Step 3The CPU- let's think big
To replace the cpu, first- choose one! I picked a T9500. Any Socket P cpu with a FSB of 800 or lower will work, but I felt that was a good choice. Here's how it compares to the old one:
T5250: 1.5Ghz, 2MB cache, 667Mhz FSB, 65nm core, 35W power
T9500: 2.6Ghz, 6MB cache, 800Mhz FSB, 45nm core, 35W power
Uh huh. The T9500 kicks the T5250's ass, all while doing the same wattage! Definitely a helpful upgrade. So let's get right to it.
Once you've taken off the cpu fan and heatsink, you should see the cpu itself. It's held in place with a ZIF (Zero Force Insertion) type socket, which locks using the little screw device next to the cpu. Looking close, you can see that it is currently set to the locked position. Using a small flathead screwdriver, turn it to unlock. Now you can lift out the cpu, and insert the new one. I recommend using a thin layer of Arctic Silver or some kind of thermal paste. To lock the new one in place, very gently hold the cpu while turning the locking mechanism back. REMEMBER- when putting the heatsink back on, do a little at a time on each screw, NEVER all at once. Better to be safe than sorry!
Add Comment
