that both mirror are mounted on the motor has angle of 90 degree to each other.
3.Laser are Pointed such that we gets reflection in-front of box as on the screen.
Step 4: Different Patterns:
Picture of Different Patterns:
By adjusting POT 1 and POT 2 we are getting different patterns as shown in images.
I have got triangular, circular and heart shape by changing pot 1 and pot 2.
Step 5: Thank You.
For any question or query please contact me on mail id: i.momin90@gmail.com
please comment and share.
ACKNOWLEDGEMENT: Dr. Akshay Mhalotra, Abhijit Patil, Abheejit Taksale, Sumit garethia, Vikram Yadav And Symbiosis Institute Of Technology,Pune,India.
Controlling the Motor is one of interesting topics in the embedded world especially for the robotics enthusiasts, on the next post we will learn the basic of motor electronic circuit as well as how to control it with micro-controller.
safay (author)2015-08-17
These are beautiful images! Cool instructable
If you use first-surface mirrors, it will eliminate the ghosting you see around the laser trace.
http://www.sciplus.com/p/MIRROR-FIRST-SURFACE15MM-...
Doctor90250 (author)2014-12-03
I want to thank you. I built a 3-motor unit, but couldn't find a good schematic for the pot configuration, so naturally I wasn't getting much range. I did, however find a very simple method of reversing the motors with a DPDT switch. I'm going right now to rewire my pots to your config, and thanks again.
vostro1014 (author)Doctor90250 2014-12-04
You are doing very nice experiment with three motors. We are getting more pattern at lower speed of motor. Try different POT as resistance varies slowly hence speed also get very slowly which result in different patterns as I tried above. keep some tilt angle at the joint of mirror and motor. it also helps to get patterns.
vostro1014 (author)2014-12-02
Thanks Instructable. awesome DJ leight effect.
About This Instructable
3,128views
38favorites
License:
More by vostro1014:Abstract : Very Low Cost spirograph using Laser
Add instructable to:
