3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Accelerometer-logger with SD-card memory
Step 4Mill out the Plexiglas.
  • last photo ←
Start to glue a printout of the mounting drawing on to the Plexiglas using a glue stick.
Then start to measure and mill out space for the components that are to high.
Drill and cut threads in the four holes for the PCB.
Mill out the space for the battery ( you can use almost any camera battery, but it should not be bigger than 45x38x6.5mm).
Then mill out space for the battery connector ( the connector comes from a broken CANON camera :) ).
And finally mill out a canal for the sensor cable so when you pull the cable the connector don't damage.
Create a front window of 3mm thick Plexiglas.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:lond
