NAY! For less than the cost of a new laptop, we can make our current one shine again! Come with me as we do both routine and very non-standard upgrades to pimp out the budget Best Buy laptop we've come to know and love!
What- you don't own one?! Well, read on anyhow. A lot of what we cover here should work with other machines. Now, let's begin- and remember, laptops ARE upgradeable! Practice your evil villain laugh whenever someone tries to say they aren't...
Remove these ads by
Signing UpStep 1In the beginning...
T5250 CPU (1.5Ghz, 667Mhz FSB, 2MB L2 Cache)
1GB DDR2 RAM 667Mhz (two sticks of 512MB)
15.4" WXGA Crystal Brite 1280x800 LCD
200GB 4200rpm SATA 8MB cache HD
Intel 3945 802.11a/b/g Mini-PCIe Wifi
4000mAh Lithium Ion Battery
Yeah, that is a little dated. I did leave out the DVD Multi Drive (as that is still pretty standard) and the GMA965 / X3100 Intel videocard (which isn't upgradeable anyway). But everything else listed above? I say... eBay it! Seriously, I sold off all my old parts on eBay and Craigslist to help offset the cost of new components. Madness, you say? Maybe. But every item on that list can be seriously upgraded!
Bwahahahaha! ...sorry, mad scientist laugh.
i had one and it had the exact same case and everything, righ down to the built in webcam and missing riser on the motherboard. the motherbaord is the only part thats different between your acer and the 5530.
Anyways, my comment/questions relates to having to buy a nu484 led lcd cable for $30 to go witha new dell wuxga for over one hundred and nto being able to use any of the other brands screens mentioned aboe.
Why do laptop makers make it so damn hard to use other screens? This seems to involved these lvds cables and the fact that they all seem to have proprietary connecters. Even from dell to dell the same cables seemingly cannot be used. is this just there way of making it harder to cut them out of the replacement screen chain? could i just solder or splice the lvds cable from, say, the toshiba screen into the dell cable that will fit into my dell 1737 motherboard? are there little adapters i coudl put on the end fo these things? lets say i wanted to use the acer 7714z led lcd screen and i had a dell cable nu 481...how would one combine those? also, is it true that no inverter is needed to put with my new wuxga monitor in my dell, which came with a wxga+ screen that had a separate inverter?
thanks,
I cleaned the Fan & Vent holes too
My bios is also v 1.35
any help ???
My Model is 5620z
Of the upgrades you mentioned, the one I am most interested is adding Mac OSX. Do you have a detailed install guide for the Extensa? If so, I would love to know where to start!
AC connection point of my extensa has gone in side and coz of this I am unable to connect with AC Adaptor...can any body please help me
Great post by the way! I was about to get a new laptop, but i love my acer and i much rather do this. Thank you.
I have 965 chipset + x3100 graphic accelerator.
I think it runs at a maximum of 384 mb currently.
You won't magically have a high-end videocard or more video memory, but these upgrades do help the onboard X3100 video a bit. I didn't do any benchmarking, but the difference was noticeable to me. Especially with an on-board shared-memory card, ram and cpu upgrades do improve performance.
That said, don't expect to suddenly rate over a 3.5 in Windows' video performance index ;)
should mention that I used MSCONFIG to stop all non microsoft programs before I upgraded
I DOWNLOADED, EXTRACTED AND TRIED TO RUN
WHAT AM I doing wrong?
Thanks
Thanks!
May try to upgrade the Hard drive next as this may help the start up time. I don't want a really noisy hard drive through or one that heats up too much or draws to much power. I assume the Fujitsu 320 GB hard drive fits that bill? I see it only costs $ 69.00 with shipping.
If my fsb is really at 800, should I look at faster memory?
Thanks a lot
I only problem is relatively slow starting Acer provided launch programs which I believe are not probably necessary. Did you delete these programs?
Also the Acer provided recovery disks that I purchased would not format the new drive. A local PC shop gave me a copy of a Vista Home start up disc and that did format the disc. Then the Acer provided materials worked fine. I only purchased the recovery discs from Acer because the a Acer back up split my hard drive which I didn't want in the future.
I think I will stop here as the LCD screen looks ok to me and I can't really speed up the graphic's card. May change out the WI FI card some day.
Thanks again. I would not even thought about doing this without your help.
Great, great great. You are doing everyone a great service.
its specs are
Intel Pentium dual core T2390 Processor
(1.86 GHz, 533 FSB, 1MB L2 cache)
15.4 WXGA LCD
120 GB HDD
Before i start doing this i am wandering whether can my 5620Z motherboard support core 2 duo processors
& can it support RAM more than 2 GB
thankx again
I'm thinking about either follwing your guide and giving it a full overhaul with the processor and ram or maybe just downsizing my hd again as i'm worried that my replacement hd or win7 is causing the cooking? Would really appreciate thoughts/ advice?
many thanks again
