Introduction: Ac to Dc Voltage Multiplier
Picture of Ac to Dc Voltage Multiplier
hi,guys if you want to convert ac voltage to dc filtered voltage that too upto 450v this is where you will get
Step 1:
Picture of
Essential components
1)0.1uf 450v capacitor(18 pieces)
2) 1n4007 diodes(18 pieces)
Step 2:
Picture of
now solder the capacitor and diode as shown in schematics.
Step 3:
Take care after switching off the circuit some current will be left in the circuit it will be dangerous for your health
rakeshG38 (author)2017-08-13
hi so if I had an input of 4 ac volts would I get 6.8 volts of dc
UttkarshS1 (author)2017-03-14
hi, my name is uttkarsh
I love ur instructable and i want to build this for various purposes
I live in india......and i am not able to find the 0.1uf 450va capacitors pls help
UttkarshS1 (author)UttkarshS12017-03-14
i am however able to find a 0.1uf 50v capacitor
but that wont work.....ill have to step down my 240vac input to 50vac which i dont want to because then ill get a 85vdc voltage which i dont want
pls help
maybe if there is a altrnative to help me make this
TheGreatResistor (author)2015-12-08
My input will be 12V AC what would be the corresponding DC output
it will be 1.7 times of your input
Saurabh Verma20 (author)2015-10-10
I want to connect this circuit to 230 volts ac suply .will it work without getting damaged like breakdown in capacitor or something other.if it work what will be DC output? And if does not withstand how can I redesign( like change in capacitor value and diode) to give it input of 230 volt.
If don't mind, please reply.
hey suarabh it is already desinged to connnect to 230- 240 v ac source dont take tension just connect it.You will get output voltage that is 1,7 times of ac voltage
S.b.M (author)2015-03-06
My...input will be....4V AC supply..............what would be the corresponding DC output.....in this design.
ssparking rajesh (author)S.b.M2015-04-19
u will get around 6 to 6.5 v
kamarul7 (author)2012-12-19
What's the input voltage?
Can it be used to convert 240V AC to 12V DC?
for which purpose you want to convert it?
Lectric Wizard (author)2012-11-08
Good "to the point" Instructable ! As for step 3 just add a 10M ohm resistor across the output to self discharge the circuit after it's shut off.
Lectric Wizard thankyou sir
ssparking rajesh (author)2012-11-07
kiteman it's not a marx generator because marx generator consists of aray of resistors and capacitors
rimar2000 (author)2012-11-07
Wow, this is vey interesting. Do you know how it works?
yes, sir i know
rimar2000 (author)rimar20002012-11-07
Thanks, Kiteman.
About This Instructable
5,103views
17favorites
License:
Bio: I aM FuNkY LoVeR BoY:p
More by ssparking rajesh:Elecctronic Ballast as flyback Driver part 2 output of 200kvAc to Dc voltage multiplierElectronic ballast flyback driver part 1 to get 100kv
Add instructable to:
