Accent Chair Transformation
318
6
Published
Introduction: Accent Chair Transformation
About: I'm a musician, crafter, dessert lover and proud grandma.
Its amazing how much a chair can change with new upholstery. If you have a chair that´s stained, or you want to change its style, this instructable is for you.
You´ll see it´s not difficult, it´s time consuming but you´ll end with a beautiful piece of furniture that looks brand new. And the supplies, even the tools, are inexpensive.
Step 1: Gather Your Materials
An old chair
Scissors
Fabric
Measuring tape
Hammer
Upholstery Stapler
Pins
Marker
Upholstery tacks
Step 2: Cover the Seat
I disassembled the chair, and added a layer of wadding to the seat .
This is because it´ll be easier to clean up with this layer, with a damp cloth, without risking that the original upholstery stain the new one.
Just staple it to the bottom, then trim the edges with the x-acto knife.
Step 3: Cover With Fabric
Because my fabric has a geommetric pattern, I wanted it to be perfectly centered, so I measured the seat and made a mark at the center.
Then placed the fabric on top and pinned it. Making sure it wasn´t tilted. Finally I turned the seat upside down and stapled the fabric.
Step 4: Neat Corners
I folded the fabric at the corners as shown in the picture. Then I stapled the corners.
Step 5: Cover the Back
I measured and made a mark in the backrest too.
Then pinned the fabric on place and stapled it.
I made some snips in the fabric that is near the legs, and folded it.
Step 6: Finish Covering the Back.
I needed an extra piece of fabric for the back of the backrest. So I measured the area that I needed to cover, then I cut a piece of fabric adding two inches to the measure. I folded those extra inches.
Step 7: Put the Tacks
I measured the width of a tack (8mm). Then with the measuring tape I made marks every 8mm. And nailed them on place. They help attaching the last piece of fabric and look fancy.
Step 8: Assemble the Chair
Finally, now that both pieces have new upholstery, I assembled the chair.
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
