I'm starting a project to build a clock that will display multiple timezones (And a bunch of other stuff too), and I need some inputs to set the time and manage the menu options. Since I'd already done the research (Albeit a year ago..) I figured I'll use the same setup to create a 4 or 5 button panel to navigate the settings and change the relevant values.
What I found though is that the original Instructable was a good proof of concept, but it wasn't good enough to put in practice. After working on this the whole night I now have a more practical solution.
Remove these ads by
Signing UpStep 1: Parts list
1 x 100K Resistor (Brown Black Yellow)
1 x 1K Resistor (Brown Black Red)
1 x 10K Resistor (Brown Black Orange)
1 x 22K Resistor (Red Red Orange)
1 x 33K Resistor (Orange Orange Orange)
1 x 68K Resistor (Blue Gray Orange)
5 x Push button switches
A Breadboard
Some wires to connect it all
Visit Our Store »
Go Pro Today »
Thanks for this Instructable. It makes a lot of sense, and I'd like to try it since the Uno (which I'm using) only supports 2 interrupts via the Arduino IDE. My project requires 3 buttons and a rotary encoder. The latter uses both interrupts and I really needed a dependable solution for the 3 buttons.
My question is this: will your system work with hardware debouncing? I have used the 74HC14 Schmitt Trigger very successfully for debouncing in the past and wondered if I can still use it when using your system to detect button presses.
Thanks
Christo (Pretoria)
1> 517
2> 566
3> 610
4> 660
5> 701
6> 773
7> 843
8> 930
I know things can be better but it works great (for me). Thank you again.
You can download it here:
http://www.cadsoft.de/freeware.htm
How many different buttons could you detect with this? What is the practical resolution of the AD-input (i.e. in how many practical segments would you be able to divide the digital input and still be sure).
In some projects, maybe you don't need to be completely sure.
With the analog inputs having a 10 bit resolution, that gives us 1023 values between 0V and the reference voltage. If you divide that by 12 buttons, you can see that each button would have to be within a unique range of 85 points. I would call it no more than 40 - 50 to be safe.
If you do this, you would have to use fairly accurate resistors (Or measure them and use the ones that are close to the E12 vaues) and you would quite possibly need a better way to debounce the buttons.
