Please note: some of the pictures in this how-to aren't of the best quality. Get in touch with us if you need a clearer picture for any of the steps!
Remove these ads by
Signing UpStep 1: Ingredients
- a 2-ft square piece of 1/2" thick sponge neoprene, sponge vinyl, or sponge foam
- non-adhesive grip shelf liner
- bike helmet
- dressmaker's pins
- 1/4" elastic braid
- a few thick hair nets (optional)
- metallic contact paper (optional)
- thread and sewing needle (optional)
- Voltage Regulator (see notes in Step 3) with snap battery connector
- Two AA batteries
- One 2x AA battery holder with "snaps"
- Arduino microcontroller with USB connector/cable (A Lilypad is used in this example)
- ADXL3xx accelerometer (again, a Lilypad version is used in this example)
- Six white 10mm LEDs for front lights
- Six red 10mm LEDs for back lights
- Twelve yellow and/or blue LEDs for right and left turn signals
- One Max7221 driver chip. You can order samples of this chip from the Maxim site.
- One 24-pin chip holder (for the Max chip)
- One 8-pin mini-DIN Serial cable, about 2 feet long
- One 4-wire phone cable, about 2 feet long
- Electrical wire
- Breadboard
- One 30 kOhm resistor (or resistors to add to 30 kOhm)
- One 10 microF and one 100 nanoF capacitor
- About 50 jumper cables
- About 30 Alligator clip cables
- 5 small prototyping boards. I used 4 square boards for the LEDS and 1 circular board for the Max chip.
- Wire stripper/cutter
- Scissors
- Soldering iron and Solder
- Needlenose pliers
- Cutting tweezers
- Hot glue gun and glue sticks
- accelerometer
- Max7221 chips (I blew a couple chips and ended up using 3 total)
- 9V battery (This was what actually blew the chips, I guess my voltage regulator is not the best)
![EBICU [ E-BIke-Control-Unit ]](http://www.instructables.com/files/deriv/FWF/64YR/HFD1DWTE/FWF64YRHFD1DWTE.SQUARE.jpg)
Visit Our Store »
Go Pro Today »
Or...
Will it blend?
