It's also possible to modify the software in the unit so it can measure other things if it can be connected to a i2c-bus.
Top Thrill Dragster
Remove these ads by
Signing UpStep 1Introduction
I have been working on this project in my spare time over two years now.
I use a LIS3LV02DQ from ST-Microelectronics to measure the forces, a uALFAT from ghielectronics.com to manage the SD-card, a HCMS2915 display and a PIC16F876 to control every thing. I also use a Canon NB-4L battery ( the same model i have in one of my cameras) to power the unit.
BOM (aka what you need) :
a PCB (a gcprevue-file to download)
a piece of Plexiglas 72.3x57x8 mm to the battery compartment
a piece of Plexiglas 3 mm thick to the front window
soldering iron with a small tip 0.4mm
some drills
some mill bits
thread cutter M3
Super glue and some regular glue stick
a X-Y table from Proxxon
a bench mounted drill
a battery (I use a CANON NB-4L).
a Microchip PICkit2 programmer.
a aluminum case 1455B802BK ELFA.se
a broken camera to get a battery connector from
and some surface and hole mounted components (BOM-file below).
To further explain imagine two paths of travel; one strait along the x axis with rotation about the Z axis the sensor will read this as altering acceleration and reverses along the X and Y axises(plot the sin and cos of x to visualize the sensor data), the second starts traveling along the X axis then begins to decelerate to a stop at the same time acceleration along the Y axis begines and reaches maximum just at the point travel on the X axis stop.
So given your accelerometer data did you just rotate a quarter step while riding the train or did you just get hit by it while traveling down the road? I say this from the perspective of having played with an accelerometer and a holonomic drive system at the same time, both paths of travel are equally likely, sometimes you just need another sensor/data point.
// Marcus
PCB Police
http://www.tamaramillerlee.com/Tamara_Miller_Lee/Software_files/G-Meter_Installer_v1.01.dmg
(I wrote it a while back, and am planning on making some major improvements)
(written in java)
You could set yourself up as a coaster-guru: Oh, this coaster is the best because the g-forces are such-and-such...
